Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Craftsman 358.360280 42cc seems to be starving for gas
The saw is 5 years old. When cranked it would seem to be starving for gas and you had to keep it reved up to keep it running and if you let it sit for a while it would crank up and run for a second but if you choked it it would run a little longer. I replaced the gas hoses and filter now it will crank up and run but if you try to run it wide open or idle it will die out. I wonder could I have the gas lines that go to the primer reversed? What would you recommend at this point.
Since i have replaced the "Kit-oil pump" the guide bar oil runs out first than the fuel.
the normal operation should be, guide bar oil and fuel should run out equally.
Posted on May 21, 2009
The saw won't start please help me
Posted on May 20, 2009
I need a replacement switch for a craftsman saw model # 315.11860
Seems to be an old saw and many parts are discontinued
Sear lists it but Switch is not available.
craftsman saw 315 11860 parts Google Search
Dec 15, 2017 | Craftsman Saws
No fuel going to carb
Either you have a air leak fuel inline or at fuel tank or a plugged up carb- sour aged fuel or foreign debris
Jun 12, 2013 | Craftsman Sears Chain Saw Manuals Model...
1988 forn crown vic misfire?
If the cap rotor and plug wires are original, I would look at them first.
Also check the condition of the plugs.
Jul 12, 2012 | 1988 Ford Crown Victoria
I have a 345 e Series 18" (I think it's 18). It's a couple of years old and probably no more than 3-5 total hours usage. Normally starts and runs perfect. Today it won't run, seems to be starving for gas....
If stale fuel has been left in the saw then try draining the tank and re filling with fresh fuel, also hook the fuel line out of the fuel tank and replace the filter on the end.
Apr 15, 2017 | Husqvarna 18" 502cc Prosumer Chain Saw ...
I need help with the hi lo settings. My saw will start buy once it warms up it won't stay running. It seems to by starving for gas.
clean air filter first then adjust low run setting counter clockwise until saw runs smoothly
Sep 20, 2009 | Garden
Help!
on the murry try the batt earth lead and on the push mower if the mower has been tipped up oilcan go into the air filter if the filter is fome wash it out in some fuel to clean dry and put back on engine if mower starts it will take 5 min for oil to burn out of the exhaust muffler allso clean the s plug when tipping a mower allways keep the s plug up words and all will be good
Sep 02, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Sears 10 inch Radial Saw wont run
Try blowing out the motor with compressed air, while rotating the blade by hand. (unplug it first.) Then press really hard on the reset, as sometimes they won't move much at all but will have popped. Use a center punch gently if you have to to push on it. If that doesn't yield results, I'd try spinning the blade by hand a bit and then pulling the start switch to turn the motor on. I once got one to crank up again by doing this, and it continued to work afterwards. (Be careful!) Seems like they are like old starters sometimes that get dead spots in the windings....
I know those are pretty basic ideas, but I have one I've managed to keep running for years as well, and would hate the thought of having to replace it... Also seems to me once I had to remove the cover from the motor and repair a shorted wire inside that was touching metal somehow. And that was only apparent after a similar jam of some sort, as I recall...
Best of luck and encouragement, anyway!
Jul 23, 2009 | Sears Craftsman 7-1/4 in. Circular Saw...
Husqvarna 357 XP Hard starting when warm.
I work for warcks county council, the husky 357xp is our main saw. We've experienced the same problem with many of our new 357's. after many hours of trying to solve the problem (including swapping carbs from old broken saws etc) i stumbled upon, by fluke i'm afraid, a problem with the ngk bpmr7a spark plugs. They seem to work fine for a short period of time (even new out of the box) then leak compression from the cylinder. We are running a esser rated bosh spark plug which seems to have eliminated the problem, (can't remember the number, sorry). We have now ordered champion plugs to replace the stock. Probably worth a try. Hope this is of some help.
Kieran Tursner
Mar 04, 2009 | Husqvarna Chain Saw 20" Bar
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
870 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
