Question about Panasonic Proline AG-DVC7 Mini DV Digital Camcorder
Need of codes....
Hi, Can any one help me in, how to reach the service mode in DV Cameras i.e.(by pressing the trick buttons in camera)
  • 53 Answers
Hi I hope this will help http://www.dvcentral.org/tricks.html Tricks 4 XLR ins: Get the Canon MA-300 adapter and get yourself 4 XLR inputs. Perfect for a couple of wireless lavs, a boom, and another mic. Sure, it's less data for the audio channels, but it's plenty for voice recording. Sure, you can't digitize audio 3&4 easily, but it is possible, and it's just so darn useful to have four audio channels in the field. (Also, you can easily mount the wireless lav receivers right on the back of the camera.) Using the Canon on-camera mic via an XLR input: Say you're using a single boom mic, inputting via XLR 1. You've got XLR 2 doing nothing, and the on-camera mic doing nothing. Seems a waste. Well, all you need to do is adapt the on-camera mic to input through XLR 2. A short female-mini-to-male-XLR adapter will do for the audio signal, but the mic needs power. Simple, just get a short micro-mini extender cable, plug one end on to the mic, and the other into where the mic's connector would normally plug, on the camera's handle. Make sure the mic is switched to stereo, and voila, you have a second XLR mic. Monitoring in the field: Though many people told me it couldn't, the XL H1 downconverts to NTSC on the fly during recording, so you can plug a little monitor or deck into the video and audio out jacks and have yourself a video tap. Perfect for the director who wants to see what's going on through the camera. I used a little DV camera, and recorded it all so we could have a playback tape if needed. Very useful. (Note that the output NTSC is anamorphic, stretching the 16:9 image over the whole 4:3 frame. A monitor with a 16:9 switch is useful, or something that automatically adapts, such as what I used, a Sony PD-100 DVCAM camera.) Native slow motion: In a 24F project, shoot 30F and use Cinema Tools to slow down the footage to 24fps for a slight slow motion effect. Use 1/60 shutter speed for a standard look, or 1/30 for a slightly dreamier feel. Good Luck.
Posted on Sep 15, 2007
6ya staff
SOURCE:
My Camera keeps displaying a message press reset button and when I press it it still does not let me watch or record anything! why is that?
Your camera's mechanical need servicing,its mode selector gear need to clean or replace mechanical,your problem will solve
Jun 16, 2010 | Panasonic NV-GS11B Mini DV Digital...
GR-DF420E my cassette is stuck in the camera and display shows that its gone in safe mode. HELP HELP HELP It doesnt do anything, tried new battery aswell
Hi,, try to put the camera in vcr mode and press rewind button and fast foward alternately until the tape start to move then press eject few time
if its not a big mechanism problem you may be able to ejected if not that will have to be made manually
by removing the cover and look where the tape is hook in the mechanism ;i sugest to you to call a
good technician
hope that will help you.
Apr 08, 2010 | JVC GR-X5 Mini DV Digital Camcorder
Blank screen when in camera mode
Hi.
1. Remove the tape from the camera.
2. Close the tape compartment
3. Set to cam mode
4. Press Menu button
5. Press "enter" on initial
6. Scroll to "demonstration"
7. Press "enter"
8. Press "Menu"
done
May 27, 2009 | Samsung SC-D103 Mini DV Digital Camcorder
I carnt find the button to start recording
  1. set it to "A" position
  2. then when your right hand is holding the camera correctly reach up with your thumb, and press the button.
  3. it looks like a power/charge button
Apr 16, 2009 | JVC GR-D290 Mini DV Digital Camcorder
Stuck in card mode
Hi a small switch ( card or DV) is responsible for this problem. If you can DIY fix the camera with a new flexiboard include the switch and it will work properly
Regards Rob NL
Apr 15, 2009 | Canon Elura 80 Mini DV Digital Camcorder
Need a link for the DV-M5056BLK-VP manual
Turn the Mode switch to capture mode, make sure the video icon is against the red triangle.
Press the Power button for about 1 second to enter video mode, the icon will appear on the upper left corner of the screen
Press ok to start recording
Press ok to stop recording the video
Press Menu for other options
For Photos:
Power On
Turn the Mode switch to capture mode, make sure the capture icon is against the red traingle
Press the OK button to take pictures
Press Menu to enter main menu for options
Feb 28, 2009 | VuPoint DV-M5056-VP Digital Camera
How do i reset my Panasonic nv-gs70
It is on the Right hand side of the camera, just underneath the finger grip. Next to the Auto|Manual Fucus button... about 2 cm to the right.
Hope that helps
Dec 24, 2008 | Panasonic NV-GS70 Mini DV Digital...
Doesn't record
Camera is in safe guard mode want you to remove and replace battery still in safe guard mode
Dec 21, 2007 | JVC GR-D250 Mini DV Digital Camcorder
Can't Get Camera off Standby
may be the rec mode button is set at the anti grounding..usually at sony camera there are 3 switch mode the 5 sec mode, anti grounding and other and always use is the start and stop mode...this switch is located at the side of the camera...
Aug 26, 2007 | Sony Handycam DCR-TRV10 Mini DV Digital...
Record button doesn't function
You may want to check the record lockout safety switch located on the tape. This button can get moved by accident and the camera will refuse to record on that tape. Also, be sure the camera is in "video" mode, not "photo" mode. Some of Canons camcorders have a digital still camera mode which stops the camcorder from functioning because the photos are being recorded to a memory card and not your tape, please check this swithc as well. Good luck. Joe Weibel customelectronics.org
Feb 26, 2007 | Canon Elura 65 Mini DV Digital Camcorder
Panasonic Proline AG-DVC7 Mini DV Digital Camcorder Logo
133 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
