Question about Microsoft Xbox 360 Console
I have the error code 0020 on my xbox 360 how can i fix it
    Novelist:
  • 174 Answers
This is overheating and may be signalling a damaged gpu. the solder is lead free and easily warps when the machine produces a lot of heat. you can use a reflow over or possibly heatgun (be careful) and that can help. we can fix this for you if you are in the uk for £40 which includes return delivery to your door. www.fixmyconsole.co.uk
we can also supply you with a guide if you want to fix yourself.
regards
ian
Posted on Apr 16, 2009
  • 3 Answers
Microsoft will fix that for free because they removed the heatsink
  • 135 Answers
SOURCE: xbox 360 0020 error code
Many people have. You need to replace the xclamp and make sure there's extra pressure (less than half a turn) on the front right corner of the GPU. You can read more about xclamp replacement here.
Posted on Jan 06, 2008
SOURCE: error code 0020
jkhgy
Posted on Mar 14, 2008
rylee_smith
  • 8619 Answers
SOURCE: xbox 360
Hi! This error code responds to Hardware failure and possibly the GPU failure(Graphics processing unit). This is also called as 3 rings of death. The issue is heat, and what you need to do is take your system apart, clean off the GPU and motherboard, and put a spacer (like a washer) between the heat sink and the motherboard. This will allow "breathing" and keep the motherboard cooler.
(Remember this will void your warranty if its under warranty)
Or else You can visit the link below-
http://www.jasonwong.net/2007/12/27/xbox360-0020-error-code-fixed-attempt-2/
http://thisisfordevices.blogspot.com/search/label/Microsoft%20Xbox%20360%20Console
Posted on Jan 06, 2009
  • 154 Answers
SOURCE: Xbox 360 has 3ROD w/error code 0020. It used to be 0102
Open your Xbox again, remove the motherboard and take off the heat sinks.
Clean the heat sink compound off of the the CPU, GPU, and both heat sinks using 91% alcohol. The CPU & GPU should be as shiney as a mirror when your finished.
The next step is to apply Artic Silver 5 Thermal compound to both processors using just enough to cover the processors, then put your system back together again and give it a try.
If it still doesn't work you may want to try to find someone who knows how to do a reflow. If you go this route, becareful who you choose. Ask for referrals and most importantly, ask for a picture of the equipment they will use to "attempt" to fix your Xbox.
If you get a picture of a standard Heat Gun... find someone else.
Be aware that even after a reflow, your Xbox is still subject to failure again. Microsoft can't even fix them permanently.
You're already familiar with opening your Xbox and taking it apart so you may want to consider learning how to do a reflow yourself.
There's also the option of buying a new Xbox but there's a good chance you'll still be facing another failure in the future. the difference will be that the new Xbox will be covered under warranty for a period of time depending on the problem.
I've heard that new consoles with a Jasper cpu tend to be more reliable but I've not seen any scientific data to back up this claim.
Good luck, I'm in the same boat with 2 broken and have decided to buy a reflow station to repair my own instead of paying Microsoft.
If you think this information is helpful to you, please take a few minutes to rate this reply.
Posted on Aug 29, 2009
Testimonial: "Thanks, I have everything I need too fix it lol. I just want to sell this one so I can get a better one. Mine is a older release one. Thanks lol."
lonewolf1996
  • 142 Answers
SOURCE: Xbox 360 had 3ROD W/error code 0102 now its 0020
error code 0020 is a overheating error.You need to do the X-clamp fix.That should solve your problem.Did you use the Acrylic silver thermal paste?
Posted on Aug 31, 2009
Testimonial: "thanks =)"
Secondary error code 0020 fix
Some consoles just aren't fixable. It's not common, but does happen. This is why I recommend only having a repair done by an experienced professional.
Dec 30, 2009 | Microsoft Xbox 360 Console
Tip
Xbox 360 RROD E08 / error code 0020
x 360 RROD E08 / error code 0020x 360 RROD E08 / error code 0020x 360 RROD E08 / error code 0020
on Mar 25, 2010 | Microsoft Xbox 360 Console
Aug 31, 2009 | Microsoft Xbox 360 Console
Xbox 360 Error Code 0021
So, you took apart the Xbox 360?
The Xbox 360 has serious cooling problems; compressed air usually does wonders for the Xbox.
You'll "brick" your Xbox tampering with the fan and heat sink; soft mods are always a bad idea if you don't have any recourse for fixing the system.
Hard Mods/Mod Chips are the best way to go because you have dual boot capabilities; you can boot to the original Xbox OS or the Mod Chip firmware.
Currently, Microsoft is being sued for the number of Xbox 360 consoles experiencing the "Red Rings of Death."
Microsoft is making amends by fixing the Xbox 360 at no charge.
Taking the Xbox apart yourself may void your warranty; you might start by uses an Ohm Meter to check the heat sink and fan connections.
Also make sure there is not a gap between the heat sink and the processor; this space should be filled with the thermal compound.
Furthermore, the fan might be damaged and not reporting the fan speed through the variable resistance wire; only way to determine this is by powering the fan with +5v / -5v and checking the variable resistance wire with an Ohm meter.
Mar 08, 2009 | Microsoft Xbox 360 Console
Xbox 360
Jan 06, 2009 | Microsoft Xbox 360 Console
I did the x clamp fix on my 360 now i have error code 0020
error code 0020 is currently unkown, however it is possibly overheating. and 0021 is caused by a timeout on the dvd drive or a GPU error, try re-heating the chips using a blow dryer on low heat for 10-15mins.
Dec 28, 2008 | Microsoft Xbox 360 Console
Xbox 360 error code 0020
Buy a heat gun and follow this tutorial http://forums.xbox-scene.com/index.php?showtopic=651407 You MUST take off heatsinks. I should fix your 0020 problem. -Blayke :)
Dec 16, 2008 | Microsoft Xbox 360 Console
Xbox 360 0020
Basislly you keep your disc drive open for about an hour.
Then you play any game what so ever.
It will say erroe 0020 but leave it for half an hour.
Then turn it on put disc in but should work as usaul
Oct 09, 2008 | Microsoft Xbox 360 Console
Xbox 360... HELP
Send the unit back to Microsoft for warranty repair.
Call 1-800- 4MY XBOX to set it up.
Make sure you remove mod before sending in as to not void warranty.
Hope this helps!
Mar 11, 2008 | Microsoft Xbox 360 Console
Error code 0020
a solution?!ok my suggest is throw away the fuckin' 360 'n buy a PS3.every time i fix that ***** another fuckin code appears.i've had 0102,0001,0020.0133!so the solution is fuckin' the fuckin' Bill Gates 'n all the microsoft./
Jan 05, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
343 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
