Question about Lands Phones
Can't find instructions to lock in speed dial numbers. Thanks.
I have an old Telstra Alcatel fixed phone, but can't find instructions as to how to lock in speed dial numbers. Thank-you. Roger.
bestdarngood
  • 3037 Answers
SOURCE: How to set numbers on speed dial
Main support number 1-800-338-9549, I'm sure they can help you
Posted on Mar 19, 2008
SOURCE: setting up speed dial numbers
User Programming Mode
�� To enter User Programming Mode, press the Program button ...or dial #9876. "USER PROG MODE" appears on your LCD. The Program LED is steady green. �� To exit User Program Mode, press Program … or go off- and on-hook press #9876. Note A IPT equipped with a headset adapter ignores the hookswitch. It can only exit User Programming by timing out (approximately 15 seconds).
Posted on Jun 10, 2008
SOURCE: Programing Speed dial on Walker W1000 Clarity Phones
I solved my problem by trial and error!
Steps to program speed dial on the Walker/Clarity Model W-1000 Touch Tone Sound Amplifier desk set phone w/large number pad.
1. Choose phone number to program including the (#1) digit for a long distance direct dial if
needed.
Write chosen number(s) on a scratch pad as a guide for numbers. Identify numbers with the
names or contact description (ie."Mom's Cell Phone.")
2. Remove hand set receiver from phone.
3. Press "memory set" button ONCE on the phone located uder the receiver on the desk set.
4. Enter phone number chosen,including area codes and long distance prefixes if needed!
5. Locate the speed dial position button you want for that number...(located adjacent to
tag/pad slot for name and/or phone number to be written after entering.
6. Press the speed dial position button (ONCE). Then replace receiver back in craddle.
7. Try out speed/dial program. Pick up receiver, push speed dial button(position) listen to see if
correct phone number is contacted. Once established as correct; program additional speed dial
numbers: ie family, business, as needed.
8. DO NOT TRY TO PROGRAM THE NATIONAL EMERGENCY 911 NUMBER! Keep this in your
own memory!
9. If you make a mistake while entering a phone number: Stop, Hang up phone and start all over
again in the procedure sequence.
10. Remove white "description pad with slots for names or numbers) from underneath clear
plastic cover.(use a paper clip end to lift up plastic cover). Write name/description for that number
on white pad(ie. "Mom's Cell") Use a PENCIL FOR DESCRIPTIONS!!
11. TO SAVE TIME AND INCONVENIENCE TO PERSONS/BUSINESSES OF HAVING TO
ANSWER YOUR CALLS; CHOOSE A AUTOMATED ANSWERING NUMBER (USUALLY A
BUSINESS ANSWERING AUTOMATED SERVICE (IE. LARGE INSTITUTIONAL PHONE
NUMBER THAT HAS A MENU PROMPT usually a AT&T 800 # will have a prompt menu
USE this procedure to see if you program correctly then once you know how; go back and re-
enter all the numbers that you actually want on your speed dial settings.
Posted on Nov 29, 2008
  • 63 Answers
SOURCE: Programming speed dial numbers into NEC DTU-32D-1A phone
hit feature key,hit a line key,dial 9 plus the number,hit feature
Posted on Mar 14, 2009
Z1G ZA9
  • 122 Answers
SOURCE: I lost instructions to program the 12 buttons on the phone
Hi
As you have not posted your model number? Have a look at this link...
http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Telephones.75500
On your phones base you should have a sticker, which will have the model number on it?
On the web page that the above link takes you to, enter the model number in the search box and it should return a download for the user guide.
Hope that helps?
Posted on Apr 29, 2009
Telstra Next G mobile phone. How do I call a Speed dial number?
just long press any key and it would give u the option to enter number for speed dial
Jun 30, 2016 | ZTE Telstra T165i Next 3g Blue Tick Phone
I cannot find how to set up speed dial on this phone
Yup, you can set a maximum of 8-speed dial entries.
1. From the main menu, select Settings > Phone settings > Keypad > Numeric keys.
2. Highlight the key with which you wish to assign the speed-dialing number (from 2 to 9), pressEdit > Contacts.
3. Scroll to choose a contact you want to assign from Contacts and press OK.
Oct 23, 2015 | Tracfone Wireless Alcatel A392G...
Alcatel cel ph model OT510APIB procedure for turning off emergency speed dial number
Please go to "Menu"-> "Settings"-> "Call settings" -> "Speed dial"->Select a number -> "Options"->"Edit", then select a contact number.
you must do this for every speed dial number you wish to delete!
Easy as...
Mar 11, 2015 | Alcatel Lands Phones
I have put numbers into speed dial of my Alcatel 20.01. I do not know how to get quick access to speed dial
try pushing the number 3 once for 2 or 3 seconds . I have 2 through 9 programmed in
Mar 03, 2015 | Alcatel Lands Phones
Tracfone customer service
Try holding the number for 1-2 seconds instead of just pressing it.
Aug 21, 2014 | ALCATEL-LUCENT USA INC A382G The Big Easy...
My hip top is not connecting to the internet how can i fix it?
Cellink have them:
None. As long as you are not locked into a contract with your current
service, you can move your number to any provider.
Given the old phone model you have, I would say that you are out of contract
with Telstra. In that case, you can move your number anywhere.
When shopping around, I would look at other providers as well as Telstra.
Some fantastic deals out there...
Jul 30, 2012 | Motorola Mobility SIDEKICK SLIDE DANGER...
I need instruction manual to program speed dial
I was unable to locate a user manual for that particular device, however the basic instructions for programming speed dial functions are normally very similar between most phones.
Generally there are ONE TOUCH Speed Dial buttons labelled something like M1, M2, and M3 on the dial pad somewhere.
There should also be another button labelled PROG or STORE on the keypad as well.
Normally to program a number into a ONE TOUCH speed dial memory location you carry out the following procedure:
Lift the handset.
Then press the PROG (or STORE) button.
Now just use the number keypad to dial the full telephone number that you want to store in a Speed Dial location.
Once the full telephone number is dialed, then push the M1 button to store that phone number in the M1 One Touch Speed Dial location.
The phone may or may not show some kind of confirmation that the M1 location was just programmed, then just hang up the handset.
Now when you lift the handset and press the M1 button, the phone should automatically dial the phone number you programmed into it.
Now just repeat the same process for the M2 and M3 One Touch Speed Dial buttons with other phone numbers if necessary.
To change one of the Speed Dial numbers, just carry out the normal programming procedure for that location using the new phone number and the old number will simply be overwritten.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Dec 02, 2011 | Southwestern Bell FM-480 Corded Phone
I have an older at&t 620 speaker phone
goto call settings and fix in the numbers you want for speed dial
Jul 15, 2009 | Lands Phones
Power outage lost fetaures
Contact these guys (sorry they dont still have a manual online); http://www.alcatel-lucent.com/wps/portal/ContactUs Hopefully they can help you out :)
Jun 27, 2007 | Lucent 1872 Corded Phone
Lands Phones Logo
56 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
