Question about Sony Handycam DCR-VX1000 Mini DV Digital Camcorder
My camcorder has an aura problems. it's bleeding green colors
My camcorder is bleeding green, sometimes red and sometimes blue colors. I was wondering what I can do to fix it. Any suggestions on replacing parts. I have the service manual with all the parts and parts numbers to get them. I have a sony vx1000 english version.
  • 10,594 Answers
It is an old model of 1995 and I'm sure it has problem of leaky electrolytic capacitors. You need to replace all electrolytic capacitors in this camcorder.
Posted on Apr 15, 2009
My screen has little dots appearing sometimes red sometimes blues behind the picture i just replaced the lamp bulb as i thought it would cure the problem
the projection tube needs to be adjust for color alignment, each tube (red, green, blue) must be aligned so you there would be no color smear appear on screen. if it is aligned try to set up the color balance, hue etc.
Feb 06, 2011 | Samsung Televison & Video
How do I make the connections from the Red - White - Yellow RCA Male plugs of the camera to a USB adapter Red - Blue - Green RCA Female to download to a computer? Stumped.
Hello, for the descriptions of the colors (red. green, and blue) of the USB video adapter, what you have is a "component video input" also called YUV in which you can only send color difference signals from a device that has the same kind of output, like a DVD player. So, you cannot plug your cam cable directly to them.
Maybe your USB adapter has another input or dongle in which the colors of the RCA jacks are the same as you have in your camcorder. Red: right Audio, Black: left Audio and Yellow: composite video.
Send me back more info of your adapter, like make and model, maybe I can see the specs and add more help in this matter.
Good luck
Dec 09, 2010 | Sharp VL-E610U Camcorder
Panasonic pv-gs15
You need 3 cables Yellow, (Video) + Red & White, (Audio L&R Stereo) Or Mini-DIN, for SVHS Video cable, this is ONLY for Video, Audio, is still Red & White. Or Component, where you have 3 Video Sockets, cables, Green, Red, Blue, All video, all color to color, both ends, and again Red & White for Audio. Sometimes there is FireWire, or HDMI you need a cable and the PC MUST also be equipped, You need software and drivers for FireWire, of HDMI..
Mar 26, 2010 | Panasonic Palmcorder PV-GS15 Mini DV...
Distored picture and a rainbow aura around objects in the pictur
this CRT TUBE internal Problem, first use CRT Rejuvenation Device. If dont repair you must change CRT TUBES
Oct 30, 2009 | Samsung Televison & Video
No sound on play back using camcorder on technika tv
Looks like you are using Component cables. There are five cables. The first three cables are Green,Blue and Red. These are the ones that are molded next to each other and are the Video signal cables. The other two cables are Red and White and they are the audio cables.
First to correctly hook up these cables you need to Connect (Match) Color for Color. (Green to Green, Blue to Blue, and Red to Red. To tell if you have correctly connected the Video cables is to look at the screen. If the picture looks ok (Normal with no colors missing then you have connected the video cables correctly). If you see a missing color meaning red, then switch the Red cables. The picture should be ok now. The remaining two cables are the Red and White cables. The "Red cable" is for the "Right" audio input and the "White" cable is for the "Left" audio Input". If all is connected correctly then you should have a good picture and Left and Right audio.
Jul 05, 2009 | Televison & Video
Posiflex cash drawer CR 3100 wiring for 6 pin phone plug
If you have the following pairs of wiring:
Blue/White - White Blue
Orange/White - White/Orange
Green/White - White/Green
Then the pairing starts as follows:
Pin 3 - Blue/White
Pin 4 - White/Blue
Pin 2 -White/Orange
Pin 5 - Orange/White
Pin 1 - Green/White
Pin 6 - White/Green
If your wiring has different colors, please let me know and I get you the correct wiring plan.
Don
May 10, 2009 | Posiflex AURA 7000 Matrix Printer
Kv-36hs20
Have you tried disabling SVM (scan velocity modulation)? Often touted as a "feature" of TVs, it's a way of artificially making a picture appear sharp. Totally unnecessary. When SVM (sometimes called VM) is on, it can lead to some color bleeding around edges.
Mar 24, 2008 | Sony FD Trinitron WEGA KV-36HS20 36" TV
Sony DSR-PD170 Color Problem
sounds like a problem with the image sensor, or an intermittent cable connection to the sensor.
Jan 06, 2008 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Sony Handycam DCR-VX1000 Mini DV Digital Camcorder Logo
213 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
