Question about Garden
Lawnmower starts when primed only then stops - Garden
  • Anonymous May 07, 2009
    lawnmower is hard to start and once started doesn't have enough horsepower to cut or sustain  power when i try to push it.
  • thedonsdank
    thedonsdank Aug 05, 2012
    cnsclark's solution fixed my stalling mower as well! Thank you!
You take the air filter off from carberator (three bolts). There is a bowl with a nut underneath. With socket wrench take bolt off and remove bowl. there are some small holes on the bolt and carberator. Take a twisty tie, like to tie up garbage bags, and run the wire in and out of the small holes. Spray a bit of carb cleaner for good measure.
Put it all back together but don't forget the gasket between the carb and the filter assembly.
Posted on Jul 11, 2009
    Sniper:
  • 109 Answers
Is the engine from Briggs & Stratton or Tecumseh, not the mower...the engine.
With either enging that will only run when primed...in the carb. there is a tube in the middle that draws gas up to the venturi, if this is clogged it will only run when primed try spraying WD-40 in the tube, it should come out in the venturi.
Also, the bolt in the bottom of some engines has a small hole that allows gas into the tube as listed above there is a hole in the top of the bolt and a small one that goes through the bolt they must be clean in order to run
Posted on Apr 16, 2009
The solution provided by cnsclark fixed my problem. Thanks for the help.
Posted on May 02, 2010
3 Suggested Answers
  • 10865 Answers
SOURCE: Lawnmower very difficult to start
Hello. Get a can of starter fluid. A couple of good squirts into the air cleaner and it will take right off for you. J.
Posted on Jul 03, 2010
garing
  • 998 Answers
SOURCE: My 550 series Bolens lawnmower won't start. When
keep pushing the prime button
Posted on Aug 08, 2009
Dynamark 3.5 Model 20211X18A. Looking for manuel, I prime 2 times to start. Engines starts then dies. If I continue to push prime button it will keep running, barely, however, dies as soon as I stop...
Could be 2 things: a restriction in your fuel line/coming out of the tank, or 2: a dirty carburetor needing to be removed, cleaned and possibly rebuilt and reinstalled. Hope it's one of those.Start with pulling the fuel line loose from the carburetor. If you have fuel flowing freely, plug the hose with a golf tee and move onto removing the carburetor. Carb kits are cheap and easy to install. It's best to rebuild while you have it off to avoid similar problems later.
Sep 30, 2013 | Briggs & Stratton Briggs Stratton...
Help, need to start a briggs and stratton 158 mower, and can't. not mine, so not sure of its quirks, also not a lawnmower person, use a brushcutter normally. lawnmower in good condition, got oil and...
after trying to start it a bunch of times, take spark plug out and see if it's wet with gas.
All mowers start with throttle High and with the choke on OR if it has a primer bulb, you have to prime it until you see gas in the bulb
Aug 28, 2013 | Briggs & Stratton Garden
All mowers have a low oil cutoff. Fill oil. 30w.
May 29, 2013 | Garden
Model A173K22 Primer Where?
What? !O_O!
Oh,.....................I was going to say, I don't remember any laptops coming with a priming feature, lol!
In answer to your question there is no priming feature, for an Ariens walk behind gas lawnmower, model A173K22,
Page 9,
http://www.managemylife.com/mmh/owner_manuals/134166/ARIENS-Walk-Behind-Lawnmower-Gas-1011731L
Regards,
joecoolvette
Aug 28, 2012 | Computers & Internet
Starts then stops
a plugged jet inside the carb
Aug 27, 2012 | Briggs & Stratton Briggs Stratton...
I have a new 650 sears craftsman self propelled 22" lawnmower that will not start. I have gone through the prime bulb instructions, still no luck.\r\nAny ideas? Walter in Alberta Canada.
could be the priming bulb gasket between the air-filter assy. and the carb.
I have the same lawnmower and if I prime with gas from a can it will start but stop after a few seconds. When I push the bulb I can hear air leaking in this area. You can replace the gasket by removing the back half of the air-filter assembly. I am looking to buy a gasket today I let you know how it works out! Thanks Ron
Oct 24, 2010 | Craftsman 675 Series 190cc 22" Briggs ...
Jul 03, 2010 | Poulan Pro PR550N22SH 22Inch Briggs ...
My lawnmower will not start. If primed many times, it will burn the gas that is primed, then stop. New plug, air filter, gas, and oil.
You need to remove and clean out the carburettor and depending on the type of carb, renew the diaphragm if there is one in it. Stephen.
May 06, 2010 | Toro Lawn Mower With Toro Power Tools
Aug 08, 2009 | Garden
Garden Logo
11,144 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
