Question about Dell Dimension 4600 PC Desktop
Won't startup(dell desktop 4600)
I tried to press the F11 button, because I wanted to clean the driver (it was running to slow). Now, the computer won't boot. It hangs on a screen that reads "Loading PBR for descriptor 2...done." Any suggestions? Or should I throw this DELL out the window? I live in apartment building
thanks. Kevin
  • 741 Answers
Before you throw it out check out this website that explains what the F11 on Dell is suppose to do (restore your hard drive) and how to fix it if it doesn't work. If that still doesn't work I'll give ya $50 for it...good luck if you have any questions let me know..
http://www.goodells.net/dellrestore/fixes.htm
Pls rate this solution...
Posted on Apr 16, 2009
  • 326 Answers
Attempt to boot the machine in Safe-Mode.
While powering up continuously hit F8.
You will get a Boot Option Menu
Select Safe-Mode boot
If this works for you, you should use MSCONFIG to remove some start up items.
Start > Run > MSCONFIG and then go to the Startup tab and un-check entrys of programs you dont need starting up in the begining.
As far as what was deleted, this could be these simple steps.
Let us know if you run into any bumps
Good luck
My dell studio 1558 won't come on when i press the power button. Although the power led indicator flashes
Remove the battery from the back..wait for 5 minutes..insert is back agian and check.
try F8 at the startup..go to repair my computer then select the lanuage..enter the username and password...you can do startup repair...or try system restore
if the above step is not working
At startup when you see the dell logo press ctrl+F11, this will initialize the system recovery(factory image restore)
If nothing is working contact dell customer support at 877-293-1197.
Aug 31, 2011 | Dell Studio 15 Laptop
I need the restore cd for dell dimension 4600
if your restore partition is still intact, try holding down Crtl+F11 on startup.
This will access the hidden restore partiton.
Alas, if you just replaced the hard drive or reformatted it. You will need the restore disk or the version of windows that is on the COA sticker with the valid windows key.
Mar 18, 2010 | Dell Dimension 4600 PC Desktop
Need to restore hard drive. Will ctl F11 do this?
Please perform the steps mentioned below:
Press the F8 key at startup
Choose "Repair Your Computer"
(see the phony progress bar)
Choose keyboard layout
Enter your user name and password (Admin is disabled if you've created a user)
Choose "Dell factory image restore"
Choose Next
Tick box to reformat and restore to factory condition.
Dec 10, 2009 | Dell Dimension 4600 PC Desktop
System recovery dell dimension 4600
you need to press the
ctrl + F11 as soon as you see the Dell logo screen when you turn on the computer.
the trick is. as soon as you turn on the computer, press and hold on the ctrl key then keep tapping the F11 key.
Sep 30, 2009 | Dell Dimension 4600 PC Desktop
Dimension 4600 won't reset to factory settings
These model dells came with a recovery cd rather than a partition. You will need to call dell and have them send you a recovery cd and then use that disc to restore your computer to factory defaults.
May 27, 2009 | Dell Dimension 4600 PC Desktop
Cannot reformat Dimensions 4600 I tried F11 but it won't let me restart
If you are going to reinstall the operating system on the dimension 4600, while it is on insert the Operating System CD inside the drive then press and hold the power button to turn off system. When you turn it back on press the F12 Key once on the Dell Logo and that will take you to the Boot Menu. Choose the one that says IDE or Onboard CD / DVD Drive then press enter. If it asks you to press any key to boot to the CD then press enter again. Then just follow the normal prompts for reinstalling the operating system.
Apr 05, 2009 | Dell Dimension 4600 PC Desktop
First, if you have any data on the machine you want, I'd back it up to a USB flash/thumb drive.
Then, assuming you purchased the machine new, you should have the maroon/silver "Recovery Disk". Pop that in the CD, and restart the machine. Press F12 to select BOOT OPTIONS. Select CD Hit Enter. This should start the Dell Recovery process. If you do not have the Rec. CD, contact Dell. They should be able to provide you the org. software - for a small fee of course.
gurutim
Mar 21, 2009 | Dell Dimension 4600 PC Desktop
Can't reload XP
Depending on the age of your PC it may have Dell automatic recovery
During startup at the Dell Screen hold down the CTRL key and tap F11 twice
It may display the Dell Recovery from which you can set your computer back to factory settings
Please note all your files will be deleted
Jan 25, 2009 | Dell Dimension 4500 PC Desktop
Factory Restore
Have you tried using another keyboard? if that doesnt work, try hitting the pause/break button on your keyboard and you should notice that your screen will be stuck on the dell logo with the bar going across, once you notice that hold down ctrl and hit f11. that should work..
Let me know what happens, alright?
Aug 18, 2008 | Dell Dimension 4600 PC Desktop
Dell 4600 desktop PC
If you are running Windows XP do a system restore. But BEWARE. You will lose everything you have installed since you started operating.
Jul 08, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600 PC Desktop Logo
331 people viewed this question
Alun Cox
