Object bumped screen and left small hole
An object hit my Samsung monitor screen and left a hole(it's small, but visible.) Is there any way to fix this without replacing my monitor?
    President:
  • 814 Answers
Sorry no hope, unless you can still see the picture in the damage spot. If the details are still there you can search the net for LCD Scratch repair and try resurfacing the screen. Hope this helps you !
Posted on Apr 16, 2009
How to get back to settings on frozen samsung tablet
Tablet should have a "reset" button on top or side. Small hole. You need an object that would fit--it will take it back to factory specs. Make sure tablet is fully charged--or plugged in first. Worked for me.
Sep 06, 2014 | Samsung Tablets & eReaders
46 " LCD....object hit screen
YES THE SCREEN CAN VERY WELL BE CHANGED.
May 15, 2011 | Samsung Televison & Video
I was given a used 31cc trimmer but can't get the spool off to replace it. how do i do this?
A typical trimmer has a small bump knob, an inner spool with the plastic string wound on it and the housing for that which is the string head.To remove the small bump knob, hold string head firmly and turn the bump knob counterclockwise. To remove the head entirely, first remove the bump knob. Next, remove the inner spool with string. What should be left is the spring with the end of the gear shaft showing. Some heads are locked on and some just slip over the end of the shaft. Check the gear drive just above the string head for any holes in the collar. An object can be placed in one of the holes to lock the drive and twist the head off.Ryobi's use retaining clips on the shaft which have to be removed.
May 06, 2011 | Garden
I have samsung lcd LN52A550P3FXZA There is 1 blacks vertical lines on the screen i thinking to replace the LCD Controlleror Buffer Upper left
If this tv LCD screen panel have not cause by any person or object truma to LCD screen panel. This problems it is alway the causes of the T-Con decoders board sit in the middle bottom of the LCD screen panel.If it is causes by a person or an object causes truma to it,this LCD screen panel is radiations are dead for that area,this LCD screen panel can't be fixed.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-Con decoders board for the replacement.
Feb 17, 2011 | Samsung LN52A530 LCD TV
My samsung YP-U2 don't work
Hi
Try and reset the player by inserting a pointed object inside the small hole, press and hold for 5-10 seconds to let the player reset. If this doesn't work then connect the player with the computer and let it charge for a while. Now go to control panel-> administrative tools-> computer management/system management-> storage, check if you are able to see the mp3 player here. If it is visible then try a reset and try again. If not then reset the player while it is connected with the system. This will resolve your issue.
Hope this helps...
Daniel
Sep 18, 2010 | Samsung YP-U2 MP3 Player
My tv is damaged and i want o fix it
Cannot fix it yourself, the very sensitive connection area on top of the screen is damaged. Unfortunately this requires a whole new panel, it will be cheaper to get a new tv.
Jun 19, 2009 | Vizio GV47LF Television
RCA 52" HDTV Rear Projection TV MM52110JX1
Replace FL231 400ma fuse. this will fix your problem.
Oct 26, 2007 | RCA D52W19 52" Rear Projection Television
Problem with opening monitor cover
to remove the back cover of samtron 56 v monitor is very simple.
locate the 2 bottom screws of the cover, remove them. pull slightly back the cover holding the bottom and about half an inch gap will be seen. insert a flat screw driver straight down through the upper side hole with your left hand and hit the head of the screw driver with your right hand. a slightly big sound is heard and that side is disengaed. repeat he same with the second hole. and you have done it. try.
Oct 10, 2007 | SAMTRON 55V 15" CRT Monitor
Computers & Internet Logo
149 people viewed this question
David Payne
David Payne
