Question about Toshiba 61H71 61" Rear Projection Television
I have a Toshiba 61H71 that keeps blowing F850. It was just sitting there the first time it did it. I didn't have a replacement fuse so I temporarly replaced it with a 3A glass barrel type fuse. This worked perfectly. I took the board back out about a month later when I got proper fuses from e-bay and replaced F850. It hasn't worked since. As soon as I plug it in and it tries to power on it blows the fuse. I have been through 4 fuses now. I see nothing wrong with the board. Gotta be a cap or something. Any suggestions?
Check for loose solder connections at jumper 010 & 050..050 jumper is located left side of convergence sig board between c7791 & c7798..jumper 010 connects to D7809...This will cause F850 to blow continuously..Thanks Arlie
Posted on May 06, 2009
Resolder jumpers on signal PCB..May be near convergence IC circuit..on 50" model they are 050 & 010. You may have solder cracks..I repaired a 50" toshiba..Let me know if this fixes
Posted on Apr 16, 2009
I have A toshiba 57HX81 tv red ligth blicking.i found (2)5 amp pico fuses at F850 & F851 & (1) pico fuse 2AMP at F852 would replacing these fuses bring the tv back to life.
Too many possibilities to predict if the fuse replacements will make the set function again but I suspect your main power supply has failed so if the fuses blow after replacement, you may have to have the supply repaired or replace it.
You might check, using your model number, at the site below to see if they have a power supply 'pull' available from their stock. They part out retired sets of all kinds.
Jimmy's Parts
Nov 27, 2010 | Toshiba 57HX81 57" Rear Projection...
Toshiba 57H81 Flashing Red Power Light, Blown Fused F850+F852
Solved by resoldering some solder joints!!!!!!!
Toshiba Model 57H81 Rear Projection TV - Purchased 11-09-2001
Problem: Toshiba 57H81 Flashing Red Power Light, No Picture/Sound, Blown Fuses F850 + F852
Symptoms January, 2009:
  • Upon turning on set I got flashing red power light and nothing else.
  • Removing plug for one minute and plugging in results in:
    • Audible click, steady red power light for 2 seconds then slow flashing red light
    • Pushing power button results in steady red for about 2 seconds then slow flashing red light, no other set activity
  • Removing power cord for several hours and plugging back in made no change
    • Audible click, steady red for about 2 seconds then slow flashing red light
  • Possible related note: Over past several months occasionally the entire screen would flicker momentarily and at other times be problem free for weeks.
  • Fuses F850 and F852 found blown
Repairs Made:
  • PD0074 DEF/CON Power Board
    • There are two main power supply capacitors in this set. They are C-809 and C-810. One their negative lead on the printed circuit board re-soldered leads and nearby contacts. I’m told that because the factory left out a printed circuit board eyelet, the connection will come loose over time. When I called Toshiba customer service they said there was a known solder joint problem causing blinking red light.
    • Replaced blown fuses F850 and F852.
      • I actually installed a fuse panel on the inside of the cabinet and routed the fuse connections here instead of ordering the special fuses and replacing them on the circuit board.
      • Had to use a 5 Amp SLO-BLOW for F850. Fast blow does not survive power up. Get the red blinking light.
      • Used a fast blow 2 Amp for F852.
  • PD0073 SIGNAL Board
    • Re-soldered Q751 + Q752 STK392-110 Convergence Amps
    • Re-soldered adjacent pads that looks suspicious
Total Cost to Repair about $10
  • Twelve hours of my time over three days to research issue, disassemble set, make repairs, add fuse panel.
  • Already owned Service Manual and Circuit diagrams from a different 2004 repair.
  • Less than ten dollars at Radio Shack for fuses and fuse panel. Already had wires, etc.
  • Some solder. Already owned de-soldering tools, etc.
  • Visited both local authorized Toshiba factory service repair facilities. One said repair would have to include replacing Q751 + Q752 STK392-110 Convergence Amps with ST392-180, and realigning set for a total of $500+ and it would be more if they had to order a power board. NO THANK YOU! Other shop said $65 for site visit and $30 to make an estimate that could be applied to repair.
Jan 04, 2009 | Toshiba 57H81 57" Rear Projection...
Shut off
make sure that you check for any cracked solder. and check all bridge rectifiers
Feb 20, 2008 | Toshiba 57H81 57" Rear Projection...
Toshiba projection tv 50 inch
Need to test F470 and F850 for open.. Simple continuity to see if either fuse is open.. If F 470 is open replace it and C884 and if F850 is open you probably you may need to replace the two convergence amps STK392-110... Large black Ic's screwed on an aluminum heat sink...
Bill
Dec 16, 2007 | Toshiba 50H72 50" Rear Projection...
Convergence
Convergence amps can be upgraded from STK392-110 to
Hitachi brand STK394-160E Part # CZ 01341.....
+ Check B+ micro fuses F850,F851,etc.
+ solder bad connects on wire jumpers 008,010,017,048,600.
If you don't solder jumpers,you may blow fuse ( again )......T.
Let me know.............................
Nov 27, 2007 | Toshiba 42H83 42" Rear Projection...
Toshiba 50H81 TAC0151 Blowing Fuses, I Need schematic
Well without the schematic, knowing Toshiba they have alot of convergence problems, so see if the fuse blown in the convergence area, if you you may have to replace convergence amps. These are the big STK's. Most of the time there was a color problem with set before going out. If no problem with this on your set then look in the HV area Hor. and Ver. area. Hope this helps!
Sep 09, 2007 | Toshiba 50H81 50" Rear Projection...
No power, LED blinking, Low voltage regulator IC?
check for bad solder connections then check all fuses the ones that look like resistors too get back to me
May 22, 2007 | Toshiba 57HX81 57" Rear Projection...
Toshiba 61H71 61" Rear Projection Television Logo
292 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
