Question about Amana ABB1927DE Bottom Freezer Refrigerator
Refrigerator doesn't start
Lights are on, but I need to flick switch several times to get it started. Then it runs for only 30 seconds and shuts off.
  • wha452 Apr 16, 2009
    I don't recall a click when I flick the switch, which is on top of frige section. both show dashed line first, thern the cooling number comes on, then after flicking at least 2-3 times, the compressor starts up. After 30 seconds, is all shuts off again. Lights are on in frige the whole time. I have tried unplugging for 30 minutes to reset with same results.
  • wha452 Apr 18, 2009
    Thanks for all your help and advice. I decided to play it safe and called a local service repair place. They came today, and confirmed the control board is shot. Total cost, including service call is going to be under $200. Too bad, the unit is around 4 years old. Maytag Co just ain't what it used to be
  • Amana Master
  • 4,654 Answers
If a click is coming from the compressor area when you flick the switch, sounds like the compressor start relay or the start capacitor. Let me know if the model and make is correct above your post, so I can examine the refrigerators diagram. That way we will be on the same refrigerator. Thanks, Sea Breeze
Posted on Apr 15, 2009
  • 1 more comment
  • John Tripp
    John Tripp Apr 16, 2009
    That is a control board inside the cold food section.
    Part # AP4366538
    Go to this site blue link above refrigerator like your model click on blue line just above refrigerator like your model, that will take you to all parts for your refrigerator. I believe the control board is bad, so if you unplug refrigerator and remove plastic cover look for burn marks on the board. (part number AP4366538 or other site enter model or part number. Same thing just no picture.That is where you find all picture of what I am talking about. Thanks, Sea Breeze
    http://appliancepartsse.blogspot.com/ Pt# AP4366538
    http://servicepartstec.blogspot.com/ Pt# 12868513
  • John Tripp
    John Tripp Apr 17, 2009
    Were we able to find the problem? If not, please let me know, Thank You., Sea Breeze
  • John Tripp
    John Tripp Apr 18, 2009
    Thank You, for letting me know. Good to know you have it running. And thanks for the vote! Oh, it's not Maytag, its those dang control boards. Good when they work and expensive when they don't.
    Sea Breeze
Our air jet tub will turn on with the button ok but it only runs for about 30-40 seconds then shuts off any suggestions
the switch that the air button works is not flicking over to stay in the on position
replace the switch at the end of the air line
May 10, 2017 | Pool & Spa
Temperature light flicking and the freezer defrost when light is flicking
Thermostat sound like it's faulty and not regulating properly
Sep 28, 2016 | Refrigerators
My compressor start but runs for 30 second then turn off
First check if condenser motor is running, secondary check if condenser coils are clean. If its commercial refrigerator it might have Low pressure switch and High pressure, if pressure of freon is to low on suction side it will shut power to compressor, same with high pressure switch - but thats commercial refrigeration. If it residential fridge and coils clean and fan is on - try to install 3n1 hard start kit, here is my video that might help You.
Nov 17, 2015 | Refrigerators
I have a Samsung rs21!!! it wont cool in either compartment. when I plug it in the compressor fan does a quarter turn then stops. the compressor runs for about 30 seconds then cuts out? any ideas plea
most likely the start relay on the compressor that changes from start windings to run windings. the compressor will run for about 30 seconds on start windings then click out on internal thermal overload.
this can be confirmed by turning it on and letting it do the 30 second run then when it stops just wait and see if it cuts in and tries to run again (usually takes about 5 min) the second time it cuts in it wil most likely not run for as long (usually about 10 seconds). if this is what it does get a new compressor start/run relay.
as for the fan flick it with your finger and see if it spins freely.
Jun 05, 2014 | Samsung RSA1SHPN American Platinum Inox...
Resetting the passlock
1. First, insert the ignition key and turn the ignition switch to the "On" position (Do not start the engine). Leave the switch on for 11 minutes. The security light may flash or be on steady during this 11 minute period. Make sure the light is no longer on or flashing before proceeding to #2 .
2. Turn the ignition switch off for 30 seconds.
3. Turn the ignition switch to the "On" position (as in step #1) for 11 minutes again.
4. Turn the ignition switch off for another 30 seconds.
5. Turn the ignition switch to the "On" position for 11 minutes a third time.
6. Turn the ignition switch off for 30 seconds one final time.
7. Turn the ignition switch to the "On" position one final time and wait 30 seconds.
8. Attempt to start the engine. If the engine starts and runs normally, the relearn is complete. If the engine does not start, Go to this link for info
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Sep 08, 2012 | 2000 GMC Yukon Denali
Gateway gt4016 wont turn on you can hear the fan and light flicks on for a second but then nothing changed the power supply nothing
try rebooting your coumpter is in sleep mode it takes a long time but you will get it back on .... keep pushing the power button aventally it will start up
Jun 30, 2012 | Gateway GT4016 Desktop PC
Refrigerator wont run. Clicking noise coming from main board preceded by a short humming noise every several seconds. Unplug for 30 minutes then plug back in and compressor starts up after several clicks...
That condenser fan motor needs to be replaced. You and doing the right thing as far as using a seperate fan to keep compressor cool,buy replacing the fan the compressor will run cooler and click off by being too hot as you have heard/seen.
Find your model number and call your local appliance parts store and see if they have a CONDERSER FAN MOTOR in stock
Gene
Aug 15, 2011 | Refrigerators
Walk in cooler cycleing
It has lost some freon and is not charged correctly...the unit is pumping down and shutting off on low pressure and then after being off a bit the pressure comes up and it restarts...
Need to check the charge and top it off and you will be good to go..
heatman101
May 28, 2010 | Nor-Lake Norlake Refrigeration 4' x 6'...
How do I initiate defrost in a Maytag tri-door
Try this open the freezer door and flick the light switch 6 times, like flick, ----- flick,----- flick. If 6 does not work try 8, cant remember.
Aug 22, 2009 | Maytag MFI2067AES Stainless Steel Bottom...
Ice maker does not work. Has worked fine until about a week ago
Mine has done this several times. There is a switch, usually in the tray above the ice container at the back. Move the switch to the OFF position for about 30 seconds. Now, turn the switch ON and push it hard in the ON position for about 30 seconds. This will 'jump start' your icemaker going again and you shouldn't have any more problems.
Mar 30, 2009 | Refrigerators
Amana ABB1927DE Bottom Freezer Refrigerator Logo
292 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
