Question about Whirlpool 30" Self-Cleaning Freestanding Gas Range - White-on-White
Circuit breaker 30 or 40 amp
We need to know if we should use a 30 or 40 amp breaker. The model tag is illegible and Whirlpool has not been any help.
  • bpstbd Apr 16, 2009
    This is a combination wall oven. Microwave and oven Model # GMC305PRS/ Whirlpool
  • Anonymous Apr 30, 2009
    after self cleaning my whirlpool oven last night, this morning it wont heat up, althought everything else is still working
    President:
  • 1,865 Answers
Electric range normally takes 50 amp breaker. Are you installing new line for this range? Normal practice is seu aluminum cable #6/ 3 conductor
Posted on Apr 16, 2009
  • buffalonyman
    buffalonyman Apr 16, 2009
    Electrical Requirements
    40AMPS. A four-wire or three-wire, single phase electrical supply is required. A time-delay fuse or circuit breaker and separate circuit is recommended. 60 Hz. 240 V. AC only.
What size circuit breaker is needed for model jckp16gs-1 ge wall oven?
there should be a tag on the unit that says how many amps it draws
Apr 19, 2018 | GE Ovens
I replaced circuit board in whirlpool combo microwave / oven, shows fault code F2, error code E1.
Did you get the circuit board from a trustworthy place?
It is a circuit board error. Did you install it correctly - right wires to right connections?
Control displaying F2 E1:
There may be a problem with the User Interface (Touchpad), or the associated wire connectors.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation
Have to go the long way to bring up the link by first:
e1 f2 whirlpool oven Google Search
and then click on https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwjprvf2_7nJAhXKVRoKHe7zAmMQFggdMAA&url=http%3A%2F%2Fwww.whirlpool.com%2Fproduct-help%2Ferror-code-oven-f2-error-code-f2-e1%2FPH7389%2F&usg=AFQjCNFoDK8E-zgNHF3Kp4EoihGu1tbyEw
Dec 01, 2015 | Whirlpool Ovens
What size circuit breaker for rbs305pr oven?
If you're connected to a 240V source, a two-pole 40 amp circuit is required. If connected to a 208V source, a two pole 30 amp circuit is required.
But the limiting factor here will be the wire size. If installed with #10 copper wire, 30 amp will be maximum. If a #8 copper (or #6 aluminum) 40 amp is maximum. See the link below for details.
http://www.whirlpool.com/digitalassets/GBS307PRB/Dimension%20Guide_EN.pdf
Sep 24, 2015 | Ovens
My electolux superba convection oven is not maintaining it's temperatures?
Heating elements cold be going bad look at them with a flashlight if either of the elements look thinner than the rest of it then it needs replacing before it goes out completely. With aloud bang a bright arc flash and smoke. Very scary. There's a metal tag on the inside of the oven door jam.write the model and serial number down. Shut off the circuit breaker for the stove should be a 50 amp double breaker. Remove 2 small 1/4 inch screws. Slide the element out straight to you. Remove the 2 wires with the same 1/4 inch nut driver keeping the wires separated .Do Not turn on the circuit breaker till the new elements are installed! !! Use the model and serial number to get your new elements first.
Sep 26, 2014 | Ovens
Oven not heating properly
most common problems:
1. calrod unit not working(heating element) easy replacement
2. breaker tripped.(sometimes a double breaker will only trip one of the circuit breakers so you end up with half power)
good luck
Jul 19, 2013 | Whirlpool Ovens
Our RBD275 whirlpool double oven just quit while the oven was preheating. There are no lights in the oven and nothing on the display. The breaker was not tripped. I turned off the breaker for 2 minutes and...
Here is a link to the service manual. look on page 12, troubleshooting. If nothing else works, you need to have the wiring check by a licensed electrician, you oven runs on 220 volts. A defective circuit breaker is my best guess. As you know this requires 2 breakers to operate. If even one breaker is defective the stove will not operate. Often the breakers are paired together with a bar or clip. One can still be tripped, but held in place by the good one.
I hope this helps.
Your review is appreciated. I am an unpaid retired volunteer who provided this answers as a hobby.
Jay
Feb 14, 2018 | Whirlpool Ovens
I have a Whirlpool double oven GMC305PRS01 when you turn on the oven it appears to me making all the right move IE it goes into pre heat and starts counting down but the elements are not getting hot.
Member Discussion on Whirlpool GMC305PRS01 Microwave Oven
Whirlpool Wall oven/microwave combo unit Door message
Does anyone know where the 15 amp fuse is? I replaced the 20amp fuse and it worked for a minute or two and then I opened the door and I blew my circuit breaker. I reset my circuit breaker, replaced the 20 amp fuse and now all I get is the Door message. I also noticed that it fused the outside switch on the right side of the door so I had to open the switch up and un-fuse it. This is for a whirlpool GMC305PRS01 Wall Oven/microwave combo unit.
Also if anyone could tell me the correct position the wire is supposed to be hooked up on the switches? I had someone help me take the switch out and they unhooked the wires and now we aren't sure how they are supposed to be hooked up. My light on the microwave doesn't work either. Is it possible the bulb blew when the fuse blew?
Nov 22, 2010 | Whirlpool GMC305PRS Stainless Steel...
Breaker sizw
In most cases look on the model number tag, the one with the serial number on it and in most cases it will tell you what amperage breaker you should run it off of. It could be a 30 amp 40 amp or 50 amp 220 breaker.
May 13, 2009 | GE Profile JKP56 Electric Double Oven
What is the breaker (amp) requirement for Whirlpool rbs275pdb8?
oven requires a separate, properly grounded four- wire 240 volt, 30 amp service with its own circuit breaker
Apr 29, 2009 | Whirlpool RBS275PD Electric Single Oven
Whirlpool 30" Self-Cleaning Freestanding Gas Range - White-on-White Logo
447 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
