Question about GE DBXR463GB Gas Dryer
Ge gas dryer runs but does'nt heat
I would like to know where i have to check on the dryer to find out
where the fuse or thermal or whatever the cause might be to the problem
thanks
  • r_soltesz Apr 18, 2009
    I have replaced the ingitor which the tech guy said was the problem. still no heat
    President:
  • 1,865 Answers
Open Front panel and check to see if ignitor is glowing when you start the dryer
Posted on Apr 16, 2009
I have a GE profile Harmony gas dryer model #DPGT750GC1PL. the dryer runs but there is no heat or air coming out of the vent. diagnostics do not indicate anything wrong
see this causes and fix it. God bless you
There's no heat dot_lineone.gif 1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Oct 02, 2012 | GE Profile Harmony DPGT750GC Gas Dryer
Dryer runs but no heat. My husband is pretty smart with appliance fixes. Do you think that this thermal fuse solution would be easier enough for him to fix or should we get a repairman?
The thermal fuse is not going to be the problem...when the thermal fuse has gone out the dryer will not start so since it runs the thermal fuse is good. The number one thing that is wrong with a gas dryer when it doesn't heat is going to be a broken igniter,this tip i wrote explains what to check when a gas dryer doesn't heat http://www.fixya.com/support/r10293028-gas_dryer_not_heating
GENE
Sep 12, 2011 | GE DBXR463GD Gas Dryer
Dryer was not heating replace heating element, how dryer still does not drying looking at wire legend and found two thermal fuses how can i check fuses.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 09, 2010 | GE Dryers
GE drsr483ed1ww dryer runs but does not heat. 220VAC confirmed ok @ dryer. I'd like to test the Thermal Fuse, but there's no rear panel to remove. Any suggestions how to get to them (they appear to be...
heatman101
Sep 02, 2010 | GE DBSR453EBWW Electric Dryer
Dryer heat starts then no heat
Hi, the most common issue will be a set of defective coils but, i suggest that you run through all points and check all the listed check points before replacing the coils.
1. Gas valve coils
igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
2. Thermal fuse
3. igniter
igniter may burn out or break. Replace the igniter if found defective.
Jun 18, 2009 | GE Dryers
MY GE GAS DRYER WILL NOT HEAT UP
check an pop the lil plastic cover on the front of the dryer an then turn the dryer on an see if the igniter glows after 30 secnds if it glows........** you probably have bad coils****if it doesnt then check the thermal fuse for continuity if is not checking ok replace it , that is one of the most common causes,
steps
1 check igniter for glowing
2 check thermal fuse for continuity test
3 if they both check ok an still no heat change the coils
good luck!
May 26, 2009 | Frigidaire GSGQ642A Gas Dryer
GAS DRYER , NO HEAT
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Dec 18, 2008 | GE DBXR463GB Gas Dryer
Runs but no heat
I WOULD LIKE TO KNOW WHERE THE RESET BOTTOM ON A (LG-GAS 7.0 DRYER)
Jul 30, 2008 | LG DLG5932W Gas Dryer
New GE Dryer Not Heating
Heating element
Thermal fuse
Wiring
Jul 25, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
Ge gas dryer
Heating element
Thermal fuse
Wiring
Apr 21, 2008 | GE DBXR463GB Gas Dryer
GE DBXR463GB Gas Dryer Logo
338 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
