Question about Spire HD05040B Harddisk cooler Double 12v DC FAN Ball Bearing 4 Pin Connector Quiet
Harddisk my hard disk has bad sectors and system is giving disk error as we boot our system.... even scandisk was not working from many days . it just goes to 3 to 4% and than hang on... one has tom pres enter before it start.. is there any solution or i have to replace it..
  • Anonymous Feb 17, 2008
    I put up in banglore...My harddisk has got crashed, so i jst wannted to know about the sevise centers near by...
    Sergeant:
    Champion:
  • 293 Answers
Hi, It may be a virus you may want to check on that first. If it is possible for you to scan it on a friend's computer while you are at it you can repair it there too. If not your last resort is formatting the drive using your Bootable Windows Installer CD.
Posted on Sep 15, 2007
SOURCE:
What am I going to to I cleanup some file in local c of window 98 suddenly my PC did not work it always say A disc error occur
hi
try to create boot disk then boot up from floopy and type command scandisk /fix
if only system problems scan disk will fix it ror u unless yr hard disk problems or bad sector problem
regards
Jun 27, 2011 | Microsoft Windows 98 for PC
Problem related Seagate Hard Disk
i also encountered that problem about using seagate. first make sure that theres no loose connection between the MotherB and HardDisk. Or maybe it has a virus or a bad sector.,Try this, if you have another hard disk, try to make the 80gb a slave drive. then format it using windows base process (Right click the drive then FORMAT). or try DEFRAGMENTATION and scandisk for that drive.
Dec 01, 2008 | Seagate 500GB Maxtor Diamondmax21 SATA2...
Bad sectors
Use the following link to download the software, which helps u to detect as well as completly remove badsectors, but before u do tat, here is the answer for wat is bad sectors..
Hard disk drive is an integral part of every computer. It stores all your information. One of the most prevalent defects of hard drives is bad sectors on the disk surface. Bad sectors are a part of the disk surface which contains not readable, but frequently necessary information. As a result of bad sectors you may have difficulties to read and copy data from your disk, your operating system becomes unstable and finally your computer may unable to boot altogether.
When a hard drive is damaged with bad sectors, the disk not only becomes unfit for use, but also you risk losing information stored on it. The HDD Regenerator can repair damaged hard disks without affecting or changing existing data. As a result, previously unreadable and inaccessible information is restored.
ths is the software
A powerful hard disk tool that can detect and repair physical bad sectors on a hard disk drive surface and regenerate hard disk.
http://www.4shared.com/file/49739096/5f24d2c2/HDD_Regenerator_151_Full.html?s=1
Jul 17, 2008 | Microsoft Windows Server Standard 2003 for...
Bad Sector on Harddisk
Set defrag to run at boot up and it will resolve any bad sectors you have, and will write a new boot registry for you.
Jul 17, 2008 | Hitachi Deskstar 7K80 Hard Disk 80GB,...
Pxe-e61 media test failure. i have managed to get the computer into safe mode but will not run in normal mode why is this and how can i fix it?
This issue is often caused by either an incorrect setting in bios or a bad boot device, such as a bad hard disk drive. To resolve this issue, run scandisk to check if the hard drive have develop a bad sector. Double click mycomputer and right click drive C: and select properties,tools,check now and check the the two options in the check this option windows and reboot your computer. During the reboot of computer the scandisk is check your harddisk after the scandisk finished scanning you can read the result if you see the bad sector or cluster found it's mean that your hard drive is damage in you need to replace it to correct the error. But if no bad sector found try to remove the software or hardware that you installed before the problem is occured go to control panel then add and remove software. if you have a registry scanner software like pctools registry mechanic try to run it to fix the problem in the registry.
Apr 16, 2008 | Computers & Internet
Missing Operating System error
your bought compag computer is a new one , because that error is appears only if the hard drive or the harddisk is defective or damage. Your installation of windows xp is finished totally because sometimes the error is appears because the system installation is not finished and the os system cannot read. try to re install again the windows and delete the old partitions and create again if the problem is the same even there is no error in the installation until it's finished i say that the problem is in the harddisk. Maybe the harddisk develop a bad sector in the master boot record of the hardrive
Apr 15, 2008 | Compaq Presario 700 470024-192 Notebook
"Non-system disk or disk error replace and strike any key when ready".
If this error occurs you open the cabinet disconnected the harddisk data cable for few seconds and reconnected the harddisk data cable and bot it will work.
Apr 10, 2008 | Compaq Evo N610C Notebook
Disk checking problem???
i think your harddisk got bad sectors.
use scandisk .
or remove the bad sectors with bootable cd.
Apr 01, 2008 | Computers & Internet
Harddisk fault
Hello!
Just try scandisk, Right click your c: and then properties, in tools menu, click check disk or scandisk.
may this help.
melnavz
Mar 03, 2008 | Compaq Presario 5000 PC Desktop
Open Questions:
See all Spire HD05040B Harddisk cooler Double 12v DC FAN Questions
Computers & Internet Logo
Top Spire Computers & Internet Experts
Ekse
Alun Cox
Are you a Spire Computer and Internet Expert? Answer questions, earn points and help others
