Question about Navman Tracker 5500i GPS Receiver
Cannot get my 5500 navman gps to turn on - Navman Tracker 5500i GPS Receiver
  • 6 more comments
  • maxwell18 Apr 18, 2009
    Which is the middle button and the reset button?
    Which button is rest? The word "Navman" is under the screen no button are under that word. The battery is the button at the buttom last one with the circle with a I in the middle?
    I cannot get my Navman 5500 to turn on
    I have already tryed the power button, checked the power cord. That is the whole problem I was requesting help it will not turn on???
    My Navman 5500 will not turn on, any ideas besides it has a hardware problems? I already knew it had problems and would not turn on when I asked for help. What about the internal battery does anybody know anything about it and could that be the problem? How do you remove and replace it and where can you find a replacement?
    My Navman 5500 Tracker will not turn on? Can/o does the internal battery cause this?
  • maxwell18 Apr 19, 2009
    What charger contacts are you talking about? Also the Antena is built in the case. Do you know where I can mail this in order to get fixed?
    Thanks
    Still waiting on the last guy, where can I mail my navman for repair? Also he said check the charger contact points where are they? He said check the antena conection, it is built into the case, how do you check it?
  • 744 Answers
Hi..
You can find the manual here:
http://www.navmanmarine.net/upload/Marine/Internet_Manuals/5430/MN000439A_T5430_EngManual.pdf
from this manual u will get a idea to change ur batteries everything..
thank u
Posted on Apr 19, 2009
  • 19,396 Answers
When the problem is the internal battery the Navman turns on if you connect it to the charger.
If you are telling that it does not turn at all, even if connected to charger then it is not the battery.
You need to grab a Multimeter , set it on volts and check if there is 12V (allow +_0.5V) power on charger contacts.
Try pointing a torchlight near to the screen , and check if there is a dim picture, in that case the back light inverter had gone.
Try also disconnecting antenna. A short in there will cause the Nav not starting.
If there is power , then a common fault that give you no power at all is caused by broken contacts on Navman charger socket.
Instructions on disassembling are difficult to find, service manual for this unit is not available.
I think you have to remove SD card, undo screws at the back, take care of volume control and keys, and operate at top and bottom to separate the to halves of the casing.
There is risk to do more damage, for example to volume control, when undoing the casing.
  • Ginko
    Ginko Apr 19, 2009
    Within US contact +1 (866) 9 NAVMAN. between 10AM - 3PM (CST), Monday thru Friday.
    To locate the nearest service center.
    Outside US refer to Navman website: Navman - Beyond Navigation
    Guru:
  • 846 Answers
This is the Manual for
http://www.navmanmarine.net/upload/Marine/Internet_Manuals/5500_5100/5500_5100_eng_web.pdf
Hope it solved your Problem
Good Day
Posted on Apr 18, 2009
  • 3,037 Answers
First plug it in and then hold down the power button until it turns on. (It should turn on within 20 seconds). If it doesn't, then it sounds like a hardware failure and you should check what you have for a warranty. If you can return it to a store, then do so, otherwise contact the manufacturer about it. I'm sorry that I can't be more help, but the reset only works if the unit will turn on. Let me know if you have any other questions.
Benjamin
  • Benjamin Patri
    Benjamin Patri Apr 18, 2009
    Again like I said, since it won't even turn on, then it must be a hardware fault and requires service that only a qualified electronics repair man can provide. Sorry about that, but there isn't much else you can do.
    Benjamin
    President:
  • 987 Answers
Try to reset..
Hold down the middle button while presing the reset.. keep holding till you see the initial screen...
  • Sibananda Apr 18, 2009
    You
    just have to switch OFF the navman with the button of the battery. Be
    careful, not with the "stand-by button" ON the navman but with the
    switch under the navman, near from the reset.
Navman Tracker 5500
I am having same trouble. I contacted Navman NSW and went through all the settings without result. It was suggested that the problem could be the external antenna, if not a fault in the machine. I have seen an after market antenna for about $19 so I might try that. It does seem as though the antenna is not talking to the Tracker.
Dec 10, 2012 | Navman Tracker 5500i GPS Receiver
I have a navman 5500i tracker ,the zoom isnt coming up far enough to show water depths and hazards by pushing the + - button .is there an easy fix? Thankyou Muzza
Just got the same one and same problem, I also have a 5505i and is only zooms in close when i put in the c-map chip and it zooms close in the chip area only?? now i have a chip for the 5500i and it zoomed in but only on the Texas part of the map, that is the chip it came with, but i live in Canada. Be carefull the c-map max chip for the 5505i is not compatible with the 5500i it needs c-map nt+ chip. 5500 chip is black 5505 is orange
Jan 19, 2010 | Navman Tracker 5500i GPS Receiver
I have navman tracker 5500 gps and the gps signal not working so there is no signel but all the charter is there
I HAVE THE SAME PROBLEM.U WILL FIND THE ANTENNA IS BUGGERED.THERE ARE NO SPARE PARTS AVAILABLE FOR THIS MODEL.LESSON; DON'T BUY NAVMAN OR NORTHSTAR.I HAVE ONE OF EACH. NEVER AGAIN!!!
Nov 17, 2009 | Navman Tracker 5500i GPS Receiver
I have a navman 5500,I can hardly see the screen on a sunny day
the problem is that the controlling diode that checks LUX value is damaged (small clear window of minute proportion that adjusts screen brightness)
Jun 29, 2009 | Navman Tracker 5500i GPS Receiver
Navman 5500 gps backlight dim but set to max
Its water ingress causing a short in the high voltage wiring PCB.
Open the unit with a 1.5mm allen key, unscrew the power/data cable sockets with a spanner and GPS antenna inlet with an 8mm socket (NA to i models) .
Where water has arced there will be burning black on the green PCB evident, cut the PCB wire and remove the section around the burn.
solder a new wire to bypass the short.
Dry the unit and seal with silicone to prevent re occurrence.
Its a 2 hour repair requiring a high DIY soldering standard but off set it against the time it will take to reload you waypoints in a new plotter , its well worth the trouble.
DAKA
May 27, 2009 | Navman Tracker 5500i GPS Receiver
Navman Tracker 5500 Marine Chartplotter
Yes the screen is replaceable, there are four screws holding it to the PCB and a short ribon and a two wire power lead.
Aug 11, 2008 | Navman Tracker 5500i GPS Receiver
Navman 5500 tracker
Navman 5500 does not support C-MAP MAX maps.. only C-MAP NT+ maps.
Apr 24, 2008 | Navman Tracker 5500i GPS Receiver
I the lost manual
Hi....
I have gone through your problem.Follow this link.
Hope you are searching for the same.
Mar 30, 2008 | Navman Tracker 5500i GPS Receiver
Navman Tracker 5500 turns on but locks itself in the entry page
Have the same problem??
Used to take less than a minute to acquire satellites now takes 10-20minutes.
Nov 08, 2007 | Navman Tracker 5500i GPS Receiver
Navman Tracker 5500i GPS Receiver Logo
281 people viewed this question
Top Navman GPS Experts
Neil Gossage
Level 1 Expert
Are you a Navman GPS Expert? Answer questions, earn points and help others
