Question about McCulloch Garden
Return spring keeps on letting loose and doesn't work
I replaced the starter rope now the return spring woks once then it doesn't return thr rope til I take it apart. I have done this numerus times. What Am I doing wrong, I have a Mccollough (sp) ****** Thanks cvmolen
  • 540 Answers
Spring is broken. Sometimes hard to see. Hopefully is is at the end or close where the spring hooks to the housing. All you will have to do in that case is bend the spring and place back in slot. If broken in the middle, you will have to replace spring. Spring may be hard to find but you may find one on ebay or one of the saw forum sites. Just type McCulloch + the model no in google.
Posted on Apr 16, 2009
How do i repair pull string on my yard machine 135202 tiller
remove starter
get new rope
wind spring DONT LET GO UNTIL DONE
feed in new rope , tie knot in rope, replace handle ,tie knot in that end. NOW YOU CAN LET ROPE RETURN IN SLOWLY
May 10, 2014 | Mtd Products Yard Machines 158CC Tiller
Tip
How to fix a recoil rope starter on lawn and garden equipment.
This tip is to help you if your power equipment starter rope broke and needs to be replaced. <br /> Step One: Prepare the equipment to be worked on by disconnecting the spark plug wire from the spark plug. This will prevent accidental startups while working on the engine. <br /> Make sure safety systems are in place. If this is a ride on unit make sure the brake is set and the battery is disconnected. <br /> Step Two: Remove the Starter housing or blower housing. The starter itself will have at least three fastening points and may vary in shape depending on the machine. It is not recommended to remove any rivets if you come across them. Most machines with rivets are part of a larger housing that needs to be removed. <br /> Step Three: Remove the leftover rope and inspect the starter spring. Once off of the machine you can remove any old rope and test the spring. the spring test is to spin or charge the spring as if the rope was being pulled out. As long as tension builds up in the spring you are ready to put a new rope in. If the spring does not build tension order a new spring from a dealer like www.arcolawn.com <br /> Step Four: Charge the spring and install the rope. Charge the spring as mentioned above by rotating it as if the rope was being pulled. Once tight back the spring off one turn and put the rope into the starter through the housing and into the pulley. Tie a knot on either end ot the rope and then slowly let the rope into the starter (make sure the grip is between the two knots). <br /> Step Five: Reinstall the starter housing on the machine and test. <br /> I hope this helps. Joe <img src="barterjoe.png" /><br />
on Feb 21, 2011 | Garden
Installing a spring in an MS240 Stihl chain saw
I have not worked on you type saw. I have put new starter springs in other saws. One end of the spring fits into the housing and the other in the pulley. Once you have that done there should be a notch in the pulley that you put the rope into that will allow the spring to be wound up without taking up the rope. It is a trial error problem now. If the spring is wound too tight you will not get full rope travel. If it is too loose tilt will not pull the rope in fully.
Jun 01, 2013 | nwp Starter Recoil Spring Fits Stihl 024...
How do i essemble a pull starter on a troy built snow thrower
to just put the rope in take starter cover off look inside the cover and turn thr pully to the left counter clock wise turn till it turns no more line up the two hole one from the pully and one on the starter cover where the rope was originaly put the rope in thr hole and tie a knot this is called preload has to have tention on thr pully to pull the string back but if thr spring is broke its another process
Frazier
Nov 01, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Lawn mower troubles
You must first remove the cover assembly which houses the starter pulley. Pull the old rope completely out until it no longer moves. Hold the starter pulley and remove the old rope. Try to wind the starter pulley spring tighter if possible. DON'T LET GO. The starter rewind spring must be wound before installing the new rope. After winding the spring, thread the new rope through the cover and into the hole in the pulley. Tie a good knot in the end and let the rope wind slowly into the housing. Once you have this done, replace the cover, get the proper length of rope, thread it through the handle, tie a knot in this end and your ready to go.
May 19, 2009 | Mtd 22" Yard Machine Push Mower
How to repair broken pull-cord
This usually happens at the most inopportune time. You go out mow the lawn, pull the rope and it comes out in your hand. Here's how to fix it yourself.
First, we'll talk about a simple rope replacement. In most cases you will have to remove the blower housing from the engine to get to the underside of the rewind starter where the rope is. We'll assume at this point that the spring is ok and you can just wind it back up again. You can check the spring by turning on the hub in a counter-clockwise direction and see if the spring gains tension. Do not try to remove the spring from its holder or you may end up having to take the mower in for service.
1. Remove the rope from around the hub. Since there is no tension, it should come right out. If you are lucky and it broke near one end, you can probably just re-use it. If it is badly frayed or too short, you will need to find a replacement at a local hardware store.
2. Attach the handle or tie a knot in one end of the rope so it will not wind all the way into the hub. You also may want to burn the rope ends to keep them from fraying and causing a problem in the future. Set the rope aside where you can grab it once you wind up the spring.
3. Wind the hub in a counter-clockwise direction using your thumb to keep it from unwinding, until the spring is tight. Then let it come back slightly so the rope hole in the starter housing lines up with the rope hole in the hub.
4. Stick the rope through both holes while holding the hub from unwinding. This is tricky because you don't want the hub to unwind on you before you have the rope secured in it. A pair of needle nose pliers or a small screwdriver or pick may help get the rope through.
5. Tie a half hitch knot in the rope after you have it through both holes. While holding the rope, release your hold on the hub and let the rope slowly pull itself back into the starter.
6. Put the blower housing back on and your ready to start the engine & mow.
Kurt
Mar 31, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
Poulan Pro Blower starter string
Pls rate the answer
Kurt
Mar 26, 2009 | Garden
Starter rope on bv2000 weed eater blower needs to be replaced.
Hi, Try the following, But make dure you can wind the spring. If not the spring is broken.
Kurt
Mar 23, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Starter rope has broken but l am unable to re-assemble starter internals to make it work. A parts diagram will help. Can you HELP??? Model : Powerbase generator 500/5000 blue in colour
See if this helps
Kurt
Mar 23, 2009 | Coleman Powermate Powermate 5000W...
Poulan starter rope
to fix starter rope first you must wind spring and place back in housing. just grab spring by middle and wind ,you will have to get it smaller than housing hole. One end should hook to a tab at housing rest of it sets inside itself. once set in housing dont let go, insert rope housing over top & screw in. rope housing should have some return spring to it when pulled. if rope is not tight on return pull simply add one winding to spool. hope it helps!
Feb 14, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Garden Logo
122 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
