Question about Arris Touchstone 450a (CM450) Modem
How to secure my d-link wireless adapter with my Arris 550a modem
Please provide me specific instructions how to make my Arris Touchstone 550 CM550 model secured using my d-link wireless adapter. Thank you.
  • 32,281 Answers
To make your wireless router secure you need to use your browser and type in the router's IP configuration address.
Then you need to change the default Admin password,
change SSID and turn off SSID broadcast,
setup the encryption (use WAP or WAP2 if your wireless card supports WAP) if not use WEP 128 bit encryption
and for added protection use MAC address filtering.
Posted on Apr 15, 2009
NEED SECURITY CODE FOR WIRLESS ps3 CONNECTING TO XFINITY GATEWAY
If you are connecting to a router(gateway) that has wireless security enabled you will need to enter a security code on your PS3. I wrote a tech article which explains how you can obtain this security code, or if need be, set one up. Click link - How to obtain router security key,password
-G33k
Sep 28, 2011 | Arris Touchstone 450a (CM450) Modem
I need the wep security code for my sons dsi to download games on it from the internet. router name arris model # cm450a
When you did the initial setup for your router, you should have configured the wireless adapter in the router:
* set a SSID -- the "name" of the network
* set an encryption-level -- hint: use 'WPA' or 'WPA2'
* set a password for your network
It's that SSID/password that you need to enter on the DSI, to make a wireless connection to your router.
Apr 21, 2011 | Arris Touchstone 450a (CM450) Modem
I just switched to TimeWarnerCable/Internet. How do I connect two PC's to the Aris TM602G Modem? Then How do I connect my Laptop? Bob
You connect the Aris to a wireless router with say 4 LAN ports.
You connect the PCs with LAN cables to the LAN ports on the wireless router and install a wireless card in the laptop if it does not have one.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
Normal 0 http://www.fixya.com/support/r3559128-wireless_router_security
Oct 18, 2010 | Arris Touchstone 300a (CM300) Modem
How do you find a WEP Key for a Arris Model TM502G
The TM502G is an MTA (Cablemodem with 2-line phone adapter)
it does not have a router wired or wireless therefore there is no WEP Key to find
Sep 29, 2010 | Arris Touchstone 450a (CM450) Modem
Where do I find the WEPkey for Arris TM502G? The question is posted all over the internet, but no real answers.
The WEP key is a encryption key that is configured in the wireless settings of the wireless router. This setting is then applied to the wireless card in the computer so it can connect to the wireless router.
To secure your wireless network from unauthorized access, please click on this link and follow my instrucrions :-
Sep 19, 2010 | Arris Touchstone 450a (CM450) Modem
Need solution to Networking 2 comps thru an Arris tm602g/ct via a linksys 8 port switch, the seems to be no Usb connection on the modem
You will need to purchase a router my friend. The arris does not have a DHCP server built in and cannot assign IP addresses to the work stations. The only way that could work is if you ISP provided you with a second IP address, which would also be extremely unsafe from a security standpoint. Any wireless router should do the trick.
Mar 18, 2009 | Arris Touchstone 450a (CM450) Modem
How do i connect a Linksys wrt54g2 to a arris cm450a
Your modem is capable of linking up to a router. What you do is take an ethernet cable and run it form the internet port on your modem to the internet/wan port on your router. From there you connect your pc's into the LAN ports on the router (typically labeled 1-5) if they are hardwired or you connect wirelessly with your laptop. You need to also power cycle/reset your modem when you plug your router in.
Jan 31, 2009 | Arris Touchstone 450a (CM450) Modem
Unable to connect Linksys wireless router to my arris cm450a
All routers will only work with ethernet. You would need to get an ethernet card installed in your computer. You can probably buy one for about 20.00 at Walmart. If you don't want to do this you can purchase a usb/ethernet adapter and still use the usb port on your computer. You can purchase one of these for around 5.00's on ebay. Just go to ebay and search for usb/ethernet adapter. Please rate if this has helped. Thanks.
Usb drivers for arris rndis adapter
Follow this link and choose your operating sysem and model. You can download from there. If this is what you were looking for PLEASE rate this solution a 4 for fixed ya. Just click on the fourth diamond. Thanks. http://www.arrisi.com/support/usb/index.asp
Mar 29, 2008 | Arris Touchstone 450a (CM450) Modem
Pulse-dialing with Arris modem?
If you have the current firmware for your modem, it should work with pulse. Arris had to make it's MTA's pulse compatible due to old alarm systems that still utilize pulse dialing.
Apr 18, 2007 | Arris Touchstone 450a (CM450) Modem
Arris Touchstone 450a (CM450) Modem Logo
1,290 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
jimmy Leo
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
