Question about Razor MX350 DIRT ROCKET - BLUE
MX350 Battery fully charged but won't run over 2mph
I have an older electric Razor MX350 dirtbike (101520-04-05090035507). It has sat for about 1 year and I have purchased a new battery. It then ran fine but over a short time always seems like it has a dead battery. Symptoms: 1. When I first attach the charger, it quickly goes to green. 2. When my 42 lb boy rides, the yellow light on the throttle comes on and it goes about 2mph for 50 ft. 3. When I take off the battery covers and measure voltage at the back of the connector with the red and black larger gage wires (maybe 10 gage or so), I read about 25 volts. So, I thought geeze, the battery isn't dead, the power just isn't getting through the controller. So.... 4. With the power turned on, I put my meter to the blue and brown wires out of the controller and throttled up while holding the bike still. I read a max of about 4 volts, but it quickly goes to 0 at about 3/4 throttle. The yellow light for low power remains on if giving throttle while loading the bike by not letting it roll. Do you think it may be: 1. controller 2. bad throttle 3. bad power switch 4. bad motor or something else.... Thanks, Joe
4 Suggested Answers
bozcro
  • 867 Answers
SOURCE: my razor mx350 battery charger blinks green when
green should mean charge is complete
Posted on Aug 15, 2009
  • 1340 Answers
SOURCE: how do i change the rear tier of my razor mx350?
I would take it to a shop only because the tire has to be on almost perfect so there is no wobble.They have the proper equipment to make sure it is aligned properly.If you are going to go around 40-50 mph alignment is critical.Even jumping moguls and turning alignment is critical.
Posted on Jul 22, 2010
erickedubbs
  • 15 Answers
SOURCE: Indicator light fully charged...but barely enough power to move
i have the same exact problem on 1 of my sons MX5s..i checked all 3 batteries and all that! you left out the controller clicks when the back wheels sapose to be moving ,it's not....so worse case scenerio batt,controller,motor,(650 This time)& throttle....So theres our blue print...lets hope it's just the batteries....!
Posted on Apr 13, 2013
What could be the problem if my son dirt bike says its fully chaged but when he turns the throttle nothing happens
Did the socket the charger was plugged into actually have 120vac in the socket?
Or are you sure the charger is actually working? Is there a short so that the battery is draining as fast or faster than the charger is providing a charge?
Mar 27, 2015 | Razor Dirt Rocket MX350 Miniature Electric...
Razor mx350
Have you tried removing plastic chain guard and making sure chain is not off track i had this problem and that is all it was.
Apr 24, 2014 | Razor MX350 DIRT ROCKET - BLUE
My Dirtbike, wont go after i charge it
Check that the lights on the throttle battery gauge show green. Lift the rear wheel off the ground and apply throttle and watch the lights. If the battery voltage drops under this load, indicated by the light changing to yellow or red, then it is likely the batteries are low in capacity and need replacing. Most battery shops will load test the batteries free of charge to confirm.
If the batteries test OK then it may be a bad connection between the batteries, fuse, switch and controller may also cause the voltage to drop under load,
Oct 15, 2012 | Razor MX350 DIRT ROCKET - BLUE
Low battery backup
Have a read of the trouble shooting guide here,
http://www.razorama.com/razor-installation-guides.html
It sounds like a fault with the charger. Test the charger output with a voltmeter to confirm correct operation. IF OK then check the wiring , fuse, switch conections between the charger and the battery.
wiring diagram is here http://manuals.monsterscooterparts.com/recreational/Razor/Wiring/
Jun 08, 2012 | Razor MX350 DIRT ROCKET - BLUE
The bike after charging is going very slow, not full speed! What could be the problem? MX350 Dirt Motorcycle
could be a faulty battery charger not putting out the right amount amps,or battery could be going out.
Aug 07, 2011 | Razor Dirt Rocket MX350 Miniature Electric...
I was given a mx350 that has been sitting in a garage for a year I charged it for 8 hours but it does nothing the light comes on to show it has power but when i turn the throttle nothing no sound or...
If it was working before it sat, then it is almost certainly the battery (these kinds of batteries suffer if sitting and not fully charged). If you had one, or could borrow a voltmeter, you could check the batt. Also, lots of car part places like NAPA can test batteries for you.
Hope that helps
Jul 18, 2011 | Razor MX350 DIRT ROCKET - BLUE
Wont run but is fully charged
the throttle is a voltage resitor and either needs cleanded with electa clean elictical parts washer or it need replaced all together.
Jul 09, 2009 | Razor MX350 DIRT ROCKET - BLUE
Razor e200 runs slow
This could be a sign of a dying battery, although it charges and lights the green light it cannot maintain enough juice to power the machine when it has weight on it.
Dec 07, 2008 | Razor E200/300 Electric Scooter Battery
Razor MX350 DIRT ROCKET - BLUE Logo
623 people viewed this question
Top Razor Cycling Experts
Erick Williams
Erick Williams
Level 1 Expert
Donald Ayers-Marsh
Lawrence Oravetz
Are you a Razor Cycling Expert? Answer questions, earn points and help others
