Question about Microsoft Windows 2000 Professional for PC
File Damaged While getting started to Windows 2000, massage is aooearing "File damaged can not be repaired"
    Scholar:
  • 151 Answers
Repair your OS with the help of OS setup cd.
Posted on Sep 28, 2007
    Problem Solver:
  • 4 Answers
Hi, Try fixing it using your BootCD. Use Scandisk to fix the error if it persist. Reinstall your Windows.
Posted on Sep 15, 2007
Issue Opening docx file
·Close Microsoft Word, then click Start, Run, type winword /a and press Enter. Try to open the document using this copy of Word.
·Try to insert the damaged document into a new document. Create a new document, then click on Insert, File, select the damaged document and click Insert.
·Try opening the file using WordPad then re-saving it to a new file, or copyimg the contents and pasting them into a new Word document.
Or try using a Microsoft Word document recovery tool such as Word Fix Toolbox
https://www.fixtoolbox.com/wordfix.html
Aug 31, 2015 | Microsoft Word for PC
Word Document Recovery Software ?
Use full version of Get Data Back recovery software.
Feb 04, 2015 | Microsoft Word Computers & Internet
Any Powerful SQL repair tool with new features
SQL database Recovery Software remove errors from corrupted SQL server database and allow to recover your all database of SQL Server Recovery tool support with all the MS SQL server version and MS windows.
Visit more here:- SQL Database Recovery Software SQL Recovery Tool
Jun 04, 2014 | Microsoft SQL Server 2000 Standard Edition...
It doesn't boot up and give a massage like inf file txtsetup.sif is corrupt or missing status 32768
you might have to make a bkf* to floppy disk since you have not mentioned an operating system i will try to explain with xp pro you might need another hard drive click start all programs accessories system tools then select back up use the back up in the top left corner next to welcome + to expand C drive then click+ on windows to expand scroll till you find repair box +to expand you will see a backup box + to expand you will see another two boxes bootable sytem state and service state place a tick in the backup box and note that all four boxes will have ticks in them the
then you will see at the bottom back up media or file name you can name it repair bkf*.next to it will be a browse make sure that A:\ repair.bkf* start backup tick in append this to the media select advanced tick in the back up data to this remote storage box and select normal from the drop down list
hope this helps
Nov 15, 2010 | NEC Galileo 845GL (N4-IBFGL) Motherboard
Replaced power supply, now it wont boot
The windows file system has nothing to do with the new power supply. Possibly yes however that the windows registry was damaged before you replaced the power supply due to an abrupt switching off operation which may have damaged the boot sector within your HDD. The solution is as recommended by windows. You can use the windows setup CD to get this fixed. I suggest you run a chkdsk /r at some point during the repair when you get the command prompt C>. Check the following for further info.
http://michaelstevenstech.com/XPrepairinstall.htm
Aug 05, 2009 | Sony VAIO VGC-JS230J/B PC Desktop
Ntldr is missing press ctrl alt del to restart cant install o/s
This problem may occur if the basic input/output system (BIOS) on your computer is outdated, or if one or more of the following Windows boot files are missing or damaged: Ntldr
Ntdetect.com
Boot.ini To resolve this issue, verify that the BIOS on your computer is current, and then use one or more of the following methods, as appropriate to your situation, to repair the Windows 2000 startup environment.
Verify That the BIOS on the Computer Is Current loadTOCNode(3, 'summary'); Make sure that the latest revision for BIOS is installed on the computer. Contact the computer manufacturer to inquire about how to obtain, and then install the latest BIOS update that is available for the computer.
Method 1: Use a Boot Disk to Start the Computer loadTOCNode(3, 'summary');
  1. Create a Windows 2000 boot disk that contains the following files: Ntldr
    Ntdetect.com
    Boot.ini
    Ntbootdd.sys For more information about how to create a boot disk, click the following article numbers to view the articles in the Microsoft Knowledge Base: 301680 (http://support.microsoft.com/kb/301680/ ) How to create a boot disk for an NTFS or FAT partition in Windows 101668 (http://support.microsoft.com/kb/101668/ ) How to use a Windows boot disk to prevent boot failure
  2. Modify the Boot.ini file to point to the correct hard disk controller and to the correct volume for your Windows installation. For more information about how to create a boot disk, click the following article number to view the article in the Microsoft Knowledge Base: 311578 (http://support.microsoft.com/kb/311578/ ) How to edit the Boot.ini file in Windows 2000
  3. Insert the boot disk into the computer's floppy disk drive, and then restart the computer.
  4. Copy the Ntldr file, the Ntdetect.com file, and the Boot.ini file from the boot disk to the system partition of the local hard disk.
Method 2: Use the Recovery Console loadTOCNode(3, 'summary');
  1. Use the Windows 2000 Setup disks to restart the computer, or use the Windows 2000 CD-ROM to restart the computer.
  2. At the Welcome to Setup screen, press R to repair the Windows 2000 installation.
  3. Press C to repair the Windows 2000 installation by using the Recovery Console.
  4. Type the number that corresponds to the Windows installation that you want to repair, and then press ENTER. For example, type 1, and then press ENTER. For more information, click the following article number to view the article in the Microsoft Knowledge Base: 229716 (http://support.microsoft.com/kb/229716/ ) Description of the Windows Recovery Console
  5. Type the Administrator password, and then press ENTER.
  6. Type map, and then press ENTER. Note the drive letter that is assigned to the CD-ROM drive that contains the Windows 2000 CD-ROM.
  7. Type the following commands, pressing ENTER after you type each one, where drive is the drive letter that you typed in step 4 of "Method 2: Use the Recovery Console," of this article: copy drive:\i386\ntldr c:\
    copy drive:\i386\ntdetect.com c:\If you are prompted to overwrite the file, type y, and then press ENTER.
    NOTE: In these commands, there is a space between the ntldr and c:\, and between ntdetect.com and c:\.
  8. Type the following command, and then press ENTER: type c:\Boot.iniA list similar to the following list appears: [boot loader] timeout=30 default=multi(0)disk(0)rdisk(0)partition(1)\WINNT [operating systems] multi(0)disk(0)rdisk(0)partition(1)\WINNT="Microsoft Windows 2000 Professional" /fastdetect If you receive the following message, the Boot.ini file may be missing or damaged: The system cannot find the file or directory specified.
  9. If the Boot.ini file is missing or damaged, create a new one. To do so, follow these steps:
    1. Use a text editor, such as Notepad or Edit.com, to create a boot loader file similar to the following boot loader file: [boot loader] timeout=30 default=multi(0)disk(0)rdisk(0)partition(1)\WINNT [operating systems] multi(0)disk(0)rdisk(0)partition(1)\WINNT="Microsoft Windows 2000 Professional" /fastdetect For more information, click the following article number to view the article in the Microsoft Knowledge Base: 102873 (http://support.microsoft.com/kb/102873/ ) Boot.ini and ARC path naming conventions and usage 301680 (http://support.microsoft.com/kb/301680/ ) How to create a boot disk for an NTFS or FAT partition in Windows
    2. Save the file to a floppy disk as Boot.ini.
      NOTE: If you used Notepad to create the file, make sure that the .txt extension is not appended to the Boot.ini file name.
    3. Type the following command at the Recovery Console command prompt to copy the Boot.ini file from the floppy disk to the computer: copy a:\Boot.ini c:\
  10. Type exit, and then press ENTER. The computer restarts.
Jul 07, 2009 | Compaq Evo D500 PC Desktop
Microsoft Windows 2000 Professional for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
