Question about Apple Mac mini G4 Desktop
My Power PC G4 1.42 Ghz OS 10.4.11 keeps rejecting disks
I am trying to install software in the disk drive and it's been awhile since any sort of disc was installed. Every time I insert a disk the hard drive makes noises like it's trying to read the disk and then it ejects without reading it. Is there anything I can do to fix this on my own and if so, what? Not that it's necessarily related, but the battery doesn't hold a charge so it's always plugged in.
  • 86 Answers
Open system profiler and check to see if the drive is recognized on the ATA bus. If it is you can attempt to clean it using a cleaning disc designed for this purpose.
If the drive is not recognized, then you will need to take it to a reputable repairer or, get an external drive.
Posted on Apr 16, 2009
My toshiba Satellite C650 . DVD drive will not recogise any bootable disks. works ok on other disks
If the OS installed is newer than your discs, it is probably trying to protect itself. Windows does this sort of thing.
Jan 20, 2014 | Toshiba Satellite Computers & Internet
I bought a LaCie 600GB Big Disk USB 2.0 ( 300990U ) at a garage sale and my Dual 2 Ghz Power PC G5 doesn't seem to recognize it. I am running on OS 10.4.11. The power supply seems to work and I have tried...
Chances are it is formatted in a way that OS X cannot detect. See if you can format it using the Disk Utility and then see if that allows it to mount the drive then...
Mar 27, 2011 | LaCie Big Disk (300990U) (LAC300990U) 600...
My printmaster 2011 gold won't install. what should I do
Installing printmaster 2011 gold on PC.
System Requirements:
Windows XP (Home & Pro) SP3/Windows Vista SP2/Windows 7*
Pentium IV 1.6 GHz or better (2 GHz recommended) or comparable AMD Processor
1 GB RAM available (2 GB RAM or more recommended, 2 GB required for Windows Vista and Windows 7 users)
Available Hard Disk Space: Installation disc requires approximately 2.7 GB; downloadable content can require up to 36 GB of hard drive space
Internet connection required to access content 16 MB Video RAM (64 MB video RAM recommended)
DVD-ROM drive, keyboard and mouse
Monitor resolution:1024 x 768 or higher (1152 x 864 or higher recommended)
QuickTime version 7.5.0 or higher is recommended (Available at www.quicktime.com)
Java version 6 or higher required (available at www.java.com)
Recommended Additional Equipment:
Printer, Digital Camera
Macintosh OS X 10.4.8 or greater* (with the latest Java update)
PowerPC G4 500 MHz or faster (G5, PowerPC or Intel Mac--1 GHz processor or better recommended)
Available Hard Disk Space: Install disc requires approximately 3.0 GB; downloadable content can require up to 36 GB of hard drive space
1 GB RAM (2 GB RAM or more recommended)
8 MB Video RAM (64 MB video RAM recommended)
22 GB (hard disc space)
Monitor resolution 1024 x 768 or higher (1152 x 864 or higher recommended)
QuickTime version 7.5.0 or higher is recommended (available at www.quicktime.com)
*Administrator privileges are required to properly install the program on Windows XP, Windows Vista, Windows 7 and Mac OS X
Do your system meets the above requirement?
Nov 15, 2010 | Broderbund PrintMaster Platinum for PC
I am not able to instal OS in my home PC. Asking me to install scsi drive. my hard disk seagate. where download this flopply disk bios drive software
hi
Checked the Bios Setting and check whether the Hard drive is recognizing or not -
Check the Boot sequence
Check Boot from the CD Drive
Format the Hard drive
it will work
Feb 23, 2010 | Seagate 500GB Maxtor Diamondmax21 SATA2...
I picked up a Powerbook G4 12' Aluminum guesing 1.5 from a local college that was going to trash it, and when I press the power button the start up chime rings and turns straight to a blinking ?/Mac OS...
Get the gray OS discs specific for the PowerBook. Your iBook gray discs won't work. You can also install the OS by getting a black label retail version disc of whatever cat you like- Panther or Tiger. If the software installs, but you hear noises or get the spinning beach ball of death, then the hard drive is fu.k.d up. You then have to open up the computer and install a new hard drive and re-install the OS. Good luck old chap. Cheers.
Dec 31, 2009 | Office Equipment & Supplies
The computer comes on but is frozen on Apple screen
I would try pressing f2 or f8 when first boots up, then change bios settings from first bootup device as cd rom drive, then hard disc as second drive, then place windows disc or recovery disc in pc, then reboot. and reinstall your software.
Oct 01, 2009 | Apple iMac G5 Desktop
DVD/CD disk drive keep rejecting
Sounds like it is not closing properly so the computer just opens it again ? if it is of the detachable type ( small release tag under computer marked with a closed or open lock icon next to release lever ) take out the drive with the door open it possible , check inside for any obstruction ( favorite place for children's random M&Ms ) if none visible check that the disk holder is below the carrige by using a small ruler place acroos the slide and see if the edges of the disc protrude above if not and you have found no foreign bodies in the drive replace the player into the machine .( I have found that occasionaly during manufacture the cariges are set a little high and as they wear they settle and they then catch on the center spindle ,gently easing the disc spindle holder down usually cures the problem .) There is I am afraid also a software glitch that causes this problem so if you have no joy with the first fix try uninstalling the drive from the Device manager and reinstalling on boot up . you do this by clicking on control panel .. then ... Device manager .. disk drives double click and the drives will appear select dvd and right click then uninstall .. for XP just go Control panel system device manager etc : reeboot and the computer will re install the DVD and hopefully clear the glitch .. hope this is of help to you Regards Vortash
May 14, 2009 | Lenovo ThinkPad T61 Notebook
Locked G3
Time to completely erase the hard drive.Start up from your install CD with latest version that will run on this Blue and White.. Don't expect to save any existing files. Just do a complete erase and reinstall via disk utilitly and then your os disc... let me know how it goes..
Mar 14, 2009 | Apple Power Macintosh G3 (Blue and White)...
OS X Leopard
If your computer rejects the Mac OS X Installation DVD, it means that there's a good chance that your Mac doesn't have an Apple internal DVD drive or an Apple SuperDrive, you'll need Mac OS X 10.4 Install CDs.
If your mac is unable to read the CD or ejects it also, there's something wrong with your DVD\CD drive.
You might want to try loading the DVD on a second computer that is connected with a fire wire to the first computer.
Good luck.
Aug 28, 2008 | Apple Mac OS X 10.4 Tiger for Mac
Apple Mac mini G4 Desktop Logo
214 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
