Question about Samsung SGH-r225m
Phone not functional
Even with a fully charged battery, I cannot get connected to the phone. I get a message-"the power is switched off". I tried switching power off-on, cleaning the SIM etc. But no improvement
5 Suggested Answers
  • 137 Answers
SOURCE: Battery charging problem
Press *2767*3855# ,it completely reset your phone but most of the functions that doesnt work will work.
Posted on Dec 25, 2007
  • 148 Answers
SOURCE: phone wont switch on
The ribbon cable from keypad to screen is probably damaged (common problem) - get it replaced.
Posted on May 12, 2009
  • 762 Answers
SOURCE: samsung omnia problem trying to charge battery
It looks like battery is damaged... When plugged in to charger phone shouldn't power on. Try put it on charger when on and see if charging icon appear. (top right corner-battery status icon should change -insted of battery to charging.) Battery is fully charged after cca 4 hours, 80% after 2 hours.
Posted on Jul 16, 2009
SOURCE: I'm getting "Update error: 020646" on my payg
here's your answer...
Posted on Mar 09, 2011
Testimonial: "Phil has reported the correct solution to my problem and I have a new Sim Card - thank you very much"
  • 2047 Answers
SOURCE: phone will not switch on battery fully charged.
Usually these problems only occur when the phone is substandard. regardless of you switching the phone off or not this is not a prerequisite to not come on. If you still have warranty on it return it.
Most times when this problem arises in phones it is because the phone was a refurbished one. Refurbished phones are phones which are made up of the scraps from other spoilt similar devices. It usually is a waste to try and fix these devices because you will end up spending more than the cost of replacing the device.
Hope this solution has been helpful?
Posted on Apr 11, 2011
0 characters
1 Points
What is the function of the on/off switch. to save battery or to have on when charging and off when charging at the wall oulet?
On a cell phone it is to extend battery life when the phone is not required. Some phones will still retain some functions eg alarm clock, even when off. You don't need to turn the phone off when charging, but it will charge up faster if you do.
Mar 13, 2015 | Cell Phones
How to restart nokia5310
Hi whats the problem ? you mean your phone could not start up,or it is totally dead ? For nokia 5310 sometimes this problem cause due to im-proper connection of its battery,the connector of the battery gets open frequently,so first check it out Or if the battery fully drains.Put another battery and try,even if there is no effect insert charger.And if the charging is indicated the fault is power key.When charging indicated and your phone doesn't switch on then you need to change the Strip (Pata).Neverthless,contact mobile repairing shop.Thanks for visiting fixya.Good luck
Jun 26, 2012 | Nokia 5310 Cellular Phone
I have a nokia 5230 and the batterey live are not even 24 hours after i have charge it and i dont even have the phone for 10 days yet. Do i Have something connected that should not be connected or are...
If I am made to understand, you have a newq phone, which is not more than 10 days old, and is already developing a battery fault.
Please whenever you purchase any electonic device, ensure to go through the users manual properly. You ougth to charge your battery fully, before using the phone.
This is to give a more durable and stable battery life. As the case is, damage has already bee done to that your phone's battery. Locate a good Nokia store, and purchase a new battery. This time around, ensure to charge it fully before using it.
Also, when charging, do so with a stable supply of power. Also, try to plug it into a DC source, rather than an AC source.
Hope this was helpful?
May 09, 2011 | Nokia Cell Phones
My LG enV VX9900 Cellular Phone is overheated
Definitley your batery had developed reverse polarity and so it will not reain or take in charge. hence the battery will consume more power resulting in this message and it might alsoo be dangerous to keep this on. I would advise you to put in new battery and do the intial charging as required. Keep it on for 8-12 hours of chrage then discharge offf in use fully and rechage again. Repeat this for three time before your battery becomes fully functional. hope this helps. Good day
Jul 22, 2010 | LG Cell Phones
Samsung omnia problem trying to charge battery
Jul 16, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
My nokia 9300 is dead, i received a phone call and while i was talking i got the low battery message and then it went off, i tried to turn it on again, it is dead, the nokia logo appears for few seconds...
1. let the battery fully discharged without connecting to power supply,
2. remove memory card
3. remove battery
4. remove sim card
5. insert the sim card
6. do not insert the memory card
7. reset the battery
8. connect to power for charging for 24 hours
9. switch on and it will work
+91 94350 62943
Jul 13, 2009 | Nokia Cell Phones
Basically my cell phone won't switch on
This is an old problem of Nokia 5310, sometimes, this phone will just automatically switch off. Please try this one:
1. Remove the battery of the phone and leave it for about 2 minutes.
2. Insert the battery and try to turn the phone on.
3. If you will get the same problem, you need to bring it to the authorized Nokia Care Center for firmware upgrade or repair.
NOTE: If the phone is under warranty, it should be free of charge.
Apr 11, 2009 | Nokia 5310 Cellular Phone
W380 goes blank when connecting via usb in files transfer mode
Finally I got it to work. I had to fully charge my battery as I had noticed that when i was trying before the computer was trying to charge the battery. Once I had fully charged the battery and then attatched it to the computer put it into file transfer mode it was really easy. Anyway I hope you have managed to solve your problem.
Nov 20, 2008 | Sony Ericsson W380i Cellular Phone
My Nokia N70 cell phone Screen is white blank
formating your phone may fix the problem
Here’s how to hard reset or format your Nokia N70 mobile phone:
1) Switch off your phone
2) Press and hold these 3 keys together:
-green dial key
-the star key(*)
-the number 3 key (Ugh, I wish I had three hands…!!)
3) Power on the phone
Warning: Do not release the keys until you see a formatting screen and even after the phone has started. Wait until the initial sound starts to play and the hand animation is displayed.
Before formating make sure that your battery is fully charged. Copy all your important contacts, messages, calender, etc in your memory card and your phone should be fully charged window.google_render_ad();
Oct 21, 2008 | Nokia N70 Cellular Phone
Battery charge is finished very soon without even using it( in about 5 hours)
The proper way of charging the battery on your phone is by waiting for your phone to indicate that it's running out of powe but not completelyr, if you frequently charge your phone even if it's not yet necessary(battery life indicator show half-way) the ability of the battery to store power will deminished hence the battery life is shorter. Last resort would be trying another battery unit to test if it's your battery of your phone that's causing the unsual battery drain.
Or you can try the following steps on conserving your phones battery life;
  • Turn off your Infrared and BlueTooth when not in use. Even when they are not in use, they do keep drawing power looking for signals.
  • Switch off the vibration alerts. Vibration causes a lot of power usage thereby making battery drain fast.
  • Re-adjust your screen brightness to around 50%. Screen power is another silent killer.
  • Usually, presetted Backlight durations are of pretty high order, this can be readjusted to get more from your battery. Try reducing the Backlight duration.
  • Often we don’t understand that playing games requires Light, Sounds and Shakes. This in turn leads to tripling of battery drainage.
  • Lower Ringing and other message sounds. This too helps saving a lot of battery.
  • Finally, do charge your battery before it gets drained fully. This enhances battery life.
May 05, 2008 | Sony Ericsson K800i Cellular Phone
Samsung SGH-r225m Logo
47 people viewed this question
Top Samsung Cell Phones Experts
Steven Wander
Steven Wander
Fred Sops
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
