Question about SAMTRON 55V 15" CRT Monitor
Display color has been changed to rainbow
I am using samtron 56V monitor for more than four years now suddenly the display color has been changed to rainbow. But hit the monitor on its top the color changes to normal. so what can i do.
    Sergeant:
    Champion:
  • 293 Answers
Its seems you have a cold solder.
Posted on Sep 15, 2007
SOURCE:
Samtron 56v pc monitor video background with gray vertical lines
How to Tell If A Computer Monitor Is Going Bad
Computer monitors are designed to work properly for years.
Whether it's from a defective part or power surge, they go bad eventually, and you'll probably know it when it happens.
Look for vertical or horizontal lines across your monitor screen that shouldn't be there.
Time how long it takes for your computer monitor to come out of sleep mode. It shouldn't take more than 5 or 10 seconds for the screen to be fully operational when taken out of sleep mode or turned on after being turned off. If the screen is not operating as quickly as it should, it could be a sign it's getting old.
Read more :
How to Tell If Computer Monitor Is Going Bad eHow
Oct 13, 2015 | Samsung SAMTRON 56E/57E/56V
I have a Problem in vga cable of my Samtron 56V Monitor.. Pls tel me how to replace
connect another cable as follows
1-red
2-green
3-blue
4-gnd
5-gnd
6-red gnd
7-green gnd
8-blue gnd
9-+5v from display card
10-stand by
11-synchronus ground
12-sda
13-hsync
14-vsync
15-scl
the numbers of pin are given
under pin
May 20, 2010 | SAMTRON 55V 15" CRT Monitor
Samtron 56v monitor control is locked
hold the menu button for 10-15 seconds.this shld unlock the menu. if the menu window still keeps popping up then u shld change either memory ic or power regulator..
Jul 17, 2009 | SAMTRON 55V 15" CRT Monitor
Samtron 56v monitor
HI all,
The problem im facing is, im using a Samsung samtrong 56V monitor, there is horizontal line appearing in the both ends of the monitor screen which gives a mirroring effect. ( for ex: if ya move the cursor on that it will show multiples of cursors displayed in that line only.)
Please suggest me a method to solve this issue. are there any patch avail for this if so please send a link to download.
thanks a lot
Jan 10, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Display color has been changed to rainbow.
AS hit the monitor on its top the color changes to normal. so what can i do AS IT COMES TO normal position after hitting that cleary indicates that there is no parts failure. 1 there is a loose contact in or near crt base. 2 loose contact in connector. 3 computer to monitor cable loose.
Sep 15, 2007 | SAMTRON 55V 15" CRT Monitor
Monitor color has been changed to yellowish.
There are three Cathod Ray guns responsible for the millions of
colors.All colors are produced by mixing the three basic colors namely
Red Green and Blue (RGB) at suitable proportion. If any one of the
three guns fail firing then we get improper colors.
Try
(1) Simply tap on the monitor and see the result.(Keep the monitor on during this trial.)
(2) Disconnect the Monitor.and Slap it at the back by keeping it on a pillow with the screen facing down - it will resolve the problem if the failure is due to the loosening of the Head due to repeated thermal expansion and contraction.
(3) check the signal cable for loose connection, twisting etc on both ends - at the back of the CPU and Monitor (it is fixed) -
(4)tighten the screws at the backside of the CPU
Best of luck
ProfSweetlin
Sep 14, 2007 | Samtron 76df 17" CRT Monitor
Need solution for the yellow display of my monitor
You can see one ic in right of crt base,plz resolder it (90%sure)
Sep 14, 2007 | SAMTRON 55V 15" CRT Monitor
Samtron 56v
change the 5v regulator 7805 which is the supply for microprocesor
Aug 26, 2007 | SAMTRON 55V 15" CRT Monitor
Monitor screen turned into pink
A defective monitor cable can cause the monitor to turn pink.
May 13, 2007 | SAMTRON 55V 15" CRT Monitor
Samtron Monitor 56v 15''
samtron 56 v problum: switch on the monitor no ON, but two or three times switch on now ON. what is the problum
Sep 06, 2006 | SAMTRON 55V 15" CRT Monitor
SAMTRON 55V 15" CRT Monitor Logo
155 people viewed this question
Top Samtron Computers & Internet Experts
William Miller
William Miller
Ekse
Richard Lilja
Richard Lilja
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
