Question about Makita 9553NB 4" Angle Grinder
4 inch grinder with brushes that need to be cleaned. How can I check the brushes inside the grinder and how to repair the brushes myself
  • Corey McConnell
    Corey McConnell May 11, 2010
    What make you believe the brushes need cleaned?
    Sniper:
  • 61 Answers
Brushes ant be repaired. They have to be replaced. unless dirty you can clean them if they are not making contact witht the armature. There should be two round circles near the hand grip with like a coin slot on them. Just srew these of with a screwdriver.
Posted on May 15, 2009
Where can i buy carbon brushes for my craftsman leaf blower 358 799 400
Parts for Craftsman equipment can be obtained at you local Sears store.
Jul 30, 2014 | Dewalt Dw4902 1-inch By 1/4-inch High...
Replacement carbon brushes Ryobi AG402 angle grinder
You can purchase replacement carbon brushes on amazon Amazon com Ryobi carbon brushes. I hope this was helpful. cheers
Jul 12, 2013 | Saws
WHAT ARE THE MOST COMMON PROBLEMS WITH RIDGID GRINDERS?
Most common problems with small grinders in general (all brands) fall into two main catagories. Low power situation and lack of lubrication /debris or maintainance. Electric power tools are used with an extension cord. If too long of cord or improper gauge wire is used, the tool will heat up and burn the brushes, switch or copper winding (lower life of tool). If you feel the tool getting hot either let it cool or check power supply. Tools such as grinders generate lots of dust/debris that enters the tool. Abrasive dust entering tool prevents proper cooling and eats varnish off winding / wears carbon brushs and commutator. Grinders/polishers get packed inside with fluff coming off bonnets preventing cooling. All this overheating prevents grease from properly lubricating gears. Check gearcase for good lubrication and keep inside of the grinder clean. Good luck
Jul 13, 2011 | Ridgid 23983 Grinder 412" Angle
New brushes arc
you could have a problem with the commutator on the armature being cupped. To remove this you would have to use a commutator stone to clean the surface. I would recommend finding a repair shop. Also just a thought do the brushes move freely in the brush holders and are the springs on top pushing them to maintain pressure. Let me know if you need more assistance
Apr 20, 2011 | Bosch 1800 4 1/2" Angle Grinder Cutoff
I need help to replace my brushes on a makita 9553NB 4 inch angle grinder the old model i used to have had easy access.. coin sized slots on the handle that you simply uncsrew to reveal the brushes. my...
first unplug the tool, next on the backside you will notice a screw, remove it and slide the cover back to expose the backside of the motor. gently move the springs that hold the brushes tight to the side and remove the brushes and replace. Make sure to replace the springs and then slide the cover back into place and replace the screw and that should take care of your problem.
Feb 18, 2011 | Makita 9553NB 4" Angle Grinder
Grinder runs about 2 minutes then shuts off. I replaced the heat sensor- no change. What else could be the problem?
check the condition of the brushes, make sure not sticking in the brush tube and also look at the commutator for a really dirty surface.
Dec 21, 2010 | Metabo 01451 We14 150 Quick Electronic 6...
"grinder blocked"
You can try th clean the grinder following the instructions here below
http://www.fixya.com/support/r5572092-saeco_italia_automatic_espresso_coffee
Good luck and thanks for your vode
May 08, 2010 | Starbucks Saeco Italia Digital Barista...
Need brushes and on-off switches for milwaukee 6140-6 hand grinders is this grinder obsolete?
I would need the exact model number and serial number to help but the brush number is 22-18-0710 and there could be a couple different switches. Either give the ser number (the alpha code) or you can go direct to Milwaukeeelectrictool.com and type in the model number 6140 on the page for the breakdown. it might be easier to let me do it. I worked there for 17 years and if you can't get the alpha code look at the switch and I would need a good description of it
Feb 20, 2009 | Milwaukee Tool Factory-Reconditioned...
Makita 9553NB 4" Angle Grinder Logo
439 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
