Question about NetGear RangeMax WPN824 Router
HTTP dropout issues
I have had my net gear rangemax for the better part of a year now, and for some reason the net has started to drop out regularly. Resetting the router alleviates the problem, but it happens again in about half an hour. Oddly enough, as far as I can tell it only affects the HTTP protocol as MSN messenger is not effected at all, but I am unable to browse the web. All connections are secure, I've tried adjusting the idle time out to no avail and I'm out of ideas. Any suggestions?
  • transistor Sep 16, 2007
    Thanks very much for the reply Benimur,
    I've tried re-configuring the router to a backup file I made a month ago when it was all working. Seemed to work overnight, then it dropped out again.
    There are two machines on the network, one wired and one wireless. Both experience the problem at the same time. There is no problem with the actual network connection, I can access files and the router without any trouble when the net drops out. Ran a scan on both machines, nothing to note. Both machines are running firefox as their browser, tried tinkering with the settings in there but nothing helped. Same problem occurs with IE. Both machines are on a fixed IP now, still nothing.
    Router side, disabled security, tried fixing the DNS adress and turned off extra functionality (extended range and such). Still nothing.
    It *seems* to be an ISP issue, however I have given Bigpond a call in the past, as soon as you mention you're running a home network their technical support guys don't want to touch the problem. Any other suggestions are definitely welcome, but I'm stumped for the minute.
  • mi2u_oe Oct 07, 2008
    Just about once everyday I would not be able to visit any webpages, but MSN messanger still works. After router reset it is ok again. I just got this router 1 week ago...
    Brigadier General:
  • 6,966 Answers
Hi, From initial/apparent indications, it would appear that something was changed in your netgear configuration that affected your internet connection. This would appear likewise to be reinforced that by resetting the router, your back to normal internet connection (though for 'bout 30 mins) and then you'll get disconnected again. Though am not discounting the router error, why don't we try a process of elimination to zero in on the problem. Client side: 1. The usual checks, virus scan? ad scan? any update/upgrade/change of your browser? 2. In your Internet Options/Advanced, try checking Use HTTP 1.1 through proxy connections and in your Connection/LAN Settings, check automatically detect settings; 3. Have you tried Networking Repair, Release, Renew? 4. Does the dropout happen both to wired and wireless clients? 5. Can you try assigning fixed IP add to your client PCs (both wired/wireless) starting from 192.168.0.2 then + 1 to all others thereafter, Subnet Mask is fixed at 255.255.255.0, Default Gateway at 192.168.0.1 (or whatever it is that you have set the NetGear IP add to be), DNS what ever is being used by your ISP. On the router side: a. Was there any firmware update recently? b. Try without any security (WEP, WPA, MAC filter) just to be able to determine if it is related; c. If possible, set router WAN's DNS also to fixed and not auto obtain; Give your provider a call, the problem might be with them. To cite an example, we have 3 local ISPs. One of them has this problem that on certain times of the day, their client would appear to be connected but can not open any site. What I did was to enter the DNS numbers of all 3 providers to the client's PCs though the client is only connected to 1 provider. No more dropout. Am not saying this will work for you merely to give you an idea. Hope this be of some help to you. Post back how things turn up or should you need further information. Good luck and kind regards.
Posted on Sep 15, 2007
  • Louie  Role
    Louie Role Sep 16, 2007
    Hi again,
    Based on the "...Bigpond...home network...don't want to touch..." > run a single machine. Entirely leave the router and the other PC out of the picture. Connect your modem direct to the wired PC. If the problem persist, your ISP has no choice but to provide service. I would suggest though that you be present when they provide the service and for you to take notes of the actions/steps they take to resolve the issue. The purpose is that you may replicate these steps when you configure your router after they have corrected the problem and left.
  • Louie  Role
    P.S.
    Have you tried fiddling with the MTU settings? Most ISP use 1500 but some sites work better with lower say 1490.
    just a thought.
SOURCE:
Lower gas millage related to transmission not dropping down (lowewr revs)?
I would get ride of it
No reason to even discuss all the possible issues
The trans sounds as though it is slipping
Not worth putting any money into,not at the kind of
mileage your putting on
Your better to lease a new one
Jan 03, 2013 | 2004 Honda Accord 2.4
How do I down load the software for the Net Gear Wireless Router WPN824
go here
http://kb.netgear.com/app/products/family/a_id/1299
then click your verison that it states on the bottom of the routher then click downloads
May 12, 2011 | NetGear RangeMax WPN824 Router
I just had an NetGear Wireless "N-150 Router" (WNR1000) sent to Me from Comcast of which all would appear to be hooked-up and running well; to the best of My knowledge. But yet My girlfriends...
If all your gear is working fine then the issue lies with the girlfriend's laptop wi fi chip. I had the same issue and had to return the laptop for another.
Apr 03, 2017 | NetGear WNR1000 RangeMax 150 Wireless...
I have a NetGear WNR834M that keeps dropping the signal. Connecting PC directly to the modem I have no problems maintaining signal.0
I too experience a similar issue with the wireless connection dropping. My wireless devices are within a 20-30 foot distance from the router and all of the devices loose conectivity so I know it's not just a specific device.
My WNR834M is running version 1.4.23NA. The logs file doesn't show anything except for one timestamp the last time it was reinitialized (a forced reboot).
The router's WiFi Channel is set for AUTO and is currectly using Channel 1 (found under Maintenance
Sep 08, 2010 | NetGear RANGEMAX WNR834M Router...
I just revently added a MacBook Pro to my wireless network. All other computers on the network are PC's and it has been working fine for years. Everything works fine until I try to download large update...
To resolve the issue, perform the below task:
1. Open the browser(Internet Explorer or Mozilla Firefox). 2. Access the router (usually http://192.168.1.1 or http://www.routerlogin.com). 3. Click on WAN setup from left menu. 4. Set the MTU to 1400.Click apply.
Hope this allows you to resolve the issue. If you need further assistance then let me know.
Regards
Anand
Jun 24, 2010 | NetGear RangeMax WPN824 Router
Net gear was completely disconnected from computer. net gear WPN82r v 2 was inadvertently reset. dont have a password. any help
To bypass the wizards, connect the router via an Ethernet cable, log in from a DHCP enabled (IP & DNS) computer at
http://www.routerlogin.net/basicsetting.htm
User name is admin and the password is password, both in lower case letters.
Note that wireless connectivity is off by default. When you configure this router manually , remember to turn the wireless connectivity on.
Jul 11, 2009 | NetGear RangeMax WPN824 Wireless Router
Can not install my router
First of all power off the net gear wireless adapter and than try to install the rangemax. if it dosen't work than please check the dhcp range in both the wireless router are the of the same range. than kindly the change the range of dhcp of this new rangemax wireless adapter. you can change this dhcp range my connecting the router to your computer and login by default ip . e.g http://192.168.1.1 and login with userid "admin" and password "admin" than go to lan management option and try the same.
Dec 03, 2008 | NetGear RANGEMAX WNR834M Router...
Net gear router again,
You would do this through the setup of the router. With your computer physically attached, allow the machine to get an IP address via DHCP. This will give you the IP address of the router because by default, it's the default gateway...
So, you drop to a command prompt (start, run, cmd and press Enter)
Type ipconfig and press enter
This will get you your IP address, subnet mask and the default gateway
The default gateway is what you want for this part...
Open up Internet Explorer and type http://192.168.1.1 (replace it with the IP address you found for default gateway)
You will need the password to get in here...
Once in, you can then poke around the settings and turn off DHCP as well as set many other settings.
Save them and allow the router to restart.
You are back in business.
Oct 12, 2008 | NetGear RangeMax WPN824 Wireless Router...
Screen lines on MacBook.
Sounds like dropped pixels.  My first guess is the computer has been dropped on its corner, with the pixel dropout radiating diagonally from the corner.
My saint bernard sat on my g3 lombard, and I have vertical pixel dropout because of it, from the top of the screen to the bottom.
And no, it is not normal for a macbook to have lines across the screen.
Linda h.
Mar 19, 2008 | Apple MacBook PC Notebook
NetGear RangeMax WPN824 Router Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
