Question about GE Security Simon 3 Wireless Home Security System
Simon 3 system not communicating with monitoring center. I tried a manual test of the alarm and no siren at all. New battery 1 year ago,monitoring center has no record of power or battery problem. Powered off. Back on. Tried phone test. No signal. What can I try? Thanks Todd
  • info42492 Apr 21, 2009
    Thanks for the response. This is a wireless system that uses radio signals.
    Todd
  • focustrick May 11, 2010
    Did you change your phone service near the time of the problem.  Security systems will always give an initial problem when you switch to vonage or comcast triple play or any sort of digital phone service.  Also if you have dsl, you will need to contact your security provider to install a dsl filter.
  • 80 Answers
Todd, when you trip the system does it seize the phone line. (meaning does it cut off the plone line to your house phones.) if not you have a wiring problem. also security systems are designed to talk to the monitoring stations reciever on standard pots(annalog) phone lines, not on a dsl line with out a dsl filter. not over voip lines,. you may want to see if your monitoring station can connect to your system remotly. any good security company should be able to do this for you. if they cant you may want to look for a new company.
mj
Posted on Sep 01, 2009
  • 78 Answers
SOURCE: i have ge simon 3 which suddenly says phone not
Hi, it is possible that simon panel took power surge threw phone line only. If lightning hit phone line in the neighborhood.
Posted on Sep 09, 2009
SOURCE: How do I turn system beeps off for sirens
My problem started when the electricity went off so now everytime I open the door the siren goes off. I don't have a manual so how can I get this to turn off.
Posted on Dec 28, 2009
  • 74 Answers
SOURCE: After I arm my Simon
When you push the status button after the alarm system has triggered, what message does it give you. That should tell you what is triggering.
Alarmprofessor.com
Posted on Sep 05, 2010
william464
  • 4 Answers
SOURCE: I have a Ge Simon
Wire nuts are ok if the siren is indoors. Gel filled connectors are better if you are mounting the siren outside because they keep the connection from corroding. The resistor needs to go between the two wires you are hooking up. The color of the wires you will are are generally red and black. If your siren has a yellow wire, you can use it instead of the red to get constant siren instead of the "whoop, whoop, whoop" sound that sirens usually make. Putting the resistor at the siren will make sure that it is supervised. That means that if someone cuts the wire going to the siren, it will alert you at the panel. If you put the resistor at the panel, nothing will happen if the wire is cut.
Posted on May 21, 2011
SOURCE: just bought a DSC SD
hook up red and black wires. Red wires to HW1&2 DC Out Terminal. 1 Black wire to HW1 and 1 Black wire to HW2. Resistor 47 Ohm resistor not needed unless siren supervision is turned on as an option. If needed , should go at the speaker, across red and black wires.
Posted on Jun 23, 2011
I have a adt simon 2 alarm system which is no longer monitored by adt. I accidently pressed the phone test button twice and now it continually beeps. How can i cancel the phone test, I've tried...
Get the front cover open by pushing the tab at the top of the panel down while pulling on it. When the cover is down enter the 4 digit master code using the red numbered keys. On the left you will fine a small menu that list different "options". You want to turn "option 1 off." To turn off option 1: Hit the delete key then the option button one time for option one finally push the bigger button in the left bottom corner. I think it's labeled enter or something to that effect. You can listen to the prompting of the panel to know exactly which one to push. After that close the front flap and no more beeping will happen. You will still get the siren in the event of an alarm but trouble conditions and entry exit beeps will be no more. I hope that helps!
Jun 19, 2014 | GE Security Simon 3 Wireless Home Security...
Hi! Just had ADT install security system and it is a Simon XT. Door units, motion sensors and control unit are in house. They also put a motion sensor in garage, which is detached. My understanding is...
My understanding is that GE does not produce a wireless interior siren any longer. So if yo want to get a siren in the garage a wire will have to be run from the Simon 3 to the location in the garage where you would like to place the siren. PS ADT will not run wires to a detached garage. GL
Nov 16, 2010 | GE Security Simon 3 Wireless Home Security...
I replaced the battery on my GE Simon Security System with a new battery yesterday 27 hours ago and still get the low system battery alarm. I upnplugged the transformer disconnected the batterty and...
Did you run sensor test(drop down cover enter you code pess test button then done button. let run 5 min. close cover press status button If that fixes great. If not, you need multi meter. remove battery put metter on leeds coming off panel. You should see voltage there at least equal to the battery. If not then you may see the the red wire for battery has a lump in it about 1" long that is a fuse. remove wire from panel and meter for resistance/continuity/ohms what ever you want to call it. if there is no resistance or an open ckt then replace that wire.if you see resistance in wire then you have a bad panel. GL.
Oct 24, 2010 | GE Security Simon 3 Wireless Home Security...
After I arm my Simon 3,the siren goes off. like the alarm has been tripped and nothing has been opened. What should I try?
Alarmprofessor.com
Sep 01, 2010 | GE Security Simon 3 Wireless Home Security...
How do I change the battery in the GE Simon XT panel?
If your system is monitored call the central station first and tell them you are working on it. Then push down on release tab in top center to fold down the front face. Nest step is to use a small flat blade screw driver to push in and release the tab again in the top center and the unit will fold down towards you, hold on to it and you will see the battery compartment. Follow the red and black wires to the battery. Some units have a plastic lid over the battery that requires you to remove to small phillips screws to remove battery.
Feb 21, 2010 | GE Security Simon 3 Wireless Home Security...
Just installed smart siren kit, worked ok for 1
Harley alarms, while a decent alarm system, are notoriously hard to set up. On a new installation I have sometimes had to run the set-up routine 4-5 times. I hope you have an owner's manual and/or good instructions. Keep trying to set the alarm up from the beginning. If you miss a key or time limit it's not unusual to have the set-up fail and you have to start all over. Disconnecting the battery will screw things up, so be careful.
Oct 02, 2009 | 2002 Harley Davidson FLHTCUI Electra Glide...
Jun 18, 2009 | GE Security Simon 3 Wireless Home Security...
I have ge simon 3 which suddenly says phone not
you may have had a lighting strike to the phone line causing a surg to your unit. it may be fried. try completly powering down the system and powering it back up, then try to send a signal to your monitoring station. also you my have your monitorimg station try and connect to your system and check the programing it may have been scrambled.
mj
Apr 02, 2009 | GE Security Simon 3 Wireless Home Security...
What resistor is required?
If the resistor is used on a detection circuit, any standard 1/4 watt resistor will work fine. The function of such resistors are to be placed at the end of the line (most distant part of the detection circuit) and the purpose is simply to prevent a undetected short path in the line from going undetected. Such a circuit allows for the detection circuit (also called a loop) to activate both on a short or open in the circuit.
BIll
Nov 15, 2008 | GE Security Simon 3 Wireless Home Security...
System Low Battery
Response 1 is correct. If you plugged the transformer into an outlet before connecting the battery the system wont see the battery and give you that error. Should be a simple fix however. Unplug the battery and then the transformer, then reverse the process. Plug in the battery and your Simon should power up, then plug in the transformer. If this doesn't help then you should replace the battery. Did you buy the system from a dealer and have it professionally installed or did you do-it-yourself? If it was professionally installed have your technician come back out to diagnose/replace the battery if needed. Good Luck.
Feb 10, 2008 | GE Security Simon 3 Wireless Home Security...
GE Security Simon 3 Wireless Home Security System Logo
527 people viewed this question
Top GE Home Security Experts
Sean
Jim Goldsmith
Jim Goldsmith
Grantec 2000
Level 1 Expert
Are you a GE Home Security Expert? Answer questions, earn points and help others
