Question about Durabrand DWT1304 13" TV
I cant get it to go to cable
I need to get my tv to cable
  • thugzy8869 Apr 16, 2009
    i do not have in put on my remote
  • 10,865 Answers
Push the input button on your remote and a menu will pop up on the screen. go to the cable connection and u will be in business
Posted on Apr 16, 2009
I cant connect my tv to computer
Hello
All modern TV's can be used as computer monitors - you just need the correct cables and select the correct input on the TV.
What cable are you using to connect your PC to your TV? VGA or HDMI? Your listed TV has both ports but your computer may not have a HDMI port. Either way, connect the correct cable from your PC to your TV and note how the port is labeled.
Turn the TV on and then find the "Input Select" button on the remote and press it until the above port appears on the screen.
If you use the VGA port, you will need to hook up the audio from the PC to the "PC/DVI Audio In" port so the sound will play on the TV speakers.
You can find the manual for your TV here:
http://www.sansuiproducts.com/products.html
Hope this helps!
Nov 09, 2013 | Sansui Televison & Video
Cant connect tv to laptop via htmi cable
You need to use the RGB input port on the TV
May 01, 2017 | LG 47LG50 47 in. LCD HDTV
Cable to tv cant find tvs cable port
fisrtly check for a rf connection on your tv. if you cant find it buy a converter rf to a/v, this will help you to input your cable and have a/v out put which you can connect to your tv.
Jan 04, 2010 | Akai LCT3201TD 32 in. LCD Television
Cant get my cable hooked up
check your unit if it is cable tv compatible.then, hook your cable to antenna in.then do the manual tunig/search for channel.if not,you'll need to buy a cable converter ,much better if it has audio/video out.
Mar 29, 2009 | Mitsubishi CS-40503 TV
I just bought a Dynex DX-LCD19-09 19 inch TV. I also have a Phillips home theater system. I have digital cable and I cant figure out how to hook it up to where i can watch regular tv but hear it through...
The only audio out jack on your TV is for the headphone on the left side of the TV. You need to purchase a 3.5 mm to RCA audio cable, connect the 3.5mm jack to the left side of your TV and the 2 RCA audio cable ends to the audio in of your Home Theater and then select AUX 1 or AUX 2 on the home theater depending on which jacks you plugged into.
Mar 09, 2009 | Dynex DX-LCD19-09 19 in. LCD TV
VP-D351 need to connect with TV. What type of cable is required
Make sure your TV is a PAL unit. The easiest place would be to look in the owners manual. If you no longer have it, there should be a PDF format online. It should tell you what cable you need.
Dec 18, 2008 | Samsung Compact MiniDV Digital Camcorder
Home cinema system whafardale to my matsui lcd tv
You need an audio cable as well. It is stupid i went into currys and they said for your home cinema system to work you need a HDMI cable and a audio cable its stupid that they don't come with the system really.
Nov 09, 2008 | Wharfedale DVD-M3 DVD Player
Cant access "Antenna" in tv menu to change to cable
It sounds like you haven't selected cable in the "pull-down" menu. You see, you physically have to tell your tv if you're selecting "over-the-air" programs(free), or cable. Select the cable option &
then run "auto-select". Your tv will go through it's steps & find your cable stations. I hope this helps.
Feb 06, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Durabrand DWT1304 13" TV Logo
151 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
