Question about KitchenAid Kitchen Ranges
OVEN WILL NOT GET HOT THE GAS DOES NOT COME ON. ITS A KITCHENAID FREE STANDING GAS RANG OVEN. MODEL # KGRA806PSS02
The gas regulator valve (gas shutoff valve) may have been turned-off accidentally,while cleaning or moving around unit. Just locate it, usually in the rear, under the burner top, if not, you may find it underneath, behind the bottom pull-out drawer.
Posted on Apr 16, 2009
Oven not working, possible cause
check gas meter outside see if some persons unknown has turned of your gas meter
if gas hot water check if you have hot water
Jun 04, 2016 | KitchenAid Kitchen Ranges
The oven door cannot open. The self cleaning cycle was not completed because the display window went blank and as a result the oven door remained locked. This occured during the Christmas season and...
Sounds like my problem two days ago. I have a Kitchen Aid free standing gas oven/range model
KGRI801PWH00. I read online that the thermo-fuse might've blown. I found the thermo-fuse after removing the rear panel. It was at the top/center. Mine is T-O-D (brand) 60F24; Westinghouse #8300802. I ordered mine from appliancepartspros.com for only $34.75; arrived in 36 hrs with regular shipping!! Easy to fix, sure beats several hundred $$ to repairman.
Don't bother to call Kitchen Aid - they'll just blow you off just like the hundreds of complaints said that I found online.
Jan 24, 2011 | KitchenAid KGSA906PSS Gas Kitchen Range
Need to take off oven door to tighten handle, gas range Kitchen aid free standing,30inch
open door 1/2 way to the first spring stop (used in broiling position) lift door straight up from the position be careful this is a heavy item
Dec 13, 2009 | KitchenAid KESC307 Electric Kitchen Range
I have an older whirlpool free-standing gas range and oven and the broiler works but the bake option does not, the oven doesn't get hot, any suggestions?
you may need to replace the bake ignitor. if it is glowing orange and not white, it isn't hot enough to light the bake. hope this helps
Oct 15, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Kitchenaid Gas convection range lower burner will
whirlpool oven wont turn on top burner work.
model #SF315PPQ2
Sep 04, 2009 | KitchenAid KGRT607HBS Gas Kitchen Range
Can't turn oven off
Over the 2008 Hoildays while baking, our Kitchenaid range (KGSA906PSS) "off" button would not turn off the gas oven portion of the range. The two ways we could turn off the oven was to either set a "stop cooking" timer for one minute or to go the main electical breaker box and cut off the electricity to the the range - either way- not a good way. We called Kitchenaid Customer Service at 1-800-334-6889 and stated the problem. We were concerned that this was a safety issue since we could not turn off our gas oven without resorting to the timer or breaker methods. The warranty for the electronics touchpad is from 2-5 years according to our owners manual. We have had the range since Aug. 2005.
We provided our model #, serial#, date of purchase and answered some other questions. Kitchenaid did determine this to be a safety issue and in doing so, our replacement part and labor will be provided free of charge.
Even if your warranty has expired, I would still call Kitchenaid first since this is a safety issue.
Dec 03, 2008 | KitchenAid KGSA906PSS Gas Kitchen Range
Kemore gas Oven /range - oven very slow to warm and gas leaks but Broiler ok
Hi thanks for the question. the problem you are having is with the igniter in the oven. it ignites but not hot enough to burn all the gas. replace the bake igniter. thanks the appliance doc. please rate my answer. thanks.
Oct 06, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
8 year old kitchenaid gas range nom fire in the oven
I went to the kitchenaid web site for parts and found a trouble shooting section. I read about how a electronic glow coil works and discovered that mine was just old and did not reach the right voltage to open the gas flow valve.
Feb 20, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Shabbat mode intructions for Kenmore free standing oven
you can download a manual from the manufactures website/The sabbath mode is in the options or set-up button.
Oct 02, 2007 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Open Questions:
Kitchen Ranges Logo
194 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
