Question about HP LaserJet 4 plus Printer
PRINTER IS PRINTING VERY LIGHT.
Replaced with new toner cartrige,not rebuilt and still having the same problem. Any ideas? Thanx Troy.
Laser needs cleaning.
If you're up to it, remove the top cover of the machine, be careful not to damage the operation panel connector (unplug), then undo several wire connectors to allow access to the laser, remove the cover of the laser, and clean all mirrors, lenses, and reflectors
Posted on Apr 16, 2009
New toner cartridge in my HP 6L printer is printing too light
dirty scanner lens OR is the toner Genuine HP or a rebuilt toner ?
Dec 22, 2012 | HP LaserJet 6L Printer
Put in new toner cartrige and on line/error light stays on and printer will not work
Printer cartridge is not compatible. try to replace the old if printing
Jan 05, 2011 | Samsung ML 2010 Laser Printer
My printer has two cartriges that are empty would that prevent it from printing ?
Yes the HP CLJ 2600n printer will stop printing when a toner cartridge registers as empty. The cartridges will have to be replaced or You could use the "overide out" option. This allows continued printing even though the supply registers as empty. Beware that diagnosing print quality problems because of toner becomes more difficult.
Overide Out
To change this go to the PRINT QUALITY menu then REPLACE SUPPLIES and change the setting from "stop at out" to "overide out".
Jun 16, 2010 | HP Color LaserJet 2600n Printer
Dirty Copies are printing
Remove the black cartridge, check the roller in front, does the roller evenly disribute the toner? if not change the cartrige. Do the same for other cartriges.
Apr 09, 2010 | Samsung CLP-510 Laser Printer
Hp 2605dn Black cartridge is printing 1/8" LEFT of other colors.
That problem is frequently on HP 2600 series.
You must try to change all remanufactured toner cartridges with HP OEM with no exception, the best alignment it is when you change the black cartridge and the printer make a cleaning page process. Cartridge HP OEM should be almoust empty. It Is not necesarry to be a new one. After the alignment process, you can put the remanufacturated cartridges back on.
This was work for me. 100%
Sep 27, 2009 | HP Color LaserJet 2600n Printer
Low toner advise keeps on after changing toner and/or printing
Have you tried to unplug your printer and plug it back in, that will force the printer to re-check all its settings and it should notice that the toner is now full.
May 27, 2009 | Dell 1110 Laser Printer
Stopped printing, need drum? but no light on
Hi! sandy; Your printer not really heavey duty one, and you give them big jobs, for a sample, you give adult jobs to the baby, it not going run, so your machine need a break! nothing wrong just give them little bit rest.
May 06, 2009 | Brother HL 5250DN Laser Printer
New toner, still get lines on paper when printing
Is there toner streaks on the drum?
Remove toner cartridge and push back the drum cover (on bottom)to check. Could be just another bad cartridge.
If the drum is clean, then it's coming from the fuser. You can have it replaced /rebuilt, but I personally wouldn't spend any money on this one.
Mar 29, 2009 | HP LaserJet 4L Printer
Toner light
NEWER MODLES HAVE A CARTRIGE ESTIMATING PROGRAM THAT NEEDS RESET (you need to tell the printer that it has a new cartrige). SIMPLY....
1. OPEN THE FRONT COVER.
2. TURN OFF.
3. HOLD DOWN THE GO BUTTON AND TURN BACK ON.
4. ONCE ALL 3 LIGHTS ARE SOLID, LET GO OF THE BUTTON & PRESS IT 2 TIMES RIGHT AWAY.
5. ALL LIGHTS SHOULD GO SOLID AGAIN, WHEN THEY DO PRESS THE GO BUTTEN 5 TIMES IN A ROW.
THIS SHOULD RESET YOUR PRINTER AND LET IT KNOW IT HAS A NEW CARTRIGE (even if it doesn't)!
Aug 26, 2007 | Brother HL-2040 Laser Printer
Toner Light stays on after new cartridge installed
2. TURN OFF.
Aug 14, 2007 | Brother HL-2040 Laser Printer
HP LaserJet 4 plus Printer Logo
88 people viewed this question
Seeker5211
Seeker5211
