Try this Click on start click on run type services.msc a box will open up with listings Check each of the following to see if they are running LexBce Server- should be set to Automactic Print Spooler- Should be set to Automactic Remote Procedure Call(RPC)- Set to Automactic If any of these items are different- change them by double clicking on the line. A box will open up make changes then click apply. Shut down and restart your computer. Hope this helps you
Try starting your computer up in safe mode by pressing the F8 key on reboot. Then go to control panel, then add and remove programs. Look for your printer software and uninstall. Shut down and restart the computer to see if they load up. Also Lexmarks website has a utiliy to remove all traces of the printer software. Try going therein the other option does not work for you.
Thanks for this but everything was as it should be and still no printers showing. Any other ideas?
