Question about Maytag Atlantis MDG6400AW Gas Dryer
My Maytag Atlantis MDG6400AWW will not heat up. The drum spins but the clothes don't dry!
  • jetgoodie Apr 22, 2009
    I have the same exact problem. No heat
  • Anonymous May 01, 2009
    Ignitor,where is it? And how do I remove it?
My dryer timer is not turning off and it does not get hot,I check glow coil.its working but it does not fire up.I smell gas some time
Posted on May 04, 2009
    President:
  • 1,865 Answers
1. Ignitor needs replacing
2. Gas manifold needs replacing (less likely)
3. Make sure the temp controls are in proper setting
4. Remove lower panel of unit and look for ignitor to glow or spark when you start the dryer.
5. Remove ignitor and inspect for cracks, and check with ohm meter.
Posted on Apr 16, 2009
Maytag gas dryer will not turn on but has power only about 2 years old
Posted on Aug 19, 2009
My washer machine don't spin
This will be a blockage in the waste pipe or pump, probably a small pice of clothing managed to get past he outer drum seal and get down into the pump.
Jun 19, 2011 | Maytag Atlantis MAV6000 Top Load Washer
My Maytag MDG6400AWW timer does not advance in the Auto mode. The clothes will dry but it will spin and spin for hours until you open the door. In timer mode everything appears to work normally
sounds like it is not sensing the temperature, which is the thermostat, here is a website that will help you out, #6 dryers basic, Good Luck Tim:
http://www.applianceaid.com/general.html#timers
Nov 27, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
My dryer will not heat.....the drum spins and air appears to be blowing but not heating up to dry clothes
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 02, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag Atlantis MDG6400AWW, timer stopped working
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 20, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
Damp clothes at end of spin cycle
Time to check out and clean your filter...........
Mar 01, 2009 | Maytag Atlantis MAV8551 Top Load Washer
Inside of my maytag atlantis electric dryer...top layer is erodin
I WOULD NOT WORRY ABOUT THE FINISH COMING OF EXPOSING ANYTHING TOXIC. WHAT COULD HAPPEN IS THAT WITH TIME, THE DRUM MAY RUST AND TRANSFER IT ONTO THE CLOTHES. DEPENDING ON ITS CONDITION, IT SEEMS NEW ENOUGH TO WARRANT INSTALLING A NEW DRUM. I DONT KNOW IF A COATING OF PORCALINE SPRAY PAINT WOULD STAND UP TO THE CONDITIONS IN THE DRYER BUT IT MAY BE WORTH A SHOT AS I DONT KNOW OFF HAND WHAT A DRUM SELLS FOR.
Jan 23, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Mytag Dryer ModelLdg4000Aw
I have a Maytag Atlantis Gas Dryer that will turn on, rotate, but will not get hot and dry the clothes. A load of clothes in the afternoon, didn’t dry, tried again but didn’t dry – went to bed after putting on auto dry - next morning the dryer was still rotating and didn’t turn off. No hot air – only cold air.
Jul 13, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag Atlantis MDG7400AW Gas Dryer not drying clothes
This problem doesn't sound right, but you could have a bad moisture sensor.
May 19, 2007 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag Atlantis MDG6400AW Gas Dryer Logo
1,527 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
