Question about Acer TravelMate 2500 Notebook
How do i update bios on an acer travelmate 2500 - downloaded bios update onto another pc as i can't install xp due to acpi etc blue screen?
How do i ubdate the bios on an acer travelmate 2500 which i have just downloaded onto another laptop, i can't install xp because of acpi
  • 26 Answers
Http://support.acer-euro.com/drivers/notebook/tm_2000.html
Scroll to the bottom and you will find the download for the update.
P.S. DON'T FORGET TO VOTE!
Posted on Apr 16, 2009
Testimonial: "thank you!!!"
Standby function doesn't work
The stand by button is greyed out when A) your computer is too old to support the
Advanced Control Power Interface (ACPI) or B) ACPI is not configured properly.
Start->Control Panel->System->Hardware tab->Device Manager button. Do any of the
items have a red 'X' or a yellow '!' beside them?
Mar 01, 2010 | Acer TravelMate 2500 Notebook
Dell 8300 not loading xp home with the blue screen of death
To resolve this behavior, contact the manufacturer of your computer to obtain a BIOS that is fully ACPI compliant.
To work around this behavior, manually install the Standard PC hardware abstraction layer (HAL):
  1. Restart the computer to restart Setup.
  2. When Setup starts again, press F7 (not F6) when you see the "Press F6 if you need to install a third-party SCSI or RAID driver" screen.
Windows automatically disables the installation of the ACPI HAL and installs the Standard PC HAL.
Dec 30, 2009 | Dell Dimension 8300 PC Desktop
How to activate blue tooth in acer 240 travel mate lap top
update your driver installer all the mother board of the laptop, if the windows is windows vista download the installer from www.acer.com to get new drivers for blue tooth.
If windows xp is using as well download from acer.com.good luck
Aug 31, 2009 | Acer TravelMate 240 Notebook
ACPI Compliant
Don't worry check out on the net about this motherboard, put that serial number of the mother board on the site and download the BIOS drivers. update that BIOS by DOS prompt , problem will be solved
Jun 15, 2009 | Computers & Internet
Dell Inspiron 1100 Bios and ACPI
Please contact your system vendor for an updated bios. If you are unable to obtain an updated bios or the latest bios supplied by your vendor is not ACPI compliant, you can turn off ACPI mode during text mode setup. To do this, simply press the F7 key when you are prompted to install storage drivers. The system will not notify you that the F7 key was pressed - it will silently disable ACPI and allow you to continue your installation."
RESOLUTION
Manually install the Standard PC hardware abstraction layer (HAL):
1. Reboot the computer to restart Setup.
2. When Setup starts again, press F7 when you see the "Press F6 if you need to install a third-party SCSI or RAID driver" screen.
Windows automatically disables the installation of the ACPI HAL and installs the Standard PC HAL. You should also contact the manufacturer of your computer to obtain a BIOS that is fully ACPI compliant
Mar 16, 2009 | Dell Inspiron 1100 Notebook
I need to disable tha acpi on an acer travelmate 529tx but i don't know how to do it. i am trying to install xp after a failure. i get bsod and says to press f7 when i install storage drivers but i need a...
I have seen on many forums that ACPI makes a lot of troubles to a lot of users under Windows. I will try to explain several things about ACPI and I hope that you will be able to solve your problems after you read this article. I cover only most encountered issues, but always there is a choice even if it's called ACPI disable.:)
The computer ACPI support is detected in the setup stage, but there are less frequent cases when ACPI is not detected and the Standard PC HAL is installed. If you want to force the installation of the ACPI HAL:
1. At the blue screen of the Windows XP setup when it prompts you to press F6 for additional mass storage devices press F5 and you will have a list of options.
2. Choose the proper HAL for your machine remembering that there are also different HALs for multiprocessor machines.
3. Complete the setup, go to Setup / Control Panel / System / Hardware / Device Manager / Computer. If you have listed the Advanced configuration and Power Management (ACPI) the process was completed successfully.
Warning: You can do the same thing if you don't want to install ACPI and your BIOS doesn't support ACPI disable setting. Just choose the Standard Computer HAL from the list of options.
Another method to disable ACPI is:
  • wait for the text-phase of XP setup to complete
  • before XP Setup Wizard to load, boot into DOS and change ACPIEnable = 0 from ACPIEnable = 1 in file c:\txtsetup.sif
The reason why ACPI is not installed on a computer with known ACPI compatibility may be a Microsoft known subtle incompatibility which can lead to hardware instability. In the installation step Windows XP checks the BIOS compatibility with ACPI and the BIOS presence on a known bad list. If the BIOS is there ACPI is not installed. Of course than errors can occur so you can force the ACPI installation (not recommended).
Try disabling it in the BIOS first, this can not be done on a computer with the operating system already installed as it will cause the machine to stop. MUST be done when you initially install the OPERATING SYSTEM.
Regards.
Nov 16, 2008 | Acer Computers & Internet
Windows XP Problem
if you got the OS cd, insert and boot from cd and try a repair.
or check for solutions in the solution range i used to fix similar problem from http://www.tinyurl.com/52mwor
source:
solution dictionary for fixing all pc problems on htpp://www.tinyurl.com/52mwor
http://www.digitalpowering.blogspot.com
Oct 29, 2008 | Microsoft Windows XP Professional for PC
Acer travelmate 2501LMI - bios update
If you have access to the original disks that came with the machine I would suggest trying to use those.
Is the harddrive SATA?
Try installing XP on the hard drive through another Laptop or a USB converter. Then place the drive back in the computer to start windows.
Mar 14, 2008 | Acer TravelMate 2501LMi Notebook
Acer TravelMate 2500 Notebook Logo
572 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
