The fridge is not cooling. I've had the repairman out twice now. The fridge stops cooling for a day, everthing melts. I call the repairman, by the time he get out to see me a couple of days later the fridge starts cooling and working. This is very frustrating because the repairman cannot fix what's working. When the fridge stops working the light still work and I can hearthe fan, the weird thing is that the water dispenser stops working. I know that the fridge is starting to work when the water dispenser starts working.
Sounds like you have a defrost problem. The timer could be playing up and taking too long to defrost, which causes the evaporator to ice up, hence no cold air to the fridge and the water line freezes up, hence no water dispensed. When the timer does eventually defrost the fridge then everything returns to normal. This could also be caused by a faulty defrost terminator or bad connection on the defrost element.
Was this helpful?
Yes
No
Popular Solutions for Kenmore 50522 / 50524 Side by
KitchenAid side by side refrigerator made a pop sound and had some electric burn smell. Refrigerator...
(More)
KitchenAid side by side refrigerator made a pop sound and had some electric burn smell. Refrigerator still works but the freezer isn't. Any ideas?
I want to remove the Cover to access the cube or crushed switch. How is the Recess cover held on?...
(More)
I want to remove the Cover to access the cube or crushed switch. How is the Recess cover held on? Should I just 'pop' it off? What are the chances of it breaking? I have a Kenmore side-by-side, model 363.9517711 and I can not get it to crush ice. I get cubed ice, but not crushed. I want to see if the switch is connected but I am having a problem figuring out how to remove the access cover on the (inside freezer) door.
My Kenmore Ice maker produces Ice just fine, but I end up getting a big clump of stuck together ice...
(More)
My Kenmore Ice maker produces Ice just fine, but I end up getting a big clump of stuck together ice in the Ice Tray. all of the food seems fine. I have watched the water fill cycle and it dosen't look like it is overfilling or splashing out. I am thinking that it may have something to do with the Defrost cycle. Any suggestions for trouble shooting this problem? Thanks!
