Question about Kenmore 63942 Dryer
Dryer will not start
We have an older kenmore front load dryer it was working fine took a load out to put another load in and now it will not start. Timer works but none of the fuses we mess with make it start does the dryer its self have a fuse?
  • Anonymous Apr 17, 2009
    Similar problem, Model 76912690 Kenmore gas dryer bought in 97'. Will work for awhile & quit. One time threw breaker. Timer appears to work. We wonder if there is something getting hot that makes it stop.
  • 38 Answers
Based on your description, i would suggest two possibilities. the first....check the door switch
two....check the blower housing sensor (a fuse like component located at the lower rear of the dryer).. it is a small , slim part about an 1 1/4 inches long and about 3/8 ths inches wide. it has a wire connection at both ends.
a quick test for both components mentioned would be to pull the wires off and temporarily connect them together. (be sure to not let them touch anything else). then try to operate the unit.
hope this helps...........................jay
Posted on Apr 16, 2009
I have a Kenmore Elite dryer model #11087872602 that would not start or light up the panel on the front of the dryer. I had a general appliance repair man come out to look at it. He took both computer...
the start switch needs replaced, as far as the front panel light not lighting you will need to open the back top panel of the dryer and find the wiring diagram and trace it out, it may something as simple as the connector is unplugged. Hope this helps Tim
May 03, 2011 | Dryers
When i push the start button i can hear and feel the timer working yet nothing else happens. when i release the start button the timer quits working.door switch is working. i've checked all the connectors...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 06, 2010 | Kenmore Dryers
I have a stackable washer and dryer. Both have worked fine except recently clothes started getting caught between the drum and the front frame of the dryer. My husband pulled it apart checked the screws...
You may have a felt seal in the front that needs replaced. A wire off the pin switch could be off, and you will see the pin switch when you open the door, and make sure it is clicking.
Jun 22, 2010 | Kenmore 63942 Dryer
Kenmore Dryer 70 Series. Push switch in and just a little clicking noise. No motion. Took top & front panel off, belt appears to be fine. Suggestions Please??
set timer push button in for dryer to start dryer did not start, timer is working and door light is on,what could be the problem
Oct 17, 2009 | Kenmore 60172 Electric Commercial Dryer
Kenmore Front loading dryer not working # 666421086718730
The thermal overload fuse is probably bad. It is located under the top of the dryer near or at the drum. Bypass it to see if that is it. Next area to look at is the element. It may have just went out.
Jan 28, 2009 | Kenmore 62602 Electric Dryer
Kenmore 3.5 HE front load washer went haywire, doesn't work now..
Yes - the ECU is to blame, and is a common failure with this unit.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 14, 2009 | Kenmore 43042 Front Load Washer
My Kenmore Elite gas dryer only heats some of the time
Took the bottom front panel off and cleaned the dust from there and cleaned it out real well. An animal had nuts in the vent from out side. Put new hose on and started it up and is working fine.
Thank you anyway. Lynn Miller
Jan 09, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Electric Dryer Model 68731
does the dryer have a gray back panel if it does then take it off the fuse may be bad its a small 1 in in diamiter white with 2 wires going to it replace it if the dryer has a front bottom panel in front then it is in there fuse is bad that is your problem
Aug 18, 2007 | Kenmore 659 Electric Dryer
Kenmore 63942 Dryer Logo
118 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
