Question about NEC MultiSync LCD1510V Plus (White) 15" LCD Monitor
Display clours The display is always very yellow no matter which setting i choose.
0 characters
1 Points
Change display landscape
Right click anywhere on your desktop. Choose Screen resolution. In the box that pops up you will see a tab call orientation. You can change between landscape and portrait.
You can also get to this menu by clicking
Start, control panel, display. Then choose Change Display Settings on the right side of the box that opens
Dec 07, 2013 | ViewSonic Computer Monitors
My screen doesn't display anything when connected by the hdmi cable to the ps3.
ok so you know how you can see the playstaion using the red yellow and white cables use those first and go to settings and choose display options or play around until you find the option for hdmi set it for both audio and video to go through the hdmi
Apr 01, 2013 | Computer Monitors
Soyo monitor MT-NI-DYLM1998 "out of range."
Your windows 7 screen resolution is set too high and your display doesn't support it. There are 3 possible solutions to this problem:
1. Press F8 during startup and choose "Enable row-resolution video"
2. Press F8 during startup and choose "Safe mode" and change screen resolution there, then reboot.
3. You can always use another display (if you have one) to set screen resolution to lower value.
Oct 15, 2012 | Soyo Computer Monitors
AOC i2353 has border around displayed image, not running at full 1920x1080res?
Had the same problem! Solve it: go to the AMD catalist and choose advanced look. then inside the digital display setting you'll see scalling option that will show 10% . Set it to 0%. Done!overscan.png
Oct 15, 2012 | AOC I2353PH New
Windows 7 wouldn't detect 1600x900 resolution after installed and uninstalled magictune premium, tried reinstalling windows, updating driver (Ati 2600 pro; ati catalyst 10.2), update monitor driver from...
Try setting your color depth to 16 bit first then 1600 X 900 and try a reboot to see if it stays. Use only the windows display manager to do this, not the catalyst control. If the resolutions stays you can try setting it back to 32 bit and saving. The true max settings will appear in your windows display manager, and not always in third party display management software.
Trust that before you trust Catalyst or magictune.
Remember not to force the resolution above what windows considers safe, even if you know the monitor can handle it. Also bear in mind that Win7 is not fully ready for some things yet, even if Microsoft says it is.
I never trust a new Microsoft OS to be fully compatible with anything, no matter what the press statements report. So far this has kept me from destroying many components that may have otherwise become damaged or corrupted.
Mar 10, 2010 | Samsung Syncmaster 2033SW Monitor
The color pallet changed to blue, green & yellow, how do I change it back? model f1703
try to reset your monitor. just press the menu button to open on screen display, theres an option that says factory settings, choose that option and choose yes to continue..
Sep 12, 2009 | Computer Monitors
This is generally caused by no video signal from the computer. Try the monitor with another known working computer. If it works there, the video card (or onboard video) of the original computer is faulty. Otherwise, it is a problem with the incoming signal circuitry of the monitor (or cable).
May 26, 2009 | Acer Computer Monitors
My LCD shows display in safe mode but no display in Normal boot.!
Its the problem with your display resolution. In Safe mode set it to 1280x800 and restart..
Apr 19, 2009 | Samsung SyncMaster 152 B 15" LCD Monitor
When i log on to my windows profile the screen
try reset the display settings click right on the desktop
choose diplay parametrers.
Mar 13, 2009 | HP w2207 Monitor
NEC MultiSync LCD1510V Plus (White) 15" LCD Monitor Logo
Top NEC Computer Monitors Experts
Brian Sullivan
Brian Sullivan
William Miller
William Miller
Are you a NEC Computer Monitor Expert? Answer questions, earn points and help others
