Question about LG 24 in. LD-12BW5 Free-standing Dishwasher
Dishwasher LD-14AW2, stopped working mid cycle
The above mentioned model is 3 years old, worded fine so far but stopped in mid cycle without any error codes showing. Turned it off and on again but only a double beep appears, nothing else. Tried other washing cycles, same result. Filter is clean, door shuts correctly (no 'connection' problem here). Water still in the bottom of machine, doesn't pump it out, doesn't start, nothing. Any ideas out there, please?
  • 1 more comment
  • wildman1024 Dec 03, 2007
    Same here. With the addition that LEDs are failing on the display. Went to debug mode with Normal-Eco-Power. First press of go/pause button registers a high/low (5 times?) tone and subsequent presses the double chime. IE not the expected diagnostics
    Hence I suspect PCB failure?
  • Anonymous Mar 15, 2014
    Stopped working mid cycle, display went black and lost power. Turned off power, checked fuses and changed power point cannot find any fault.
  • Anonymous Mar 27, 2014
    drain pump working, no water in bottom of machine but displays error 20 with double beeps repeating.
  • 641 Answers
Since water doesn't drain out ,it could be a clogged in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. Good luck!
Posted on Sep 15, 2007
The solution by Dovi was correct. Cleaned the filters and all debris at the bottom and took the left hand side off and cleaned stuff out of the top of the plastic water/air part. It still did not work, but the pdf file that we downloaded suggested that if the motor had been overloaded then the safety cutout then needed to reset itself. We were disapppointed that this didn't happen immediately but when we tried some 5 or 6 hours later it worked. Saved ourselves $$$$ this time on a plumber's bill!
Posted on Jan 08, 2008
  • sahar
    sahar Nov 10, 2013
    try it . push it up from on side , left or right , a little bit water will go out and all the problem disapear....
SOURCE:
Lg LD-1403w dishwasher stops mid cycle
Most likely the water temperature is not reached as required and the dishwasher times out and stops without draining the water. It is likely the inlet water temperature is not adequate or if only using cold water the thermistor or the water heater are faulty.
Look for part M083 in the diagrams at the back of the service manual attached. you can also perform some diagnostics as shown in there but be very careful about the sequence otherwise you may flood or damage the dishwasher components.
http://www.jordansmanuals.com/ServiceManuals/LG/Dishwasher/LD1416T/LD-1416T%20Service%20Manual.pdf
Aug 06, 2014 | Dishwashers
I hav a lg Dishwasher model # LD-14AW2 the problem
broken door cord. remove side panels and relace. this is a cheap and easy fit. make sure you replace both sides at the same time, you will most likely find it is only one side broken at this stage, but the cords do not last very long.<!-- from fixya rte -->
Jul 07, 2010 | Dishwashers
Model No LD-14AWZ Wash rinse and dry lights flashing. IE flashes on display board.Model no LD-14AWZ
not sure if im on the rite page we have move into a house that has a disherwasher LG Model LD/14AW2 there was no instruction book left at the house cant seem to get it to work even though it looks quite a new dishwasher do anyone know where i could get a instruction book from thanks noelene
Jun 26, 2010 | LG 24 in. LD-12BW5 Free-standing...
Stopped Working Mid-Cycle
blockage in outlet pipe
Chris
Lg durban
031-7165444
Jan 29, 2009 | LG 24 in. LD-12BW5 Free-standing...
LG LD-14AW2 (03 error)
agreed O3 is not a LG error code. OE is more likely and if so it could be the main pcb faulty, a blocked drain pump or a blocked spigot under the sink where the drain hose connects onto.
take care.
May 11, 2008 | LG 24 in. LDF 7811 Built-in Dishwasher
LG Dishwasher Model LD-1403W gets stuck and stops on rinse cycle leaving water in bottom of machine. I have stripped it down and emptied it, made sure filters etc are clean but to no avail
LG Dishwasher LD 1403W. We have cleaned it and when it gets to the heating cycle after running right through to nearly the end, it trips all the electricity and stops everything. Its only 3 years old and hubby thinks its the heating element but between $200=$300 to fix.
Apr 10, 2008 | Dishwashers
LG Dishwasher Model LD-14AW3
I have had this dishwasher about 4 years, it has work beautifully, then one day there just wasn't any power going to it. Have tried different power points and no change. Looked for a fuse, was unable to find one. The power cord coming into the machine is undamaged. Any suggestions.
Mar 28, 2008 | LG 24 in. LDF 7811 Stainless Steel...
LG Dishwasher
according to the manual that i have just downloaded from the net,E1 code means.water leakage in Hose connections.
.water is leaked by damages
hope this helps,
keith
Sep 20, 2007 | Dishwashers
E1 Error Message
agreed all LG d/w with E1 is the wash motor faulty.
take care.
Jan 12, 2007 | LG 24 in. LD-12BW5 Free-standing...
LG 24 in. LD-12BW5 Free-standing Dishwasher Logo
2,745 people viewed this question
Top LG Dishwashers Experts
Marvin
Marvin
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
