Question about GE Spacemaker JVM1540 Microwave Oven
The microwave is less than 2 years old and no longer heats. It comes on, but does not cook.
    Scholar:
  • 192 Answers
This odd GE last for ever.
Try replaceing the fuse. not everything runs off the same curcit , need hepl replacing contact me DFD
Posted on Apr 16, 2009
Our microwave, a (built in cabinet with venting), will tend to shut itself down if we cook something longer than, say, 8 minutes straight. No power, lights on panel out. Then a few minutes later i
Not enough venting. Imagine putting your hair dryer on full and putting it that cabinet. Would your venting keep it cool? Your microwave oven uses about the same current
Dec 20, 2014 | In Microwave Ovens
Our microwave, a Summit OTR 24 (built in cabinet with venting), will tend to shut itself down if we cook something longer than, say, 8 minutes straight. No power, lights on panel out. Then a few...
Sounds like the electronics overheated. You'd have to pull it and examine the insides to see what has gone bad. It could be pretty much anything.
Why did my whirlpool microwave display quit, everything else works. less than 2 years old
Over the range ovens of all brands are prone to failure of the electronics due to heat and steam from the food that's cooked on the range below them. It's not extremely common, but you do see more of these types of failures on these as opposed to counter top models.
Apr 26, 2014 | Microwave Ovens
My sharp carousel II microwave no longer heats food. Do I need to buy a new one?
The problem maybe the magnetron, or the inverter board if 7 years old or less, and possibly the keypad control board, by the time you add parts and labour cheaper to replace the microwave oven in the long run.
May 07, 2012 | Sharp Carousel R530EST Microwave Oven
Machine goes through the motions but water comes out cold
Hi,you have not stated how old this unit is ? I think they are supposed to last for 4-5 years but I've known some to break after just one year and others that worked great for 15 years or more.
Read more: What is the average life span (during normal use) of a microwave oven? ' Answerbag http://www.answerbag.com/q_view/1540053#ixzz1TQlW7RlH
Carbon Heating Lamp for microwave oven strong heat resistance. More than 6000hrs lifespan.
From a website...
7.3.7 Magnetron Life Expectancy
The typical life of a magnetron tube is approximately 2000 hours of operation. Some factors that can diminish the life of a magnetron are: 1) no-load operation, 2) operating with too much metal in the cooking cavity, 3) line voltage consistently too low or too high, 4) improper phasing, 5) improper installation or removal, 6) replacing associated high-voltage components with substitutes that are incompatible with the system design, 6) continual operation at the upper limit of its heat tolerance due to inadequate air circulation, 7) obstruction in the wave-guide, 8) failed stirrer operation.
We use ours about 15 mins a day which would mean 2000 hours would be reached in 22 years but as they say there are a lot of factors which may reduce its life. The design and parameters of the oven will make a considerable difference. E.G. A highish power magnetron always underrun will last much longer than a smaller one run at its max ratings.
A restaurant might reach 2000 hours in only a year or so and industrial machines whether for cooking food or other processes will require frequent magnetron replacement.
http://www.alibaba.com/product-gs/439406670/Carbon_Heating_Lamp_for_microwave_oven.html
Jul 28, 2011 | AEG Microwave Ovens
Model JVM1850DM4BB purchased August, 2010 buzzes when pressing express cook, does not heat food. Microwave is less than one year old! How do I fix it?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ';';'
Apr 19, 2011 | Microwave Ovens
Microwave runs but does not heat or cook food
If a Goldstar, LG or Zenith MV1610 or MV1608 is running but not seeming to heat a load placed in center of turntable, its probably because the "stirrer" intended to spread microwaves generated by the magnetron around the cook chamber is stuck so that most all the heating is directed toward the back and top rather than the center of the cook chamber. This usually occurs after cooking for longer than a minute with no load in the cook chamber - as when a model w/o a timer (such as a MV1608) is intentionally operated in cook mode to serve as a kitchen timer, or when a model with a timer function (such a MV1610) is accidentally operated for longer than a minute w/o any load. Before assuming the magnetron (usually warranted for 5, 8 or even 10 years) or other high voltage component such as diode or capacitor needs to be replaced, try “cooking” a 16 oz pyrex cup of water at full power on the outer edge of the turntable for 2-3 minutes - which usually reactivates the "stirrer" and restores normal cooking function.
Jan 18, 2010 | LG Microwave Ovens
Microwave cuts off after using for about three minutes and then comes back on in five plus minutes. Does this every time. Now it does not heat at all. It is 4 years old and has been doing this for a year...
you what??? you hate to replace it after 4 years??? stone me!
its worn out girl!, done in!, had it!, claped out!, (sounds a bit like me)
well they dont make am like the did,,,if its been over heating and turning off, for a full year, its dead now, and as there are microwaves on the market for less than £50.00p whats the problem get a cheepy use it till it drops dead then get another one,,, ok?
oh, by the way,, my first microwave i got way back in 1978!!!!! lasted till 2005 it was used every day to cook for 6 children, one unhappy wife, and me? (who is all ways happy now wife has gone?) beet that one?
Oct 21, 2009 | GE Microwave Ovens
Kenmore microware does not heat
It's one or more of the following items -
Fuse
Diode
Capacitor
Transformer
Magnetron
Yes, you can fix the unit, and I can give you direction, but make sure the microwave circuit is not covered under a longer term warranty.
Feb 01, 2009 | Kenmore Microwave Ovens
GE Spacemaker JVM1540 Microwave Oven Logo
230 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
