Gas or electric? My gas oven would not come on last year. Once I had checked the integrity of the gas supply I researched and found that if the glow bar glows orange instead of white, it is worn out and needs replacing. DIY for about $35. Works wonderfully since the replacement. You can find several "how to" videos on YouTube.
SOURCE: Having taken the oven out to fix a problem with
Both the top and bottom oven will only work if a time (any time) has been set on the clock. Setting the time operates a contact to switch the power through. The only exception is the grill. This will work even if the time has not been set. So if the oven controls/lights and heating work, to me it means that the clock/timer is half working and the only thing that isn't is the display.
I haven't had the clock/timer to bits but a fellow blogger has said that in some timers there is an electrolytic capacitor that controls the display. When this fails as they are renowned for doing, the dispaly mal functions. If there is one then Maplin have some - VHR41W/43W and DT64U depending on value etc. Let us know how you get on.
If you need a new clock/timer they are around £80 from espares.
