How to change washing machine drive belt?
MY WHRILPOOL ULTIMATE II WILL GO THROUGH EACH CYCLE, BUT WILL NOT SPIN. I THINK IT IS THE BELT HOW DO I A.)KNOW IF THE BELT IS IN NEED OF CHANGING AND B) HOW DO YOU CHANGE THE BELT?
  • Tracy Farrell
    Tracy Farrell May 11, 2010
    Hola Mon Senor,
    Does the washer drain the water out? Those who will help need this information.
    Gracias,
    SG
  • Washing Mach... Master
  • 8,220 Answers
Their are several diff configurations. Could I
trouble with a model number and brand porfavor?
Posted on Apr 16, 2009
How to fix a broken belt of motor of whirpool wash ultimate care 2
  • Replacing the Belt in a Whirlpool Ultimate Care II ' Home ... homeguides.sfgate.com > ... > Mortgage-Backed Securities Replacing the Belt in a Whirlpool Ultimate Care II by Rogue Parrish. Email; ... The Ultimate Care II washer, ... it may have a broken belt.
  • Whirlpool Washer: Ulitimate Care II - YouTube www.youtube.com/watch?v=bVmjmSzMXHE
    • BY CHERRY HILL
    • 3 MIN
    • 36K VIEWS
    2012-05-30 · Video embedded · Whirlpool Ultimate Care II: ... This is fully funcational washer. Direct Motor Drive works perfectly through each ... Whirlpool Washer: Ulitimate Care II
  • How to replace a broken dryer belt. Whirlpool Ultimate ... www.youtube.com/watch?v=PU8QZeDRl_0
    • BY BAILSOFSTEEL
    • 5 MIN
    • 3.5K VIEWS
    2015-04-04 · Video embedded · This video shows me replacing a belt in a Whirlpool Ultimate Care II ... a broken dryer belt. ... Whirlpool ultimate care II clothes washing
  • http://www.bing.com/videos/search?q=broken+belt+of+motor+of+whirpool+wash+ultimate+care+2&FORM=HDRSC3
    Jul 15, 2016 | Washing Machines
    Problem with washing machine spin cycle.
    see if belt is loose if it is a no belt model you will need a repair man to change some parts
    Mar 29, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
    No wash cycle or spin cycle. it will drain the water ok but no wash or spin.
    After taking apart my machine I discovered a broken part called the Motor Coupling. This part is what makes the basket turn from the motor. I had to completey take apart the machine. The part is located between the motor and the transmission. This machine is not belt driven. It is called a direct drive. good luck
    Dec 31, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
    Machine makes loud clicking noise when in the spin cycle....tub doesn't spin.
    You very well could have a broken belt. Sounds like just your pulley is spinning but not the belt. You will have to remove the rear access panel and take a look.
    If belt is still intact, make sure tub and bearigs are not frozen up. Make sure motor pulley spins. You can check power to the motor with a voltmeter.
    http://home.howstuffworks.com/how-to-repair-a-washing-machine.htm
    Nov 16, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
    How to fix rinse spin cycle problem
    lift the washer up and see if drum drive belt is broken or direct drive coupler is defective.
    Nov 01, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
    Won't spin, won't drain
    Hi...
    If your washer does not drain, you need to check this:
    • Inspect the drain hose for kinks
    • Test the timer control
    • Test the lid switch (some models)
    • Inspect the water pump
    • Inspect the drive belt (belt drive only)
    • Inspect the motor coupler
    If it does not spin check also this:
    • Test the centrifugal switch
    • Test the water level switch
    • Inspect under the washer for soot (clutch)
    • Test the motor
    • Inspect the pulley
    • Test the transmission
    Good luck !!!
    Regards
    PCmania
    Jul 14, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Spin cycle doesn't work
    the motor coupling is bad it is between the motor and transmission
    Jul 09, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
    Will not spin on any rinse cycle
    Hi, This washer does not have a belt. While the washer is agitating, if you lift the lid will it stop? Some models will agitate but not spin if the lid is up. It sounds to me like the lid switch might be going bad.
    If you will get me a model #, I can look this up for you and give you a better idea.
    Vic
    Jul 05, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Whrilpool ultimate care II
    Do you get any noise when you put it in the spin cycle with the lid closed?? if not you may have cooked the motor (easy repair) let me know
    Nov 29, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
    Washing Machines Logo
    398 people viewed this question
    Top Washing Machines Experts
