Question about Kenwood KAC-X1R Car Audio Amplifier
Kenwood kac-x1r flashes code e-03
I have 2 kenwood kac-x1rs> i had one hooked up along with a kenwood kac-x4r and a small alpine amp 4 channel. I tried hooking up the first kac-x1r and it would cause both the other amps to cut off. no power at all. I then figured i wasnt geting enough voltage at the remote turn on wire. so i made a jumper wire from the main power input on the amp to the remote turn on wire. amp then worked perfectly. ran it like that for a day. then the amp would come back on. i removed the jumper wire and no power. i then tried the reset button and nothing. i swapped out that x1r for another, and the other works perfectly. i then replace the first on back in and i get a blinking red light and the display gives e-03 code and then for a brief second i get the voltage display of like 10volts this happens continusly over and over again. did i blow the remote turn on? if so how do i fix it and if not what could be causing this? im running a pair of cerwin vega's 12.4 v-max. the silver cones ones from 2 years ago. also what is the proper way to wire a 2 ohm mono load per amp? i have the subs both wired in correctly, just dont know which speaker connection to use on the amp as the instructions dont cover that.
  • 26 Answers
HI DUDE EVERY REMOTE WIRE THEY HAVE FUSE NEAR THE BACK OF PLAYER TRY TO CHANGE IT .... R...TRY UNPLUG UR AMP .. AND ..FIX IT BACK
Posted on Jun 23, 2009
What amp would be better to use with what speakers/sub? I have a KAC-7202 kenwood 920W maximum power (150wX2 RMS, 4ohms) (230wX2 RMS 2ohms) and then the other amp I have is a Alpine MRP-M500 mono power...
I'm using that Alpine right now for 2-12" subs and I have compared it to 6 or 7 other amps this month and most were 4 channel 150Watt/Channel Bridged to 300Watts x 2 and found the Alpine to be superior in both sound quality and loudness. The Alpine has also not turned off even with full volume for hours at a time, Very solid amp I was very surprised due to it's size!
Apr 04, 2013 | Kenwood Car Audio & Video
Amp is not turning on at all. The capacitor I have hooked up is getting power, it just seems like the amp isn't turning on.
this might sound dumb but check the ground on the amp make sure its getting good connection to the frame
Nov 07, 2010 | Kenwood KAC-X1R Car Audio Amplifier
When I turn up the volume the amp shuts off and displays an E-03
do you have your subs wired down to 1 ohm? The reviews on this amp is not very good, a lot of people said they had a lot of problems with this amp, a lot of blown fuses and cant take a 1 ohm load
May 12, 2010 | Kenwood KAC-X1R Car Audio Amplifier
Blinking E-03
somthing is fried on your motherboard
Apr 28, 2009 | Kenwood Excelon KAC-X811D Car Audio...
Amp promblem
i have a Kenwood KAC-X812D amp and a alpine SWR- 1242D Subwoofer in a sealed box. What is the best setting i should do for this amp. HEADUNIT KDC- X592
Apr 21, 2009 | Car Audio & Video
How too hook my kac 7201 up to my two dual 4 ohm Alpine type Rs
Hello manbearpig65,
Well, that's a 2-channel amp, so it's really best used to power a set of regular speakers.
The best power solution, for your existing components, is to wire each of your subs voice coils in parallel, resulting in a 2 ohm load, and then run each sub off a separate channel from the amp.
The amp is stable only to 4 ohms in bridged mode, so you would series the sub voice coils (8 ohm load) and then parallel them (4 ohm load) to the amp bridged connection. This will result in less power to each sub than if you ran them separately.
Hope this helps.
Apr 10, 2009 | Kenwood KAC-7201 Car Audio Amplifier
My Kenwood KAC-X1R hooked up to (2) Kicker Solobaric L5's
first get a deck with 4 volt pre outputs or more that will help a lot then a battery in the back will help like a 1000cca or more
Dec 30, 2007 | Kenwood KAC-X1R Car Audio Amplifier
Kenwood KAC-X1R Car Audio Amplifier Logo
530 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
