Question about Kitchen Ranges
5 wire maytag cooktop wiring diagram..
Maytag cooktop model cse9000ade. 5 wire hook-up.Im having trouble wiring this cooktop, there are 5 wires white, black, red, white with a purple stripe, and yellow. I have hooked up the whites and blacks together. Ive hooked up the cooktops white/purple stripe, yellow, and red to the service red and could only get two burners working..I am unable to find a wiring diagram online due to the age..can you describe what I am doing wrong?Please
IB4G2008
  • 3587 Answers
SOURCE: ge spectra jbp78wxb4ww
GE parts folks says that the wiring diagram is either taped inside the back control panel, or someplace else inconvenient. Try that first, and then perhaps you'll find the information. Nada on the net.
Posted on Feb 10, 2008
SOURCE: Help in Removing Frigidaire Smooth Cooktop Burner
What holds the spring assembly onto the bar assembly is just two small prongs. Use a pliers on the end that protrudes through the bar, squeezing the prongs together, and it should come out fairly easily.
Posted on Mar 02, 2008
  • 145 Answers
SOURCE: My Amana ceramic cooktop has
Check your warranty first. Some burners on smooth tops had long warrantys. If not first turn the power off to the unit at the breaker. If this is a in counter cooktop it has to come out of the counter and take all the screws out that hold down the top. Best to unwire from house and move whole unit to big surface to work on.
Posted on Apr 18, 2008
SOURCE: Converting Kenmore gas range to LP???
I had success with the conversion. The directions are very cryptic, but it can be done, without the professional emptying your wallet, for 5 minutes worth of work. No adjustments needed on the air shutters, once they are wide open. The orifices are the pain-in-the-a$$es. You need some small tools to get to them, or chance dropping them under the top....which wasn't fun. Oh...and watch which orifice goes where...there are 3 sizes. So, short version, change orifices, open shutters, and flip regulator setting from NG to LG. Orifices take the longest time. ~ sjDIY
Posted on Oct 31, 2008
vitg55
  • 78 Answers
SOURCE: wire a 5 wire cooktop
If you have a model number for this cook top you can find the schematics here jast enter the model number:
http://www.servicematters.com/corner/corner_main.htm
Posted on Dec 15, 2008
Wiring for Kenmore Elite Induction Cooktop
The white one may just form an earth loop,, I recently had a ceramic plate needing cleaned so we did the whole lot, I think most hobs have 4 wires and they are numbered rather than colour coded..hope this helps
Nov 10, 2013 | Kenmore 30" Induction Cooktop Stainless...
Voltage for ge jp326 wiring diagram
That's the correct way to hook it up. Check the wires for possible insulation missing.
Jan 04, 2012 | GE 30 in. JP340 Electric Cooktop
Maytag cook top Model # CSE 9000 ADB. A red, black, blue, yellow, white, and bare copper wire come out of the unit. How do I hook it up???
each colored wire is for a seperate burner, the white wire connects to the white neutral wire the bare wire connects to the ground the red and yellow wires connect to the red wire (L1) and the black and blue wires connect to the black wire (L2). i have the same model and i connected mine this way and it's working fine. mine is also connected in a box that has a seperate fuze for each burner so you can follow the red (L1) wires to the 2 fuzes and connect your red and yellow wires to these fuzes and the follow the black (L2) wire to it's 2 fuzes and connect your black and blue wires to these fuzes. i don't know if this box is necessary or ir you can just connect directly to the wiresin a regular box and rely on the breaker but it was already there from the old cooktop i replaced so i used it. hope this helps you
Jan 07, 2011 | Maytag 30 in. CSE9000 Electric Cooktop
I need a wiring diagram for the 6 wires that are in the flex that feeds the unit
if it's like mine white to neutral, bare to ground, red and yellow to the red, black and blue to the black
Sep 05, 2010 | Maytag 30 in. CSE9000 Electric Cooktop
Maytag cse9000ade cooktop. Does anyone have
Hi Greg. Welcome to FixYa. I am Kelly. I have been looking into this for several hours now. Even service manual(s). The only thing I can find is the yellow wire goes from the infinite switch to the right side elements. I don't see a blow on your model so the wiring diagram should be on the bottom of the pan cover. The bad news is I can not tell if it is actually on the bottom or inside the bottom. From everything I can see it appears that the yellow wire would be attached to L1 vs where you currently have it connected i.e neutral. I can not come up with the wiring diagram that is part of your cooktop but all of the other Electric Maytag and Jenn-Aire models show the same thing. Yellow wire from the infinite switch and L1. Take a look at your wiring diagram if you can find it and see if you come up with the same conclusion.
This became one of those solve the mystery questions for me and I literally have been looking at it for about 3 hours now. trying to get something I can safely pass to you that will not damage your unit.
With the yellow wire on neutral currently it would be operating on 110V and have low heat. Placing the yellow wire on L1 (Left) should get 208V to the right side burners. Again.. take a look at the schematic / wiring diagram that is attached to your unit.
This is the best I can do from here. The users manuals I have found for your cooktop are in several languages. ENGLISH is not one of them :(
Kelly
May 03, 2010 | Maytag 30 in. CSE9000 Electric Cooktop
Cooktop - maytag cse9000 - wiring
white goes to neutral, bare copper to ground, red and yellow to one phase ( red L1 wire) and the black and blue to the other phase ( black L2 wire)
Dec 20, 2009 | Maytag 30 in. CSE9000 Electric Cooktop
Wire a 5 wire cooktop
Dec 15, 2008 | Kitchen Ranges
GE JP350 wiring problems
a to black one
b to red one
d to orange
e to grey
a-e to red two
a-d to black two
a-c to orange two
a-b to grey two
a-a to white
Jan 19, 2008 | GE 30 in. Profile JP350 Electric Cooktop
Kitchen Ranges Logo
142 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
