Question about Video Cameras
My camcorder has no sound VM-L153
My camcorder has no sound. When I record something, I cannot hear the sound. This is when I play it back through the recorder or adapter.
5 Suggested Answers
SOURCE: quasar camcorder model# vm-d52
your pause . . . button . . . has come loose from the tiny switch that actually controls pause ; the remote ( it has a battery ) can activate pause , directly from your control chip and is cheaper than the repair ;
Posted on Jul 29, 2007
SOURCE: Owners Manual for a Quasar VM-L153 camcorder
Posted on Oct 18, 2007
  • 3 Answers
SOURCE: canon dvd camcorder dc220 recorded dvd play laptop for vista
I have Vista. I used a free download "DVD Decrypter" and it converted the files. I then just used Window's Media to view them.
Posted on Nov 19, 2008
SOURCE: I purchased a Panasonic SDR-H40P/PC
Good Cam
Posted on Dec 21, 2008
  • 10594 Answers
SOURCE: Sony Handycam Vision videoHi8 will record sound, but no picture.
It is known problem of bad ccd imager in camcorder and requires replacement of that part.
Sony will repair CCD-TRV318 Free of Cost in ccd imager problem.
Please click Sony CCD Imager Support for details.
Good luck.
Posted on Feb 22, 2009
0 characters
1 Points
No images but records sound
To start ensure that you removed the cover from the lens.
Also remove battery and put it back in place to reset the camcorder.
If you get only sound on playback, connect the camera to a computer or TV, or play the tape on a different camera. If you get picture in there, then the camcorder is recording, but the video playback does not work because of a faulty LCD display.
If when you play back the movie on a different camera, or using the compute you still get no picture then the camcorder is faulty.
Faults that can cause black screen can be:
Lens problem. Faulty CCD sensor. Faulty controller board.
All this faults are not easy to diagnose and fix, if there is a fault , then it is better to take the camera to a repair shop.
Jun 17, 2009 | Quasar VM-L153 VHS-C Camcorder
LCD Monitor is black. The camcorder records
you can go to there you can get the owners manual start on page 60 that is where we got mine i have a quasar vm-L153
Mar 25, 2009 | Quasar VM-L153 VHS-C Camcorder
My Quasar VM-L143-C Camcorder screen turns black
if the camera records the video it will be there in the memory of it and you can check it by connecting it with a computer.if the video is in the memory there will be no problem with the recording device and the problem will be only to the LCD screen .if it is so, replace it with a new one which cost you about 35$-40$.if the settings are not correct the above problem will check the settings first and then go for the replacement of LCD .check whether the color of the LCD screen is in the correct level(check the brightness,contrast....)thank you.
Dec 17, 2008 | Quasar VM-L153 VHS-C Camcorder
Yes needs cleaned...try radio shack....or best buy for cleaning tape
hope this was of help!
Dec 11, 2008 | Quasar VM-L153 VHS-C Camcorder
Sep 02, 2007 | Quasar VM-L153 VHS-C Camcorder
No image at all...
The JVC C-Format camera can have one of two seperate problems that cause this symptom. The connector to the CCD comes loose and causes loss of video. Also, the CCD has been a source of problems for some time now, JVC will repair this for you free of charge if it's the CCD causing the problem. Good luck to you. Joe Weibel
Feb 18, 2007 | Quasar VM-L153 VHS-C Camcorder
No Sound Please Help....
I had the same problem,i just figured it out,
With these palmcorders there becomes a loose connection.
I have to hit where the speakers is to get it to record voice
Aug 06, 2006 | Quasar VM-L153 VHS-C Camcorder
Palmcorder problem
Need more info this when you play back thru the adaptor or playback from the camcorder its self???
Mar 22, 2006 | Quasar VM-L153 VHS-C Camcorder
Video Cameras Logo
330 people viewed this question
Top Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Video Camera Expert? Answer questions, earn points and help others
