Question about Canon imageRUNNER 400S Copier
Printer canon
Printer canon this machine repeats its warm up process. again and agin doest go on ready mode
  • mailramkumar Nov 17, 2007
    E677 message comminig
  • Anonymous Dec 17, 2007
    after 5 min whn the machine is on it gets this code e677 (printer canon this machine repeats its warm up process. again and agin doest go on ready mode)
Sir,
I have IR 400 copier machine, i have faced problem of Error massage of E677 when i
give print command from PC. While switching to PC mode it display the massage
WAIT.....
& while making coping this error massage came E677 & also E803 some time.
You are request to please do arrange to give one perfect solution for above error massage.
Waiting for your favorable reply.
Regards
Hitesh - India.
Mob.: (091) 09824402926
Posted on Sep 11, 2008
I am a certified canon copier technician and you guys are all wrong.
Posted on Jun 10, 2008
  • 146 Answers
Check the heat lamps, thermistiors, and thermostat in the fusing unit. The thermostat should show 0 ohms. The heat lamp should have some resistance but not be infinite, and the thermistor(s) can be checked by holding the part that rubs the heat roller between your fingers and watching the meter for a gradual change in resistance. Letting go of the thermistor will induce a gradual change in the opposite direction. The thermostat is a redundant system to cut the power to the lamps themselves should the thermistors and the temp control circuit on the main board fail. You can go into service mode and force the lamps on to check the entire heating system but that won't check the temp control part of the circuit.
Posted on Jan 02, 2008
    Problem Solver:
  • 18 Answers
What  model is the printer ? This could be Hard disk or system software problem.
Posted on Oct 15, 2007
  • 163 Answers
There is the heater bord problem in your printer
Posted on Sep 16, 2007
SOURCE:
My canon imagerunner 6000 hangs on starting the machine. It just says wait.....
Most copiers and printers have a mode called power save mode. If the Machine is not in use it saves energy and powers down to a lower level. Once it receives a print job it takes a bit for it to warm up. It can take up to a couple minutes on some machines to do their self test while powering up. As long as it gets to the ready mode to unit is good. On some unit you can disable the power save mode or make the between going into power save mode longer.
Printer Repair Service in Miami and Fort Lauderdale FL
Jan 15, 2016 | Canon Office Equipment & Supplies
Canon code E000001-0002
E000001-0002 refers to the fuser assy either getting to hot or not hot enough. Fuser error codes cannot be reset by power cycling the machine even though that is what the display tells you to do. In order to reset the fuser error code you must enter the service mode & reset the code. To enter the service mode:
press"Additional Functions" button (looks like a picture of a head with a star inside)
press the #2 and #8 at the same time (simultaneously)
press "additional functions" again
The display should show a choice of
copier,feeder,sorter,fax,or board service modes
Select copier
select clear
select ERR
press OK
Turn power off & back on.
****IMPORTANT****
After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils at 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair.
Oct 21, 2015 | Canon Office Equipment & Supplies
I have downloaded a printer driver for BJC 1000SP for Canon inkjet printer but it i s not win 7 compatible so need help Venugopal
The only way to work around your problem if canon doesn't produce a new Win 7 driver, is to download & install "XP mode" on the win 7 machine. Google it and you will find numerous articles describing how to do this. Once installed, you can open the XP mode and install the printer there. Once you have it installed using the win xp drivers, make sure you click the tab at the top of the screen and select "attach" for the device you require. You have to repeat this attach process each time you open XP mode.
NOTE! XP mode will only work on WIN 7 Pro and upward.
Jan 29, 2011 | Epson R245 InkJet Photo Printer
Hi dear mis/mr we have hp 1212nf mfp,ok when we turn on the printer ,after ready,Continuous restart agine the printer . how to reset factore this printer? how we can update this printer cpu flash...
press and hold the power button for 30 seconds after disconnecting the power cable and the USB from the back of the printer.
repeat this process thrice and the memory will be formatted.
you can update the printer drivers from HP.COM
Jan 03, 2011 | HP LaserJet M1522nf Multifunction Printer...
Canon IRC3200N warms up from cold when printing first job
One way is to leave the iRC3200 in standby mode and have one the office servers or office PC's to have ajob scheduled to print a 1 page startup job at 0835 so that the unit is ready for everyone at 0845.
Nov 12, 2009 | Canon iRC3100 Printer
How to rectify the continious error in copier IR3300 canon
the last error generated is from the fixing unit you have to clear the error again,but if this error code (Error 003) returned a thorough check on the fixing unit is needed.Or could be the AC supply to the machine is not stable.Go to program mode got o display> analog check the fuser/fixing temp hope this will help
Jun 30, 2009 | Canon Office Equipment & Supplies
XEROX WORKCENTRE M20 WHEN POWERING UP MACHINE IT WILL NOT COME OUT OF WARM UP MODE. FUSER IS HOT. MACHINE DISPLAY WILL SAY WARMING UP, MACHINE WILL CYCLE, SCANNER WILL MOVE , PRINTING WILL APPEAR ON...
what you want to do is this, turn the machine off. Remove the back cover. Then on the main board you should see a memory stick or 2 depending on the model.
Remove the memory sticks, then power up the machine with them out. Let it come to ready, then re install the memory sticks and power the machine back up to remove any software corruption.
Apr 08, 2009 | Xerox WorkCentre M20 All-In-One Laser...
Canon irc2600n is taking time to boot what could be the problem
There is a boot wait timer set for 2 minutes by default on the unit. If the unit is taking longer than that it may be that it is warming up in preparation for printing. If you have warn parts, it may be taking a longer time to fully become ready.
Otherwise, seek support from a trained Canon technician or your Canon dealer.
Most features in service mode are designed for trained technicians. Many options are not labeled and ambiguous and assume you have been trained by Canon for the machine.
The process to enter service mode is available by searching google. I am unable to post it here due to a non-disclosure agreement.
Guides for this are almost impossible to find online, in my experience.
Mar 27, 2009 | Canon imageRUNNER C3200 Color Printer
How do I fix this?
please have the check on fuser for damage. Could be a thermistor, thermo switch, or faulty heaters. To clear error, service morefunction/clear/error/ok/ exit service mode and cycle power.
fuser over temp means the fixing assy has exceeded the manufactures maximum temp limits
Fuser error codes cannot be reset by power cycling the machine eventhough that is what the display tells you to do. In order to reset thefuser error code you must enter the service mode & reset the code.To enter the service mode:
press the #2 and #8 at the same time (simultaneousley)
Select copier
select clear
select ERR
press OK
****IMPORTANT****
Afterclearing error stay at the machine to see if it comes to ready. Thefuser assy can reach 139 degrees C.(Water boils @ 100C) The error canonly be cleared through the service mode because a technician shouldinspect the fuser to verify there is nothing faulty that could possiblystart a fire. If you enter the service mode & clear the error,power cycle the machine & during warm up the machine throws a codeagain- turn it off, unplug it & call a tech for fuser repair.
Good Luck!!
Aug 10, 2008 | Canon LASER SHOT LBP-5200 Printer
Canon imageRUNNER 400S Copier Logo
237 people viewed this question
Clive
Clive
old marine
old marine
Ekse
