Question about Cobra 29 LTD CB Radio
My cobra 29 NW/WX won't power up.
I run it in a loader at a quarry and has worked fine for some time till one day when i turned it on, it powered up for about 3 seconds and then hasn't powered back up since. i took it to my bench and put a power supply on it and it still won't power on. i replaced D23 which is supposed to be the circut protection diode but to no avail. any suggestions what i should do in this situation? What should i look for?
  • davedknzz May 05, 2009
    i replaced both diodes AND the power wire from the socket to the board and it powers up again. i'm thinking it was the wire from the socket to the board. something i would've never looked at !!! Thank you, Thank you!!! this is one that'll be something to remember for future problems....
    Guru:
  • 773 Answers
Open the case and hook power inside past the power socket. They do go bad from time to time.
Also, if you never checked the SWR, and you noticed the ant ligh come one ever, you could have burned up your final. You now have a paper weight.
Oh and the protection diode is D28 not 23. It should be a big black one. Also, D8 is another protection diode. they are the only big black diodes in the radio.
Posted on Apr 24, 2009
  •  Laron
    Laron Jul 30, 2011
    D23 is the protection diode.
    D8 spike suppresser diode.
    There isn't a D28 at all
The weather channels quit working on my cobra 29 nightwatch.
its an internal problem , take it to a tech and let them fix it. the board for the wx probably has jumped freq. and thats why you can't receive wx.
Apr 10, 2015 | Cobra 29 WX NW ST 40-Channels Base CB...
I have a cobra 29 wx nw st cb radio I have power to cb and won't power up
is fuse good should be on red wire power or in back of cb itself
Jul 26, 2014 | Cobra 29 LTD CB Radio
Every time i turn on my cobra 29 wx nw st sound tracker it goes back off
Hi Davis, please post on CB radio forum, this is Radio scanner forum.
Cheers,
Peter
Feb 20, 2013 | Cobra 29 Wx Nw St 40-channel Nightwatch Cb...
Cobra 29 NW WX BT Channel indicator
Still have the receipt? Take it back to the store and exchange it for another one. Easiest and quickest solution.
Otherwise, you can unplug the power from the radio and take the top cover off and check at the channel selector module to see if there's a broken wire or a broken solder joint. If the radio received rough treatment during some point in shipping (the outside packaging box may show no signs if it) it could be just a bad connection.
With the top cover off, replug the power and turn on the radio. BE CAREFUL IN HERE, THOUGH!! With a pair of insulated needle nose pliers, gently move the wires that connect to the channel selector module and see if it will light up. If so, disconnect the power and re-solder the joint or replace the broken wire. Reinstall the cover and reconnect the power, you should be good to go.
WARNING...if you open the cover on the radio, you cannot return it. Do this only as a last resort, if you can't return it for an even exchange for the same model radio.
Oct 22, 2009 | Cobra 29 LTD CB Radio
could be a lot of things. could be the audio chip. radio could be toast. its not something some one can tell you how to fix on fixya.
it needs a radio tech.
Apr 21, 2009 | Cobra 18 Wx St Ii Mobile Cb Radio
Cobra 29
it's all about R55 and L14 and etc.
Jan 11, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
COBRA 29 WX NW ST
have somebody look and see if there are any bad solder joints inside the radio...
Jan 10, 2009 | Cobra 29 LTD CB Radio
29 help
hi, sounds like you have a problem with the SWR' S Probably too high. Tumbleweed01
Mar 12, 2008 | Cobra 29 WX NW ST 40-Channels Base CB...
Cobra 29 LTD CB Radio Logo
515 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
