Question about Brother IntelliFAX 4100 Laser Fax
FAXES ARE COMING THROUGH WITH MISSING LINES IN THE SAME AREA FOR ALL FAXES BUT NOT ALL THE TIME.WE HAD A NEW T-LINE INSTALLED, COULD IT BE THE CAUSE?
  • 1 more comment
  • dbailey965 Apr 16, 2009
    The missing lines run accross.Thank you
    Keith, Thank you. Looks As you suggested, looks like the drum was causing the problem.
  • keith640 May 11, 2010
    Do the lines run down the page or across?
  • 23 Answers
To see if the phone line is causing the problem, try moving the machine to a different line. You may need to go to another location to be sure your T-line is not a factor.
If the problem does not change, you may have a defective drum unit or the machine's electronics are failing.
Posted on Apr 16, 2009
White lines on both faxes and copies
clean the scanner, which is the .5 inch thick piece of glass that the ppr runs over as is is scanned
Nov 19, 2013 | Brother IntelliFax-2820 Laser Fax
Tip
Get rid of the line in your faxes or copies from your copy machine
If you are getting one of those black lines in your copies from the copy machine/fax machine, it may not need a new drum.
Most likely the scanning glass is dirty if the line appears from copies that are fed through a feeder, clean the little glass strip area (usually to the left) just before the scanning area where you manually place a paper to be copied. In most cases there is a spec of something on that glass. Don't scrap it with anything abrasive because if you scratch the glass you will have a line that will never go away. In most cases a damp klenex, paper towel or soft cloth with water will work. For stubborn specs dampen your klenex, paper towel or cloth with a little rubbing alcohol. This will also work well for getting rid of any greasy smudges on the glass strip and the larger glass area on the copy machine. Most of the thime the spec is from liquid paper or white out.
If you are getting calls from people you send faxes to saying your copies have a line on it and you use a dedicated 'fax machine only', look for the glass strip and clean it as directed above. If you are receiving faxes with a line, call the sender and give them the above tip.
If this tip works, it sure beats paying for a new drum you don't need.
on Aug 25, 2010 | Office Equipment & Supplies
I have a 1996 Nissan Quest. Back in April the radiator broke. I order a new one and replaced it. Later, which I did not notice, fluid was leaking from (which I believe was the reutrn hose to he...
Crossing the lines would not cause a leak. i think you need to take a good look at the lines and see if its the connection to the radiator or a rusted line or bad hose, some of theses came with the trany lines being all rubber hose from ****** to radiator and some were rubber and then change to metal tubing , anyway it doesnt matter which you have but i will bet its leaking from the lines , it may be the line itself or the connection at the radiator, clean the area with some engine cleaner and rinse off then run the engine and watch where the leak comes from, maybe the line just needs tightening. good day.
Aug 06, 2011 | 1996 Nissan Quest
Meridian M7310; just installed replacement phone (used); line 3 disconnects when answered. Lines 1 and 2 work fine. They are in the loop. Line 3 is dedicated fax incoming but can be used as outgoing phone.
Normal 0 Hello, Gary.
Disconnect power and cables from all phones and faxes on the line 3. Wait 15 minutes and reconnect the line again, one at a time. See if the Meridian works. If not, it could be faulty.
Hope this helps.
Feb 01, 2010 | NorStar M7310 Corded Phone
Dark vertical lines
You have to clean the scanner.Open the dock feeder area,and make sure the scanner glass is clean sometimes the glass look clean but just a smaal dot on the glass can cause a line.Clean also the white area above the scanner.The white area above the scanner help for shading operation of the mchine.Make sure you clean with a sullotion that can remove ink but not damage plastic.
Feb 18, 2009 | Brother FAX-8070P Plain Paper Laser
Fax stopped operating when FIOS was installed
Verizon is lying to you. fax machines are ANALOG devices and will not work reliablyon DIGITAL phone lines.
Jan 17, 2009 | Canon PIXMA MP830 All-In-One InkJet...
HP 920 Fax Half Lines
Try making a copy of something.
If the copy comes out the same way as your faxes, then the ink cartridge is either dirty or clogged.
You can try removing the cartridge and checking the bottom of it.
You can even wipe the bottom of the cartridge with some denatured alcohol.
If this doesnt work, then purchase a new cartridge and your problem should be solved.
Good luck.
Hope this helps.
Mac =)
Apr 02, 2008 | HP 920 Plain Paper Fax
Dark line
If the line is not on your recived faxes then you need to clean the area the paper passes over when sending. any marks could cause this.
Mar 19, 2008 | Brother IntelliFAX 2600 Fax
Bad copies
take out toner cartridge shake from left to right and reinstall cartridge
Jan 23, 2008 | Xerox WorkCentre Pro 555 Plain Paper Laser...
Comm.error displayed
Answer to your problem is move out of Verizon service area, they stink
Jan 20, 2008 | Brother IntelliFAX 4100 Laser Fax
Brother IntelliFAX 4100 Laser Fax Logo
114 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
