Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Turns over but will not start
1988 sportster.when riding heard a big back fire and then smoke came out of carb. will turn over but will not start at all.just smoke out of carb
  • Harley Morris
    Harley Morris May 11, 2010
    First off you need to check the plugs to see if they are fouled out. Simply replace the plugs with new HD spark plugs. Let me know from there what it does. You should probably also do a compression test and possibly a leak down test as well.
  • 11,896 Answers
Carb needs to be cleaned and adjusted properly
Posted on Apr 15, 2009
After changing the spark plugs, and riding the bike for about10 minutes, I heard a back fire , and the bike started smoking, and gasoline leaking throught the tail pipes.
When you drove it for 10 minutes did it work & run perfect without any missing? One cylinder possibly started missing backfired and then maybe the carb flooded some how. I would pull both plugs first. Have a look at the plugs, then you will be able to tell which one was missing (wet with fuel). Check compression on each cylinder and then check the carb. I hope this helps.
Jul 11, 2015 | 2002 Suzuki VS 800 Intruder
1979 xls sportster. At about 3000 to 3500 bike begins to lose power and back fires. Not sure why. Any suggestions?
It sounds like ignition to me. Most likely coil or stater. I would start with the coil.
Jan 08, 2015 | GAS Motorcycles
Trying to set air / fuel ratio 1977 sportster zenith carb.bike will start run foul plugs black smoke.tried air screw in till die screw out 5 half turns.3 full turns cannt find sweet spot rebuilt zeni
Hi Anonymous, take a ride over to your local dealers service department, I'm sure they will be happy to offer advice and assistance concerning your issue. Have a nice day.
Mar 03, 2013 | Harley Davidson XL 1200 C Sportster Custom...
My 1980 sportster back fires when started but after its running its OK.This just started what could cause this. Thanks JL
By the term "backfire",are you referring to the engine spitting back through the carburetor or popping through the exhaust system? You also didn't tell me what type of carburetor the bike is equipped with. A lot of the owners of early Sportsters didn't like the original carbs and replaced them with aftermarket carbs. Since the carburetors use different starting circuit designs, it makes a difference in how the engine is started. It really makes no difference and I've heard many bikes that do either or both of these things when starting. What does make a difference is how easily it startes and how it runs AFTER it starts. If it's simply a spit or a pop, this is not unusual. Does the bike run the way it's supposed to? If not, that's what we need to look at.
Good Luck
Steve
Sep 09, 2011 | 1979 Harley Davidson XLH 1000 Sportster
My 2000 sportster dies when im riding and only the gage lights and turn signals work..i turn the key off and back on and the bike will start again
sounds to me like is starving it self from fuel
1 check fuel filter
2 check fuel lines for blockages
3 clean carb
good luck
Mar 26, 2011 | Harley Davidson XL 1200 S Sportster Sport...
Specifications , Air/fuel mix for my LS400 88' savage
Is the compression release operating properly? Is it stuck open a bit? Is the head gasket blown? Normal compression is 125psi to 150psi. This sounds like a stuck compression release, blown head gasket or burned valves. A mechanic will need to pull the cylinder head and do a valve job on it if the compression release or gasket is not the problem.
Please rate this answer. Thanks robbman1!
Apr 18, 2009 | 1988 Suzuki LS 650 Savage
FIRE and FUEL........NOT CRANKING !!!!!!!
check your ignition fuses but i think your problem is between your module and ignition switch if you got safty switches on there any one of them can cause that also.
Dec 04, 2008 | 1993 Harley Davidson XLH Sportster 883
Lands Phones Logo
203 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
WTF Chuck.....
WTF Chuck.....
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
