Desktop PC with Windows 98 OS won't boot up.''windows protection
The complete error displayed is ''windows protection error. You need to restart you computer. After PC is rebooted windows doesn't load and it goes into safe mode. In safe mode I can't access the D:drive to load windows from Windows 98 OS cd which is put in D:drive.
IBM PC
  • NitrusInc
    NitrusInc May 11, 2010
    I am assuming that you can't select boot from CD, and boot off the CD and do an in-place upgrade/re-install?
  • 600 Answers
If you reload windows you will lose all of your files...try system restore from the command line in safe mode ...In SAFE MODE>START>RUN type MSCONFIG and enter in the general tab on the bottom there should be LAUNCH SYSTEM RESTORE
Posted on Apr 16, 2009
Hard drive boot failure
what is the error message? If operating system could not find, try you original windows installation CD, during you boot from the CD there is a repair option, follow the wizard to complete.
Sep 03, 2012 | Dell Dimension 2400 PC Desktop
My 2300 don't started. Keep running the windows screen forever..and nothing. What i can do it?
if you are using xp, boot from xp cd and
copy from i386. this file "lsass.exe" to the follewing location and restart
c:/windows/system32
C:\WINDOWS\system32\dllcache (this is hidden file also protected os file)
hope this is usefull
Jan 02, 2011 | Dell Dimension 2300 PC Desktop
My dell inspiron 1525 has a black screen with a white cursor showing
First, I want to know if you sees the Dell logo after turning on the laptop? If yes then this is no boot issue.
1. Immediately run the PSA. Make sure laptop is off. Press and hold down the Fn key, while holding down Fn key press the power button at the same time just once. Once the Dell screen loaded you can now let go of the Fn key. Check if the PSA will run short test for the LCD, RAM and HDD. When full color displays on the screen just press Y. PSA will continue. Just take note of any error code will appear on the screen such as 0141, 0142 and 0146 these are HDD failure errors which means HDD needs replacement. If the test says no errors found then proceed to step 2;
2. Try restarting the laptop once you see dell logo then keep tapping F8. Select last known good configuration. Press enter key. Just wait and check if laptop will load Windows. If not then, restart laptop keep tapping F8 try to select safe mode check if it will load Windows. If not then prepare the Windows OS disc the one came with your laptop.
3. While laptop is on insert the Windows OS disc. Restart the computer. On the Dell screen keep tapping on F12 to show boot menu. In the boot menu select CD/DVD ROM Drive. Press enter then keep tapping on space bar until it will say Windows loading files, please wait.
4. In the User Interface it will show you some options to select. Once the Install screen comes up look on the lower part select Repair Your Computer. If will ask you to do Startup Repair, please do start up repair. If fails try the System Restore. If fails then step 5;
5. If you have important files in your HDD then back up your files first. After backing up of files you can now install the Windows OS. Here is the process in installing the Windows OS. Insert the Windows OS disc, restart the laptop, keep tapping F12 on Dell screen, on boot menu select CD/DVD ROM Drive.Install the Windows OS. Just complete the installation.After the installation install the laptop drivers.
Dec 10, 2009 | Dell Inspiron 1525 Notebook
Error installing windows xp
hi! there,set up exe. that was when your setting up win 98 you have to install that came from floppy disk before you can install win 98.there is an os win 98 in your system you have to delete that previous os before installing another win xp.restart ur computer. press F2 to open your bios set-up . then select bios set-up priority your cd-room drive second,your hard drive. last, quit and save set-up. and then your computer will restart. insert your cd windows xp then reinstall your window xp. delete the previous os then follow the set up on your window xp until you install your new window xp.
Apr 01, 2009 | Compaq Presario S4020WM PC Desktop
Windows protection error
boot it from your recovery disc or a proper bootable OS disk, and try repair mode. if this doesnt work, you will need to reinstall your OS
Mar 18, 2009 | HP Pavilion 6835 PC Desktop
Network Boot
hi,
i have dell c400 laptop, its to much simple to install xp
first you just take out hdd from laptop
plug in tht hdd in desktop pc by external usb box
now u just start windows 98 setup in it
when it started first format ur drive then install it
when windows 98 setup files copies to 100%. machine need to restart
u just plug out the hdd and plug in back to laptop
now the setup will remain start in ur laptop and when the installation complete u just upgrade ur windows from 98 to xp by intalling xp from external drive on OPERATING SYSTEM OF 98 WINDOWS
NOW WAT U SAY???
ITS TO MUCH SIMPLE just try once
Jan 29, 2009 | Dell Latitude C400 Notebook
PC Restarts
i think the memory of your computer have problem that is why it keeps on restarting. kindly get the memory and try it a new one.
Feb 15, 2008 | Compaq Presario 5000 PC Desktop
Windows 98 is not opening
You need to re-install Windows 98, and this time, you should do it on a separate hard disk partition.
Oct 31, 2007 | Computers & Internet
How to install os
This is a little difficult but it can B done :) Firstly I dunno if ya need to re-format ya drive? perhaps first ya could try to "Repair" of Win98? If that doesn't work,then, perhaps ya may have to re-format. If the Win98 is on a SEPARATE drive or Partition this also makes a difference.... Basically ... repair/re-install win98, then do a repair of ya Boot menu for XP, as Win98 sets up an incorrect Boot up for XP, and thus must be "Fixed" so XP will boot & show a Dual boot menu.. here are some links to help you step by step... http://pcworld.about.com/magazine/2109p156id111652.htm http://www.thehindubusinessline.com/ew/2004/08/30/stories/2004083000250400.htm
Aug 21, 2007 | Microsoft Windows 98 for PC
Computers & Internet Logo
David Payne
David Payne
