Question about Aiwa CR-LD120 AM/FM Radio
No Sound Clock is set and keeps time Radio stations are set in both am & fm Through the ear phones you can hear that the radio is on but no radio sound at all, on any of the am, or 2 fm sets of stations
  • 328 Answers
It seems to be that the antenna is at fault. If you can take it apart, you should resolder the antenna.
Posted on Nov 10, 2007
How do I change my cd clock radio to AM
probably doesnt have AM option. You have high quality CD sound and high quality FM sound, they don't let you have bad quality AM. Having said that it does.
Press the ALM OFF/SOURCE button to select the FM or AM mode.
Press the
/MIN button or
/HR button step by step to tune to the desired radio stations.
Press and hold the
/MIN button or
next radio station in the direction of the search. The search operation simply finds stations with
strong signals. Stations with weak reception can only be tuned in manually
Onn ONB14AV201 Product Manual Product Features View
Jul 09, 2017 | Audio Players & Recorders
No sound from speaker but through ear piece I get sound.
Many devices will automatically switch off the large speaker when ear phones are plugged into them. Also there may be a switch or button or prompt on your radio to switch between regular speaker and ear phone jack. Look for that first.
Try connecting and disconnection ear phones while listening to a station and see if the problem is intermittent. If is works sometimes but not every time then it is most likely an internal connection.
You will have to access the inside of the radio to investigate further. Connect a working external music or sound source with speaker wire to the terminals inside the radio that connect to the radio's speaker. If the radio's speaker works with the external sound source then you know it is a bad connection inside your radio. If the radio's speaker does not work with the external sound source then it is most likely a faulty radio speaker. Look closely for a broken solder point or broken/disconnected wire.
Sep 10, 2013 | Eton E100 SW/FM/AM Radio
The sound on AM channel is very poor while that on FM is excellent.What is the cause of this problem ?
Usual problem can be traced back to faulty electrolytic capacitors, solution is to replace all capacitors and make sure any leakage is cleaned up with needed repairs. Contact me if you need help.... poikaa(at)yahoo(dot)com
Dec 22, 2011 | Sony ICF-SW77 AM/FM/SW Radio
No Sound on AM or SW
If the set receives FM signals without any problem, and only fails to receive AM signals, the IC [integrated circuit] used in it is faulty. The number of the IC used with your radio is CXA 1376AS. It is a replacable type IC, and can be bought from most of the electronic spare part shops at your town. If you want further details about its service manual, get me by Fixya. OK.
Nov 11, 2011 | Sony ICFSW7600GR FM Stereo World Band...
When using the FM tuner I have to click buttons multiple times before it responds. It also does not keep the clock display up to date . . . acts like the processor is overloaded. This only occurs when...
I have the same problem and not just with the FM tuner. I have spoken to Aluratek about the sluggishness of this radio. Their reply was to not push the buttons ore than once. The radio will eventually work.
Sep 28, 2009 | Aluratek AIRMM01 Internet Radio Alarm...
No sound
If you are getting AM sound, but not FM, its because the headphones you are using are shielded for interference. This shielding is what is causing you not to be able to pickup FM, as the headphone wires are what is used as an FM antenna for the unit. Try using a CHEAPER set of headphones (Yes, I said cheaper). Cheaper headphones usually don't have the shielding. Usually these types of headphones have both wires for the headphones bound together as one wire.
Apr 01, 2009 | Sony Walkman SRF-M37V AM/FM/Weather/TV...
Lost manual for a timex t307s
Setting the Alarm 1 for AM/FM Radio
1. Press and hold the 2 Radio Alarm 1 Button. The display will flash and the Radio Alarm Indicator will appear. If
you do not begin setting the time within ten seconds of pressing the button, the display will stop flashing and you will
need to press the 2 Radio Alarm 1 Button again.
2. While the display flashes, press the 1 Reverse and 6 Forward Buttons to set the wake time. Hold a button for a few
seconds to set the time rapidly. Be sure to set the correct AM/PM time, as shown by the PM Indicator.
3. After setting the radio alarm time, while the display is still flashing you will need to select the station. First, press the
L Mode/DST Button to select a radio frequency. Next, select a station using the M Memory Set 1-6 Buttons. For
more information on programming radio stations into memory, see the Programming Radio Station Settings section of
this manual. Rotate the O Volume Thumbwheel to set the wake sound volume.
4. After setting the radio alarm wake time and sound, you will need to select the 7-5-2 setting. The 7-5-2 setting lets you
set the alarm for a full week, weekdays only, or the weekend. Before setting the alarm, be sure that the correct date
is set, as shown in the “Auto-Set” and Manual Time and Date Settings section of the manual. While the display is still
flashing, press the 9 Date/7-5-2 Button until the desired setting is shown.
5. After you have set the radio alarm wake time, sound, and 7-5-2 setting, press the 4 Enter Button. The Radio Alarm
will appear on the display, showing that the radio alarm has been set.
Setting Alarm 2 for Nature Sounds/Buzzer
1. Press and hold the 7 Nature Sounds/Buzzer Alarm 2 Button until the Alarm 2 settings and Sounds Alarm
Indicator appear on the display.
2. Press the 1 Reverse or 6 Forward Button to set the Alarm 2 time.
3. Use the L Mode/DST Button to select a nature sound or the buzzer to wake to. There is a choice of five sounds:
Sound #1: Ocean Surf
Sound #2: Birds
Sound #3: Brook
Sound #4: Wind Chimes
buz: Buzzer
4. See Note #4 in the Setting Alarm 1 section for instructions on setting the 7-5-2 alarm setting for Alarm 2.
5. After you have programmed the Alarm 2 settings, press the 4 Enter Button or wait ten seconds to return to the clock
display. The Sounds Alarm Indicator will appear on the display, showing that the alarm is set.
Nov 18, 2008 | Timex (T307S) Clock Radio
Zenith Z212B CD clock radio
Have you done the presets on the memory. Do that then select the station you want to wake up to. Hopefully its fm. Per the instruction manuel . Set or adjust the alarm time if necessary. Press the Alarm on/off button if necessary until one of the alarm indicatior either the note or alarm appears on display when the buzzer alarm is selected. While the alarm time display is flashing press the tuner button to select am, fm, or tv band. The selected indicatior appears in the display ( Note : you can only select the band when you have selected wake to music. While the alarm time display is flashing press one of the preset buttons to select the station you wish to hear when the alarm goes off.
Apr 17, 2008 | Audio Players & Recorders
How to set alarm and ring with radio?
Hi gidgid.
This is direct from manual mailed to me from Oregon Scientific re my own contrast problem.
1. Press [ALARM] to switch to display the alarm setting.
2. Select ALARM 1 or ALARM 2 using [ALARM].
3. Press and hold [ALARM] for two seconds.
4. Use VOLUME [ + ] / [ - ] to enter the hours.
5. Press [ALARM].
6. Use VOLUME [ + ] / [ - ] to enter the minutes.
7. Press [ALARM].
8. Use VOLUME [ + ] / [ - ] to select ALARM or RADIO. If
ALARM is selected, a two-minute crescendo alarm will be
emitted at the set time when the alarm is active. If RADIO is
chosen, the radio will be turned on for two hours at the set time
9. If RADIO is chosen, use [STATION] to choose the radio
station and press [AM / FM] to select AM or FM.
10. Press [ALARM].
11.Use VOLUME [ + ] / [ - ] to set the volume of the wake up radio.
12. Press [ALARM] to exit.
Note: If there is no battery for the radio, there is no operation for
step 9 ~ 11.
sleepy head
Jan 13, 2008 | Oregon Scientific RRM112 Clock Radio
Timex T600
Can anyone tell me where to obtain a owner's manual? I bought this clock used.
Aug 07, 2007 | Timex T600 Clock Radio
Aiwa CR-LD120 AM/FM Radio Logo
155 people viewed this question
Top Aiwa Audio Players & Recorders Experts
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
