Question about Samsung YP-T8 Digital Media Player
Usb lead hi there any ideas where i can get a USB Data cable from
  • tony strudwick Sep 26, 2007
    thanks ive now managed to get hold of a player and lead from ebay but great to see that someone has helped
Need a usb cable 4 a samsung yp t8 any 1
Posted on Aug 11, 2008
    Problem Solver:
  • 6 Answers
Http://www.samsungparts.com/1/1/82095--usb-cable-ah3900498a.html Double check your manual for your specific version to be certain this is the cable before ordering it. www.samsungparts.com
Posted on Sep 26, 2007
SOURCE:
Need a connecrtion/cable for downloading photos from phone to computer whats it called and which type do i need
Hi
Depending on your phone you will need either a mini - USB cable or micro USB cable. You can find them on eBay. Most likely Micro USB.
Micro USB:
http://www.ebay.com.au/itm/2M-3M-MICRO-USB-Cable-Data-Charger-For-Samsung-GALAXY-S4-HTC-ONE-M7-M8-/400691057892?pt=AU_MobilePhoneAccessories&var&hash=item5d4b0c54e4&_uhb=1
Mini USB:
http://www.ebay.com.au/itm/New-1m-USB-2-0-Male-A-to-B-Mini-5-Pin-Cable-Lead-XC03-/321443971464?pt=AU_CablesConnectors&hash=item4ad78dc188&_uhb=1
Aug 31, 2014 | Cell Phones
Why does my epson R280 Givers me a Communication Error, what does this mean
It normally means that the signal between the printer and computer had been corrupted or interrupted. Check that your USB cable is not damaged, unplugged or even slightly loose. Unplug and re-aligns in both ends. Use a different USB port on your computer if you can.
Keep the USB lead and printer away from unshielded mains or hi-voltage cables as as they can corrupt data signals. Next reinstall the printer driver. If all this fails, try your printer and lead on a friends computer. If it works, look for the problem in your laptop otherwise maybe it's time to buy an Epson wireless multifunction printer.
Aug 16, 2014 | Epson Stylus Photo R280 Series
I getting error 'USB device has malfuntioned and Windows does not recognize it" when I attach my transcend storejet 25 mobile to the computer. I have critical data in it and need somehow to get the...
Hi, most external hard drives come with a seperate power supply, the exception is "pocket" externals which some have the ability to run from the USB socket alone. They have laptop drives in them. Many of these drives come with a USB cable that occupies 2 USB sockets in order to obtain enough ppower to run. (Or a second cable that occupies a second USB with a power plug on the end for a drive. They will often not run on one socket. If your device came with a double USB lead then use this. If it came with an external power supply then use it as well as the USB lead. Try the same on another PC just to confirm the USB sockets on the one you currently use are ok or try a different device to prove correct function.
If all this fails to get your drive running then the drive itself is probably faulty. Is it under guarantee? If so then you can get a replacement. This will lose your data though as the guarantee does not cover stored information. In this situation, is the data more important than the drive? If very important, buy a replacement empty external drive case, remove your drive from the original case (voiding the warranty) and fit the drive in the new case and try again. If it now works you have a dead interface board in the old case, if still not working you have a faulty hard drive. Does the drive click continouously? If it spins then you could try data recovery software or run "HDD regenerator 1.71" on it to fix potentially bad sectors and try again. This is a time consuming process but if the data you need is saved then it is worth it!
I hope this helps
Steve at Olive country Computers.
Feb 20, 2011 | Transcend USA 120GB Storejet 2.5" SATA -...
Hi, every time i connect this to my home computer it turns it off! if i turn the computer on with it already connected it turns it off, have done initial set up on work computer and can access ok from...
sounds like your pc's usb socket has a problem, try the following...
1. Try a different usb port,
2. Using a small light (and possibly a magnifying glass) look inside the usb port on the pc for bent pins or distortion within the socket causing the pins to touch something they shouldn't.
3. check the usb cable for minor damage, try a different cable if you can, different machines use different ways of manufacturing sockets making some more sensitive to a damaged plug than others.
The pc turning off is a safety system which prevents power being sent through data ports. If the pc turns off immediately after inserting the usb cable then that's a sure sign that there is a bad connection/short somewhere between the socket and the cable.
Hope this helps.
Jan 16, 2011 | Verbatim 250GB USB Portable Hard Drive
I am looking for a mini USB lead to connect my JVC camcorder GZ-MG275EK to a JVC share station CU-VD10AG
You can get the USB Data Cable/Cord For JVC DV HD HDV Digital Camcorder on Ebay.com.
Let me know for further assistance.
Thank you for using fixya.
micro-
Dec 12, 2009 | JVC Everio Share Station DVD Burner Burner
Motorola L6i usb data cable software
my motorola l6i cannot connect with my pc through data cable. so pls give me USB Data transfer sotware .................send software on my e-mail [email protected]
Aug 09, 2008 | Motorola Mobility Mobile PhoneTools 3.0...
N95 usb not connecting to pc
I had the same problem with my N95, what I did was try another USB cable, and was able to complete the data transfer and have my phone show up as a usb drive when connected.
Hope this helps!
Jul 17, 2008 | Nokia N95 Cellular Phone
Samsung YP-T8 Digital Media Player Logo
130 people viewed this question
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
