Question about HP Compaq Presario V2000 Notebook
Need to amplify incoming internet signal
Weak internet signal, need to amplify
  • 56 Answers
Install a wireless access point at the strongest signal spot you have. This will repeat the signal throughout the rest of the house, or an addition length as necessary. You can purchase a good linksys wireless access point at bestbuy for $83 or cheaper from a trusted ebay dealer. Setup is fairly easy, follow manual.
Posted on Apr 16, 2009
My icom ic v8 is weak on receiving...pls help
Is it week because the incoming signal is coming from further away or is it coming from down the street . Maybe the problem is on the other end,the incoming signal is not strong enough.Lots of reasons.
Jun 04, 2012 | Icom Ic V80 Vhf Handheld Two Way Radio...
The picture looks like it's moving in slow motion...
Ur tv incomming broadcasting tv channels signals are pick up and using are Free over the AIR broadcasting tv channels pick up are by a Antena signal wright?Not signals by a pay cables or satalites tvs incomming broadcasting input signals?Yes?This tv causes are low and weak ranges of a tv Antena incomming recieving broadcasting tv channels signal.Buy a better design Antena like a Digital Antena and used it will solved this problems.Plug it in ur Digital Antena and rescan ur Free over the AIR broadcasting tv channels again.
Aug 15, 2011 | TruTech PVS31170S1W 17 in. LCD Television
There is a message on the screen that says "Weak or no signal".
Tv it is not getting the tv stations broadcasting incomming signals.Make sure the ur pay CABLE or free AIR incomming broadcasting tv stations signal sources are good and than go in ur tv menu go into SETUP pick AIR or CABLE and rescan channels again.U should have no more weak or no signal message anymore.
Jul 31, 2011 | Samsung HL-67A510 67" DLP HDTV
Can not get any digital channels
Digital TVs do require a fairly strong signal in order to operate properly. The fact that your set is displaying the "weak or no signal" message is proof that the incoming signal is below the required signal input level threshold.
A "rabbit ears" type of antenna would only work if you were right next to the broadcast transmitter. I assume that you have the rabbit ears fully extended and that you have tried slowly rotating it from one side to the other to see if you can get a signal lock. But seriously I doubt it.
You should check into either a set-top amplified antenna, or a larger roof or attic mounted antenna. Note: While the larger antenna should provide a much stronger (better) signal, they tend to be directional. You might have to put it on a rotator so that you can "steer" (aim) the antenna toward a particular signal. For most people, this is unrealistic due to the expense and complexity.
My recommendation is to get an amplified omni-directional set-top antenna designed to receive DTV signals
Jun 10, 2011 | Philips 52PFL3603D 52 in. HDTV LCD TV
My TV has a "no
My recommendation is to get an amplified omni-directional set-top antenna designed to receive DTV signals. That should fix your problem.
Also Make sure you select the HDMI input using the remote control, should be a button on there called 'Source' or 'AV' or 'Input'. You may need to press it a number of times before getting to the cable box.
Good luck.
May 27, 2011 | Televison & Video
Eurovox Max V -codes required for basic channels on Chorus Dublin
Then you don't need codes. It won't amplify the signal and if it's weak it won't receive all the channels.
Sep 15, 2009 | StarTech.com StarView SV211K 2-port KVM...
Cannot set up Motorola Surfboard SB5120 modem
This usually means something is not correct with your incoming signal. If your cable wire into the modem is being run off an amplifier in the wall this could be effecting your service. If the signal is too strong the modem won't be able to communicate for internet.
You could check the incoming wire to see if it is running off an amplifier. If it is you would need to run a new line that is not on the amplifier. I would recommend comcast coming out to check the signal frequency and make the necessary adjustments.
May 04, 2009 | Arris SURFboard SB5120 Modem
My psp keeps showing error 80410209 when connecting to the internet
This error means that either the internet signal you are trying to connect to is very weak or not there at all. If you have wifi internet around you it could be that there is a firewall blocking you from using it if it is someone elses wifi and if it is yours your router or modem could be blocking incomming wireless connections. If the second is the problem try restarting your modem or resetting the router to the default setting
Oct 27, 2008 | Video Game Consoles & Games
Proscan PS50700
Appreciate the direct "Ask Me".
Technically, when a TV signal is said to be snowy, it indicates that the incoming RF signal is weak; on the other hand, when a TV signal has static, this refers to electrical noise that goes with the TV signal.
Having said that, then to your concern:
  • for snowy signal, it is the cable providers problem. They have to change where your incoming cable is tapped from, check/replace the feedin cable itself or worst case scenario, replace the line amp/distribution amplifier feeding your cable input;
  • for static noise, what is required is to check possible sources which could include (but not be limited to) electronic ballasts of florescent lamps, electric fans, hair dryers, shavers, wireless phones, computers and others.
Additionally, you may want to check if you have any RF producing devices attached to the TV such as VCRs, DVDs, game consoles. You can try unplugging them when not in use.
Worst case scenario is the tuner block of the TV is getting weak (unlikely but possibly). You can try rewiring the cable to feed first into a VCR, connect the VCR to any of the free Video IN, and select channels through the VCR. If significant improvement, then you have just confirmed an internal fault with the TV tuner, if problem persists, then the static/noise/low RF is caused by something else.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 31, 2008 | Samsung TXE2745 TV
HP Compaq Presario V2000 Notebook Logo
91 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
