I have a Dymo label maker 150. After I turn it on type in a label and press "Print" nothing comes out. I have tape in it and it hhas performed well in the past.
Try reinstalling the driver
Posted on Apr 23, 2009
Won't print from another mac as can't find printer
You can try going to System Preferences and pressing Resume to make sure the printers are not off line. Otherwise, please contact us (see dymo.com for numbers).
^CM
Dec 26, 2013 | Dymo LabelWriter 1752266 450 Twin Turbo...
I have the dymo letratag. no letters come out on the paper. I can not find anywhere to put any ink.
LetraTag label makers are thermal printers, so they don't use ink - just batteries and LetraTAG tapes.
When the print starts to fade it's time to put new batteries in.
Jan 29, 2011 | Dymo LetraTAG Thermal Label Printer
How do I reset my Dymo lablel maker I have ! ! ! ! ! ! when in use
!!!!!! is a (rather unhelpful) error code that means basically that it can't print for some unknown reason. If the tape is not jammed in the printhead, and the tape seems to move freely, then generally it means the machine is broken.
To be sure you can call Dymo tech support on 020 7341 55 29 (UK)
If it's under warranty, you can return by going here:
http://global.dymo.com/enGB/ServiceAfterSales/default.html (UK)
If not you'll need another one...
http://www.dymo-label-printers.co.uk/Dymo-Label-Maker.html (UK)
You don't say which model you have, but if it's the one in the picture it should still be under warranty as they're fairly new and come with a 3 year warranty (in the UK at least).
For US or other countries go to www.dymo.com and select your country, and then the returns and contact information can be found there.
Nov 04, 2009 | Esselte Dymo LabelManager 120P Compact...
Labels coming out blank
1. Replace the batteries (use only alcalines)
2. See if the tape is correctly inserted.
3. Clean the printer head
4. Replace the tape with a new one.
5. Check the contrast settings
Jul 20, 2009 | Dymo LetraTAG Thermal Label Printer
How do I change the tape in my dymo QX50 label maker?
Where the cartridge has a hole in it, make sure the tape is IN the print head, not over or under it. Also, check the type & color of the tape. They have some strange combinations that are only visible under certain conditions.
May 22, 2009 | Dymo LetraTag QX50 Thermal Label Printer
Dymo Letra Tag
I have to assume you are pressing the print button. That being the case, either your batteries are weak or the tape is empty or jammed.
Aug 28, 2008 | Dymo LetraTAG Thermal Label Printer
Tape Jam
There may be a small piece of label cutting stuck in the gears. remove the label cartredge, you will see a white gear set between the pinch wheel and the print head. Use a micro drive or something strong and give the gears a little help while pushing the print button. You may have to do this several times. Be careful not to use too much force as this may knock a tooth off. Good luck. My Dymo continues to print prefet labels.
Mar 08, 2008 | Dymo LetraTAG Thermal Label Printer
Printing
I was having the exact same problem & had lost my user's manual (you can go on the Dymo.com website to download a replacement). The !!!!!!!!!! display means that there probably is a tape jam. Here's what the manual says:
*!!!!!!in the display indicates that the tape can not be transported *Press any key to return to normal display *Check if there is a tape jam. In that case, life out the cassette and carefully release jammed tape. Cut off excess tape and refit/replace the cassette *If there is no tape jam replace the batteries
Nov 05, 2007 | Dymo LetraTAG Thermal Label Printer
Error 1
The user guide lists all the error codes and possible solutions. http://download.dymo.com/media/UserGuides/QX50US.pdf Error 1 indicates a tape jam or low battery. To resolve, try removing the cassette and clearing the tape or replacing the battery.
Sep 20, 2006 | Dymo LetraTag QX50 Thermal Label Printer
91 people viewed this question
jasbo
jasbo
