in the chanel set up mode , verify that its set to antenna and NOT cable , also verify with other known working tv that antenna is still good and working well
Remote Control Code for Element LCD TV -- & Direct TV Haven't been able to find the right code to program the - Olevia LT32HVM 32 in. ... It is annoying to turn the TV on and the volume with the Element remote and then have to use the ..... Need the codefor a 42 inch LCD TV model ELDTW422 to program our Direct TV ...
? 6:40
https://www.youtube.com/watch?v=EKtjBnx6EG0
Mar 27, 2013 - Uploaded by PureLegit
This is a new video on this TV that I got from Element. If you go back on my channel you will see my first ...
Main system control memory IC fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
put the co axel cable in the back , bypass this tv programming stuff put your tv on channel 3 or 4 and use the cable remote , no tv channels just cable
G into the menu function and look for channel search.Usually pretty easy to find .Manual add and auto settings. Use auto if new channels are already operating.Otherwise use manual
you need to go into the menue, under setup and chanels, do the auto program, it will memorise all the chanels that you can get, analog, and digital, after that, just type in an analog chanel, if it goes to a digital chanel, hit the chanel down button
